02-11-2010, 04:30 PM | #821 |
Rock Stacker Join Date: Jun 2009 Location: Buford, Georgia
02-12-2010, 10:53 AM | #822 |
Rock Crawler Join Date: Jul 2006 Location: Hobbywing
If you're using NiMH, it might be in Lipo Mode.
02-12-2010, 08:28 PM | #823 |
Rock Stacker Join Date: Jan 2010 Location: phoenix
I have the same problem as Tomer. I have the stock controller and rx that comes with the lnc. I suspect that they are the culprits to my problem. If they are what controller would you recomend to over come this. 21t goat/ballistic w/fan and bec istalled hyperion 3s/11.1v 25c 1100mah I am a tig welder by trade and mechanically inclined, I'm very confident that everything is correct and soldered well. bec is at the top of pics next to the motor rx is out of pic mounted to the under side of the roof. Also out of the picture is the esc mounted over the rear axle. |
02-14-2010, 11:12 AM | #824 |
Rock Crawler Join Date: Nov 2008 Location: lakeside
02-14-2010, 11:41 AM | #825 |
Describe the glitch. Does it just shut off? Take off at full throttle? Jump back and forth? Creep foward with no throttle?
02-14-2010, 01:51 PM | #826 |
I tried to take a video of it today and it wouldn't do it. 3 batteries and no glitch. I guess I am happy it didn't glitch but I wanted to show it here and the tech at novak. The temp today is 72* the warmest its been this year. Knowing that batteries are effected by temp more than any other part on the car I wonder if i don't have enough battery for the motor. The glitch is just like a bad tuned carberator, as soon as you need to bump an obstical or nice steady throttle it cuts out. It usually glitches 2-5 times really fast then runs fine. I doesn't seem to have anything to do with any noise from the steering servo. Maxing out the deadband on the goat deffianatly helped, but I don't want it to happen at a comp. I still want to improve its performance. |
02-14-2010, 04:01 PM | #827 |
It could be a battery issue. I run the 2s goat 18.5, started having an issue with the truck shutting off as the temps dropped with a 1900 20C (whether that was peak or con. I don't know) 2s pack, the colder it got the worse it got. I have a 3300 20/35C 2s pack that would never have the issue but was to thick for what i wanted. I now run a 1650 30/50C 2s pack without the issue. I have had a similar deal happed with a bad sensor harness also.
02-14-2010, 05:15 PM | #828 |
thanks mudcat I'm gonna order a Hyperion G3 VX - 3S 1800mah 35C Lipo. The more and more I think about it its the battery. I do think that I wanna upgrade my radio as well. |
02-14-2010, 06:01 PM | #829 |
I did have a ton of glitching issue's with my Goat on AM that went away with 2.4, so I wouldn't rule the radio out. Since you both have 2.4 and Tomer's is the 3r I think battery, Novak does reccomend a high C pack and high end radio though. Also another thing it could be is the BEC, the one Novak includes with the 3s Goats is 3amp, if your powering your rx and servo with it it could be dropping voltage to the rx.
02-14-2010, 06:03 PM | #830 |
the glitch is like a brushless motor that is senserless trying to creep along. and the motor and esc is nice and cool. i am on throttle light or on it hard.
02-14-2010, 07:09 PM | #831 |
Interesting about the bec, I am powering both rx and steering. Is there anything to watch for if I go with a 5 amp (over loading something). My concern is why do they give you 3 amp and show you how to wire it to power both steering and rx. I thank you very much for your lesson here |
02-14-2010, 08:05 PM | #832 | |
Tomer yours sounds like either a sensor harness issue or just the effects of the 14mm rotor. | |
02-15-2010, 09:15 PM | #833 |
but it is not a problem everytime i trun it on . it is just sometimes.
02-15-2010, 09:30 PM | #834 |
Stock AM radios are fairly well known to not work awesome when you use upgraded Servos and ESC/Motor setups. Sometimes you get a good one and it works okay, other times, you get periodical goofyness. The big thing I have found with any AM, be it an RTR or even a fancy pants aftermarket one, is the wire routing is everything. Bundles of wires together usually wreak havoc on them, so keep all the wires in separate bundles. Also, the antenna is crucial, It sorta "needs" to go up and out of the truck as soon as possible. Having it coiled up or wrapped around usually won't work that well. Cold Lipos are a common problem too. When the pack is cold, it's like it's dying, the voltage actually goes down slightly, and the resistance goes up, this makes it hard for it to do it's job. At comps I try to keep them in my Pocket to warm them up, or run my heater in my car for a few minutes and put the pack under the vent, then put it in my pocket and "keep it warm". Little lunch boxes and those "warmer pouche" things could be very useful for this.... If it's just a startup glitch, it could be a lot of things, starting with wiring issues at the plugs, the battery being a bit on the weak side, or even the gear mesh being bad. I work in a hobby shop, and it seems that a lot of guys don't really understand or appreciate how important gear mesh really is. |
02-15-2010, 10:42 PM | #835 |
my radio is a dx3r. looked at wiring and gear mesh. they are all good. running 35c 3 cell lipos. its not cold in san diego so could it be the on off switch that is going out?
02-16-2010, 05:02 PM | #836 |
I am glad to say my glitch is fixed, but ashamed of what was wrong. I still had my red wire from rx to esc hooked up. I read it the first time i read the directions but when it came time to install i forgot. I thank John at novak for his help. The solution to my problem was in the first sentence of his e-mail which leads me to believe i'm not the first special one to pull this off. For anyone that managed to do what I have done remember the red wire will be hot, it must be insulated!!!!!!!!!!!!! Travis |
02-20-2010, 03:03 AM | #837 |
Rock Crawler Join Date: Oct 2009 Location: Wasilla, Alaska
So i just installed a used goat 2s 18.5 and it doesnt want to turn, and the motor gets hot real quick. using a 6 cell 7.2v battery, and who ever owned it first extended the sensor wires. Any help would be appreciated thanks |
02-20-2010, 03:16 AM | #838 | |
Quarry Creeper Join Date: Feb 2009 Location: ewetah
Sounds like you have some binding somewhere or your pinion mesh is to tight. What truck is it in? | |
02-20-2010, 03:22 AM | #839 |
Pebble Pounder Join Date: Dec 2009 Location: England
| rooster crawler
im just about to buy a rooster crawler and all this crazy jittery talk has got me worried i use a hpi tf-1 radio will i have to get a new one or will it be ok thanks novak |
02-20-2010, 03:31 AM | #840 |
Its in a night crawler, i can turn it with my fingers when its off. i even pulled it out and tried to get it to turn but it just bounces back and forth
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/85567-official-novak-crawler-products-thread.html | ||||
novak rooster crawler edition | This thread | Refback | 10-04-2011 04:16 PM |
