02-04-2010, 06:36 AM | #801 |
"HOLLYWOOD" Join Date: Dec 2008 Location: Miami
Any update on the M2Dig? They said early Feb.
02-06-2010, 10:06 PM | #802 |
Pebble Pounder Join Date: Jan 2010 Location: East Boston
This might be a dumb question but, I just picked up a Goat 2S, and I have no idea how to wire the BEC. I'm guessing its the two pins for the auxiliary fan. And then the signal to the servo comes straight from the receiver..? Is this correct? I'm pretty new, but it's not exactly explained in any documents from Novak, and I want to do it right the first time.
02-07-2010, 08:46 AM | #803 |
Newbie Join Date: Feb 2010 Location: St. Joseph
Any timeframe on catching up with demand for the 3s Goat/ballistic motor systems. I've had one on order from tower for over a month.
02-07-2010, 08:57 AM | #804 | |
02-07-2010, 12:08 PM | #805 | |
02-07-2010, 12:17 PM | #806 |
Rock Stacker Join Date: Nov 2009 Location: santa cruz
you should try rpphobbies, thats were i got mine. when you do get it you will love it crazy as hell
02-07-2010, 03:02 PM | #807 |
| Wouldn't that send straight battery voltage to the servo..? I'm not quite sure I understand, because Novak claims it is a 6V/5A BEC, but if it solders to the battery leads, it would be whatever battery voltage is, no?
02-07-2010, 08:55 PM | #808 |
He's telling you how to add an external BEC like the 3s goat has. The wire that runs from the ESC to the RX is the 5 amp line, the other two pins just jump off it to power a fan, you don't need them.
02-08-2010, 05:56 AM | #809 |
| Ohhh. So the esc sends power to the steering servo through the receiver?
02-08-2010, 10:33 AM | #810 |
Newbie Join Date: Feb 2010 Location: UK
Just a few pictures of our newly built Tamiya CR-01 Junfac Joker. We have a Novak Rooster, 55 Turn Novak motor, Intellect 4200mah Lipo saddle batteries and a Castle 10 amp BEC powering 2 x Hi-tec HS-5645MG servos via a y lead for crab crawl. this is my son and my first home build. Tried to make the wiring as net as poss, there sure is a lot of it, and to get the receiver as far away from the ESC. We have a Etronix powerpal charger, but it did not come with the correct balance board to connect to the lipo's for balance charging. Cheers Simon. |
02-08-2010, 11:15 AM | #811 |
Rock Crawler Join Date: Jul 2006 Location: Hobbywing
Woohoo, look at the Tidy Wires, like a harness out of a real VW.... maybe even a few extra wires!
02-08-2010, 11:36 AM | #812 |
02-08-2010, 01:06 PM | #813 |
02-08-2010, 01:32 PM | #814 |
| It just doesn't make sense to me. The receiver originally sent power from the external battery pack to both receivers. How does the receiver know that it is supposed to take power from the ESC output and send it to the steering servo output?
02-08-2010, 02:05 PM | #815 |
The three wires running from the ESC to the RX are: red+, black- and white signal. The RX + and - bridge all the way up and down with seperate signals. The ESC powers the RX and servo's the same as the RX pack did in the nitro's.
02-08-2010, 06:02 PM | #816 | |
Also, by just plugging the positive and negative leads to the positive and negative inputs on the ESC, I am utilizing the low voltage cutoff, correct? Last edited by Rob C; 02-09-2010 at 11:28 AM. | |
02-09-2010, 07:11 PM | #817 |
Newbie Join Date: Feb 2010 Location: Signal Mtn.
I just went and bought one of the goat 3 s withe ballistic 18.5 turn and it rocks
02-09-2010, 09:27 PM | #818 |
Rock Crawler Join Date: Nov 2008 Location: lakeside
ok i have a goat 3s with 18.5 motor. some times when i power it on it well run fine for a min. or two then well start to glitch out? what shoould i do to fix this?
02-09-2010, 09:31 PM | #819 |
Rob C, you have to turn the cutoff on in the programming. Also at some point depending on how many servo's you run and how many amps they draw you might need to add an external BEC, for me the one built in was enough for a 8711, but when I added a dig servo I had to add the external unit. There's a couple ways to wire them in, Either the way stated above by 2500hdon37s or directly powering the servo's. |
02-10-2010, 05:22 AM | #820 | |
Just one for steering. I'm sure I'll be fine. Thanks for the help. This motor/esc combo rocks my socks. | |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/85567-official-novak-crawler-products-thread.html | ||||
novak rooster crawler edition | This thread | Refback | 10-04-2011 04:16 PM |
