11-24-2009, 11:53 AM | #741 |
Pebble Pounder Join Date: Oct 2009 Location: Dallas
| 18.5 crawler sensor wire issue
I've already submitted this to Novak support but I figured I'd post here as well. I just bought a Goat 3s with the 18.5 Crawler motor. The guy I got it from said it had an intermittent issue that seemed to be with where the sensor wire plugs into the ESC. It just stops running but all of the lights are on like normal. You can immediately unplug and plug it back in and it will be fine for a little while and then for no apparent reason will cut off again (short). Again re-seating the sensor wire connection will fix it for a while. I recorded the light sequences and are. The normal Blue, Amber and Red, hit the throttle either forward or reverse and they go Blue, Amber and Green then the Red light flashes 6 times and then goes off for a few seconds like it's resetting then Green and Red flash then back to the normal Blue, Amber and Red. You can hit the throttle again and it does the same sequence. I do have another Goat 2s with an 18.5 so I pulled the 18.5 crawler motor and sensor wire off it and put it on the 3s and it seems to be just fine. Is this something I can send to you and have fixed or would I be better off buying another motor/sensor wire combo. I tried to see if replacing the wire is something I can do but it doesn't look possible on this motor. Thanks Larry |
11-24-2009, 12:30 PM | #742 | |
Quarry Creeper Join Date: Mar 2006 Location: SoCal
| tech@teamnovak.com is the best place to ask about your options. We can replace your motor for @39 +sh/handl. Quote:
11-24-2009, 01:03 PM | #743 | |
How much more would it be to upgrade to a Ballistic 18.5 Crawler motor? Quote:
11-24-2009, 01:56 PM | #744 |
11-26-2009, 12:29 PM | #745 |
Our new Ballistic Crawler motors will begin shipping shortly. We have added the replacement wound stators for these motors to our store: Ballistic Crawling Hand-Wound Stators We will be adding the 17.5T wound stator to the options. If you want to try a different wind Crawler motor: just replace the stator, instead of buying an additional motor. Last edited by NovakTwo; 11-27-2009 at 11:09 AM. |
11-29-2009, 06:35 PM | #746 |
Pebble Pounder Join Date: Nov 2009 Location: OKC
| Rooster crawler esc
Hi guys, I have a Rooster crawler esc and 55t Novak setup in my crawler and have never had any problems. Recently I bolted up a set of weighted alloy beadlocks and now my rig seems to not have the amount of drag brake it once did. On hill climbs when I let up on the throttle it'll ease down hill and I was wondering is there anything I can do to prevent this. I am not willing to get rid of the weights in the wheels because it will now take lines it would otherwise flip over on without the weight. BTW I love this forum for it's abundance of info and wish I had joined sooner! |
11-30-2009, 08:09 AM | #747 |
Quarry Creeper Join Date: Sep 2007 Location: NE Ohio
Lately I've been having a drag brake issue with the Rooster Crawler ESC. After a couple of runs, I'll turn off until my next turn and then real quick check the drag brake function and it's not there. Typically I've been turning off and reprogamming it and then drag break works fine, until next time it's turned off then off then has drag brake issue all over again. I have the Traxxas TQ4 radio system and there where alot of racers & crawlers at the local club spt, so not sure if I was getting interference. I will try again this Tuesday to make sure. Chris |
11-30-2009, 09:50 AM | #748 | ||
I recommend that anyone with specific Novak product related issues contact Tech for trouble-shooting help. The more info you include, the more likely it is that the Techs can help you. I also generally suggest the following: You can always email tech@teamnovak.com with your question, during regular CS hours. Before emailing, take a moment to review the instructions (trouble-shooting guide) originally included with your Novak Item: Novak Instruction Downloads Quote:
PS: It's a good idea to send this comprehensive info to ANY company when you are requesting product or application assistance. | ||
12-01-2009, 08:14 AM | #749 |
Rock Stacker Join Date: Nov 2009 Location: hamilton, oh
