04-06-2012, 03:37 PM | #21 |
Rock Crawler Join Date: May 2011 Location: SoCal
| Re: Harley's Project: Comp Cart
Best check your charger will work with that battery long enough for the three of you. My charger has some sort of LVC on the input. It doesn't put up with 11ish volts.
04-06-2012, 03:48 PM | #22 |
| Re: Harley's Project: Comp Cart With how this plan is developing I may bump battery size up, but that one is 35ah so I feel pretty confident it will handle that charging duty without any problems.
04-06-2012, 03:56 PM | #23 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
Uh, why isn't it going to have a powered drivetrain....I mean, sure would be easier to move along. Holmes probably could adapt one of his ebike setups to work...big ass servo for steering and DRIVE it into comps. Later EddieO |
04-06-2012, 04:21 PM | #24 |
| Re: Harley's Project: Comp Cart You need to figure out how much capacity you'll use up in a day, then buy a battery twice that size to actually achieve that amount of usage.
04-06-2012, 04:38 PM | #25 | |
Pebble Pounder Join Date: Jul 2009 Location: Fort scott
| Re: Harley's Project: Comp Cart Quote:
My experiance with those is they tend to get unstable with whaite, and hard to move. The lack of bearings in the wheels and the wheele base is to narrow. | |
04-06-2012, 04:48 PM | #26 |
| Re: Harley's Project: Comp Cart These do have bearings in the wheels but could use width. All the weight will be low but it could still use some width. None of that is much of a concern though since width is a super simple fix if we did want to.
04-06-2012, 05:40 PM | #27 |
Good, I didnt know that HF would put bearings in. The ones we have at work are junk and every time the field service guys come back There is something that has to be maintained on them. |
04-06-2012, 05:57 PM | #28 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
I got something like that... Its called a Wagon. |
04-06-2012, 05:59 PM | #29 |
Newbie Join Date: Feb 2012 Location: Sacramento
It wouldn't hurt to throw a 10$ digital battery meter somewhere. A fully charged 12 lead acid battery should be above 11.8 long enough to charge a pack or two if its a 5-10Ah. A car battery (650Ah Honda size) would leave a small footprint but run your mini-fridge, charger(s), tvs, car alarm system(everyone has to poop eventually, might as well have a lockup and alarm) and still be able to power a small 3-600w inverter. Hell you can bring jumper cables and charge people to jump their 1:1 batteries, too!
04-06-2012, 06:36 PM | #30 | |
04-06-2012, 06:49 PM | #31 |
I wanna be Dave Join Date: May 2006 Location: akron
how are you going to keep the weight down on this your drawings look like it will be pretty heavy when fully loaded.. those carts suck on pretty much anything but smooth paved surface's with just a light load on them.. I would definitely consider some power assisted axles. |
04-06-2012, 06:53 PM | #32 |
Don't forget a fire extinguisher and sand bucket mount. |
04-06-2012, 06:54 PM | #33 |
I wanna be Dave Join Date: Aug 2008 Location: cape crud... will you be my friend
04-06-2012, 07:52 PM | #34 | |
Psssssh, sounds too easy. What would I do while I was at work then? Actually work what I should be? | |
04-06-2012, 07:56 PM | #35 | |
The battery I listed is a deep cycle. That's a requirement. | |
04-06-2012, 07:58 PM | #36 | |
04-06-2012, 08:28 PM | #37 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
I say screw the cart and just build a 1/4 scale Dakar support truck. Do you reaaaaally want to pull a cart around instead of drive it?
04-06-2012, 09:35 PM | #38 |
| Re: Harley's Project: Comp Cart |
04-11-2012, 10:44 AM | #39 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
who's gonna pull it? thats the question... you boys better start hitn the gym..i forsee it being to heavy once all is added on the cart. |
04-11-2012, 11:16 AM | #40 | |
The metal work is planned to be aluminum. It definitely won't be something you can just throw around but shouldn't be terrible to pull. | |
Harley's Project: Comp Cart - Similar Threads | ||||
Harley's Dark Soul MRC Comp Rig | Harley | Losi Mini-Rock Crawler | 176 | 11-01-2018 12:22 PM |
Harley's Project Tweaker - Reiteration from '09 | Harley | 1.9 Scale Rigs | 40 | 12-01-2012 11:13 AM |
Harley's Axial Comp Chassis - "Hybrid" | Harley | Chassis and Suspension | 43 | 11-06-2008 08:33 PM |
Harley's March Comp rig | Harley | Axial AX-10 Scorpion | 58 | 03-30-2008 12:33 AM |
project rock cart | rock_starr | Tamiya TLT Crawlers | 15 | 05-20-2006 09:10 PM |
