12-12-2009, 07:16 PM | #181 |
| You may need to flash the firmware again, if you have the bug where there is no reverse. Otherwise ready to go with lipo cutoff already on.
12-12-2009, 08:46 PM | #182 |
Quarry Creeper Join Date: Jan 2007 Location: Hawk Point
12-12-2009, 08:52 PM | #183 | |
I wanna be Dave Join Date: Jan 2009 Location: laying low
if you hook the esc up to your rig and the reverse is working norm then you are good to go.. clear as mud? | |
12-12-2009, 10:10 PM | #184 | |
Shipments going out since thursday have been fixed. | |
12-13-2009, 08:48 AM | #185 | |
Quarry Creeper Join Date: Jun 2009 Location: Fredericksburg
Thank You John Can't wait to run it | |
12-13-2009, 01:11 PM | #186 |
Rock Crawler Join Date: Jun 2007 Location: Arlington
Yep, got her installed and it wasn't recognizing my transmitter inputs. Once I realized that it wasn't arming, I turned the transmitter off and back on again. It armed, but did not have reverse. CC link fixed it all with a quick 1.02 firmware update. I had to go wth a bit wider of a throttle deadband setting, but everything is working fine for now. I also removed the 4mm bullet posts for wires with bullets attached. I'm using this in a DNA slingshot, so they were a little taller than I liked. I LOVE not having to use a BEC. My z9100t and HS225-MG are not stalling anything out on 2S/3S with a handwound 35T arm in an EPIC Cobalt can. Excellent ESC John, thanks. |
12-13-2009, 04:30 PM | #187 | |
Old guy Join Date: Jan 2007 Location: Northwest Arkie-saw and we got ROCKS!
12-13-2009, 04:58 PM | #188 |
Much cleaner wiring with no BEC to install. So far, no servo stalling. |
12-14-2009, 05:23 PM | #189 |
53 Willys and J R H, The following is a quote from 53 Willys reply dated 12-12-2009 09:52 PM , "and all you need to do is hook up the castle link to the esc and upload the newest update/firmware to fix it????". This is what I do not know how to do. I'm guessing you are talking about hooking the BR-XL ESC to a computer via a hard wire connection like the Mamba Max. The only problem is my BR-XL ESC does not have a USB port like the MMax. How do you make the connection to a computer???? I'm still stuck in the mud. Thanks for the help, Hawk |
12-14-2009, 05:36 PM | #190 |
Pebble Pounder Join Date: Nov 2006 Location: vaca, nor cal
You need to use the Castle creations "Castle link". It basically is a connection at "receiver end" and turns it into USB , its pretty cool. http://www.castlecreations.com/produ...stle_link.html link for more info Last edited by rentstdi; 12-14-2009 at 07:56 PM. Reason: added link |
12-14-2009, 07:15 PM | #191 |
rentstdi, Now I know what I am missing a "Castle link" USB Connector. Many thanks to you rentstdi John do you have this item in stock? Thanks again rentstdi, Hawk |
12-14-2009, 07:17 PM | #192 |
I have plenty of the programmers in stock. Sorry for the mixup on my part.
12-14-2009, 07:45 PM | #193 |
John, Just place an order for the "Castle Link" plus other stuff. Please check I ordered correct "CL". Thanks, Hawk |
12-14-2009, 07:57 PM | #194 |
Looks good to me, thanks!
12-14-2009, 09:12 PM | #195 |
mine FINALLY showed up today Thanks JRH! |
12-14-2009, 11:30 PM | #196 |
I got 2 nice little esc's in my mail box today too!!!! I'm pumped to get these bad boys installed on my new rig!!! thanks JRH!! |
12-18-2009, 11:08 AM | #197 |
Damn man, another fast as hell shipment! I cant wait to get to building on my super that's gonna be running two of these bad boys! |
12-23-2009, 08:15 PM | #198 |
JRH I got a quick question for you... do I have to use the bullet connectors you sent with the esc's I bought or can I just solder wires right into the esc's motor connections??...I dont really have room for the extra height the bullets would cause... thanks |
12-23-2009, 09:04 PM | #199 |
[HOONIGAN] Join Date: Nov 2005 Location: Grand Junction
When are we going to be able to change the throttle curves on these? I really don't like the stock the linear throttle cure that's on this thing. Also, fyi for those looking to run 3s or more voltage to these things, the internal BEC is not enough for your 300-400oz servos. I've noticed a big decrease in power on my scalers, even my 1.9, and my berg running 4s and a Hitec 7950TH won't even steer when there is a good load on the servo. The big servo's still need the power of the 10amp CC BEC versus the 5amp internal BEC on these. |
12-24-2009, 09:12 AM | #200 | |
guess I should be looking at running my CC BEC after all? | |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/holmes-hobbies/200916-torquemaster-br-xl-big-brushed-power.html | ||||
HH TorqueMaster BR-XL new bad boy esc! | This thread | Refback | 10-04-2011 03:37 PM |