This thread is pointless, Novak 2 all you do is refer people to tech support. why not have a tech support guy post here. The point of these forums is so people can find solutions to problems others have had and to share knowledge. I read one long post after another where people post info and then you direct them to customer support. Even after they said they sent the info to customer support. You make me want to sell my novak and buy something else. |
12-01-2009, 09:02 AM | #750 | |
| So many R/C forums, so little time..... Quote:
Almost every problem you have in your racing electronics will seem to cause problems for the esc, whether it is an esc problem, or not. Finding out what is causing the problem can be a lengthy process; technicians just don't have the time to do this (and sort through extraneous comments) in the forum threads. Some here may not approve of our method of helping our customers, but we have been providing tech support in this industry for over 30 years and it seems to be working fairly well. When we identify common problems, or questions, customers have, we prepare technical updates for all to read---posted on the front page of our website (right column.) Perhaps you could direct me to Crawler forum threads in which other major electronic manufacturers are offering superior tech service; we are always willing to review our policies and update procedures. | |
12-01-2009, 02:24 PM | #751 |
thank you for the cookie cutter reply, blah blah blah, goto customer service, you are as bad as best buy. So worried about corporate bs you are actually losing your customer support. Really, why don't you at least send someone in the right direction or use some of your technical expieriance to help people out. Novak is losing ground to Tekin and Advanced Electronics, soon you guys will be an entry level brand. |
12-01-2009, 06:47 PM | #752 |
Newbie Join Date: Mar 2009 Location: Tucson
| novak havok
I found a 21.5 novak havok sensored BL motor/esc combo for a good price would this work good in a LCC?
12-01-2009, 07:39 PM | #753 |
Rock Stacker Join Date: May 2005 Location: West Bend
This is the same bull shit that gets posted on rcmonster from Novak. Lets push our products out the door and post the same crap when there is a problem, e-mail tech support. WTF was I thinking when I bought a goat 3s!?!?!?
12-02-2009, 09:17 AM | #754 |
RCC Addict Join Date: Feb 2005 Location: Minneapolis
When is the new Goat 3s with 18.5 motor going to be out? It was supposed to be in some shops on 11/27, still not there.
12-02-2009, 09:56 AM | #755 | |
Let me make one additional point about Tech Support: I am not part of our Engineering/Tech group. I am not qualified to offer technical advice; so I always direct forum members to contact the Novak guys who can offer them personal assistance. We are a very small company (@40-45 employees, most of them in manufacturing) and simply do not have excess employees who can spend their days monitoring the vast array of R/C forums. I always try to respond quicky to questions by directing forum members to the help or information needed to solve problems. I monitor many forums daily and I believe that our level of forum support equals, or exceeds, that of other R/C companies that are much larger than Novak. | |
12-02-2009, 10:00 AM | #756 |
12-02-2009, 11:21 AM | #757 | |
in the industry and offer the support customers need instead of whining about what other manufactures are doing. | |
12-02-2009, 11:56 AM | #758 | |
I can't please everybody; just do the best I can. It is unusual to receive this much criticism for my presence here and attempting to resolve customers' problems. | |
12-02-2009, 03:38 PM | #759 | |
"Call tech support" isn't much of an attempt to solve customer problems. I'm not trying to be as critical as I may seem, I'm just looking for better customer service. I understand Novak is a small company and there are only so many hours in a day but even something as simple as "call tech support and talk to "John Doe", he's an expert on the Goat ESC." shows a bit more customer care. | |
12-02-2009, 10:59 PM | #760 |
Newbie Join Date: Jun 2009 Location: qualicum Beach B.C
Is the pro SS 21.5 brushless motor compatible with the goast 3s and what are the differences between this motor and the 21.5 crawler motor. (advantages /disadvantages)
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/85567-official-novak-crawler-products-thread.html | ||||
novak rooster crawler edition | This thread | Refback | 10-04-2011 04:16 PM |
