08-23-2009, 08:52 AM | #681 | |
Quarry Creeper Join Date: Mar 2006 Location: SoCal
08-23-2009, 09:13 AM | #682 | |
Number of Turns: 13.5 (#3414), 18.5 (#3419), 21.5 (#3420) Watts: 195 (#3414), 119 (#3419), 85 (#3420) KV (unloaded) 3,300 (#3414), 2,700 (#3419),1,800 (#3420) RPM/Volt The 13.5 spins 600 rpm faster per volt than the 18.5. 7.4 x 3300 = 24,420 for the 13.5 7.4 x 2700 = 19,980 for the 18.5 11.1 x 2700 = 29,970 for the 18.5 | |
08-23-2009, 09:54 AM | #683 | |
08-23-2009, 11:56 AM | #684 | |
or i could gear down with the 18.5 on 3s and have more wheelspeed than now or with the 13.5 and get a torque boost from the gearing. | |
09-09-2009, 10:21 AM | #685 |
Quarry Creeper Join Date: Jan 2005 Location: uk s,wales blackwood
just fitted a goat 3s in my losi with a 17.5s sensered brushless motor 12t pinion with a 3cell lipo and when i go from fowards to reverse quickly and some times from neutral to reverse it jerks violently and then does not move untill the trigger is released and moved slower the green led is solid and the amber is flashing or only the amber led is on when going from neutral to reverse quickly with no movement of the truck untill again the trigger is released and moved slower any suggestions please my radio is a spektrum dx3 and i have done the 1 touch setup all other settings are factory settings |
09-09-2009, 10:37 AM | #686 | ||
Novak Instruction Downloads Quote:
09-18-2009, 07:02 PM | #687 |
Rock Stacker Join Date: Jun 2009 Location: Buford, Georgia
I have a question about the 5 amp BEC rating on a 2s GoatCrawler esc. I am running 2 goat crawlers so does this mean 10 amps total? both ESC's are on a "Y" harness leading to my Futaba reciever. Do you know how many amps a pair of Futaba s9157 servos draw? I just want to be sure I am within Novak's specs. Thanks, Harry S. |
09-19-2009, 09:49 AM | #688 | |
Shoot an email to tech@teamnovak.com for assistance. Quote:
09-20-2009, 03:16 AM | #689 |
Rock Crawler Join Date: Jul 2006 Location: Hobbywing
Old S - When you run Dual ESC's in Parallel through a "y" harness to an RX, yes, you get double the BEC rating, or at least very close to that. I "think" but could be wrong for this to happen you have to have both on/off switches turned on, so N2 is probably correct in the recommendation to Email them directly. I've run Dual ESC's with a Y harness over the years and it usually works totally fine. |
09-24-2009, 09:04 AM | #690 |
"HOLLYWOOD" Join Date: Dec 2008 Location: Miami
Hello want to ask have noticed that my ESC has been running a little to HOT for my liking is this something I should be worried about? Thank you.
09-24-2009, 04:45 PM | #691 |
Newbie Join Date: Aug 2009 Location: farmington
ok ive got the novak goats system and i love it but i was trying to run lipo and i already have tons of three cell lipo batterys and i was wondering if there is anyway to run three cell batterys on it. but i have a 850 2 cell and when i plug it in it works fine for about a minute and then i just starts blipping and then the red light comes on and it just totaly shuts off i need some help thanks alot.
09-24-2009, 05:08 PM | #692 |
09-24-2009, 05:16 PM | #693 | |
Thank you for all your help. | |
09-25-2009, 10:50 AM | #694 | ||
Because I am not part of Novak's technical support group, you may need to email tech@teamnovak.com with your question. Before emailing, take a moment to review the instructions originally included with your Novak Item: Novak Instruction Downloads Quote:
Novak Fan/Cooling Accessories | ||
09-25-2009, 11:53 AM | #695 |
Ok thank you.
09-25-2009, 11:58 AM | #696 |
my goat would get hot enough that you couldn't hold your finger on it after just a minute of being on, not even driving. i added the fan a month or so ago and it stay's nice and cool now, i think the 3s comes with the fan the 2s probably should have.
09-25-2009, 12:07 PM | #697 |
| Mine takes a little longer that that to heat up, but yea it get's to the point were you cant hold your finger to it. And it never did that befor scare's me a little, and there really is not too much room on my chassis to put a fan eaither. |
09-25-2009, 08:31 PM | #698 |
the fan bolts on top of the heatsink, it's the same size square and about a 1/4 inch thick. so if you've got about 1/4" above the ESC fins it'll fit.
09-26-2009, 03:21 PM | #699 | |
| Quote: Mine are clear plastic, 30 mm size. I have 2 of them installed in my crawler (one on each ESC) both of the ESC's stay stone cold and actually add a small touch of bling. Harry Last edited by Old Sloppy; 10-02-2009 at 04:40 PM. | |
10-28-2009, 11:12 AM | #700 |
| Thanks fixed everything once I installed a BEC direct to my steering servo, that sucker does not even get warm now |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/85567-official-novak-crawler-products-thread.html | ||||
novak rooster crawler edition | This thread | Refback | 10-04-2011 04:16 PM |
