01-13-2010, 01:27 PM | #781 |
Rock Crawler Join Date: Apr 2008 Location: SO CAL
| Hmm ive had a similar problem and it turned out my voltage setting was wrong, differet esc but same problem
01-13-2010, 02:49 PM | #782 |
Newbie Join Date: Jan 2010 Location: Norway
01-13-2010, 02:57 PM | #783 |
did you do the one touch setup?
01-13-2010, 02:59 PM | #784 |
01-13-2010, 03:07 PM | #785 |
Newbie Join Date: Mar 2008 Location: portland
01-13-2010, 03:18 PM | #786 |
01-14-2010, 10:32 AM | #787 | ||
Quarry Creeper Join Date: Mar 2006 Location: SoCal
Our regular CS/Tech Support hours can be located here. Before emailing, take a moment to review the instructions (trouble-shooting guide) originally included with your Novak Item: Novak Instruction Downloads Trouble-shooting TeamNovak's One Touch™ Speed Controls Quote:
01-16-2010, 10:58 AM | #788 |
Rock Crawler Join Date: Dec 2008 Location: Appleton, Wi
I bught the havoc 3s for a scale build Im doing but I cannot get the esc to program for instant reverse. Is it possible to get instant revers or am I gonna have to deal with hitting the brakes, waiting a second then getting reverse?
01-18-2010, 05:57 PM | #789 |
Rock Crawler Join Date: May 2007 Location: Norwich
ANy update on the M2 Dig Esc? Some say late Feb, was hoping it may be sooner? Thanks
01-18-2010, 06:53 PM | #790 |
Rock Crawler Join Date: May 2007 Location: Corona, CA
My set up Losi Comp Crawler 7.4v 1700 35c Goat esc 13.5 motor with large rotor Well what i would like to know is why reverse has double the power/torque and wheel speed then forward. I have tried to reverse the motor in the esc and have also calibrated the esc backward. I have also done this many different ways. what can I do? |
01-19-2010, 09:17 AM | #791 | ||
Because I am not part of Novak's technical support group, I suggest you email tech@teamnovak.com with your question, Our regular CS/Tech Support hours can be located here. Before emailing, take a moment to review the instructions (trouble-shooting guide) originally included with your Novak Item: Novak Instruction Downloads Trouble-shooting TeamNovak's One Touch™ Speed Controls Quote:
01-19-2010, 09:32 AM | #792 |
Quarry Creeper Join Date: Nov 2009 Location: San DIego
I think the title of this thread should be changed to this email tech@teamnovak.com thats about the only help you get here. Maybe the tech guys from novak could log on here and maybe help us out couple time a week. If not this thread makes no sense without the help.
01-19-2010, 10:03 AM | #793 | |
01-22-2010, 03:48 AM | #794 |
I joined the Band! Join Date: Apr 2007 Location: norfolk
I am going to use the above address to see if I can get an answer to my problem. I thought I would put it on here too. I just recently got a Crawler King, and installed a Rosster Crawler ESC. At 1st , on both profiles I did not get any drag brake. Then if I push the set up button while power on it blinks repeatedly then I had some brake. Now it does a slow roll down hill and will not hold its position without holding the throttle mid way. Is this normal for the WK Trans???? THANX!!!!!!!!!! |
01-30-2010, 10:38 PM | #795 |
Quarry Creeper Join Date: Dec 2009 Location: Salisbury, Maryland
You might want to e-mail Novak tech support. I have a feeling that's what you are going to be told after reading the last few pages of this thread. |
01-30-2010, 11:23 PM | #796 | |
01-30-2010, 11:32 PM | #797 |
Rock Crawler Join Date: Sep 2005 Location: Duncan, BC, Canada
uhhh ... when did the Rooster get an adjustable drag brake? According to my instructions there are just two proflies to choose from, 1. w/o LiPo cutoff, and 2. w/ LiPo cutoff Both profiles having 100% fwd and rev, and drag brake at 90% Last edited by Rockfrog; 01-30-2010 at 11:40 PM. |
01-30-2010, 11:59 PM | #798 |
I assumed the rooster had the same basic adjustments the goat does, guess it don't have squat. Still though it sounds like the OP isn't doing the one touch correctly.
02-03-2010, 10:27 PM | #799 |
Newbie Join Date: Jan 2010 Location: Orem
| Novak Ballistic Goat 3s MOA
Novak.... I'm planning to run (2) 21T Ballistic Motors and (2) ESC's with The Dig unit on the Berg MOA axles. Will this work? Any suggestions? Thank you! |
02-04-2010, 01:51 AM | #800 |
Rock Stacker Join Date: Jan 2010 Location: spokane
Just install my noval rooster and 55t in my axial.. blast to drive around the room for now, tomorow outside for me Only 1 problem and that was soldering deans connecters . wish they was presoldered but I GOT ER DUN |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/85567-official-novak-crawler-products-thread.html | ||||
novak rooster crawler edition | This thread | Refback | 10-04-2011 04:16 PM |
