06-07-2010, 10:02 AM | #381 |
Yeah, both of my BR-XL start up faster than my Sidewinder. You don't have very good low speed control with it. I have swapped in my Sidewinder (throttle curves haven't been tampered with) with the same battery/motor combo and it works just fine. It's the only thing that I don't like about them.
06-07-2010, 10:14 AM | #382 |
Interesting. My motors seem to whine plenty before they start up. I will look into it and see if there is any remedy.
06-07-2010, 12:32 PM | #383 | |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
06-07-2010, 01:33 PM | #384 |
Hey Beefcake Scattman and constantmotion, what motors are you guys using? |
06-07-2010, 01:50 PM | #385 |
06-07-2010, 03:37 PM | #386 |
Rock Crawler Join Date: Nov 2009 Location: Wildwood
I am also having the fast start issue. I have Holmes 45t motors.
06-07-2010, 06:58 PM | #387 |
35T JPCustoms Warriors and a 30T HH TorqueMaster Pro
06-07-2010, 08:00 PM | #388 |
I think I was noticing the same startup issue at the scale nats on my trail rig. I thought it might be the motor I was using though (21t 550 can) I destroyed my 30t handwound during the ttc, and didn't have very many chances to notice if it was still doing it though. I'll have to throw another motor in there and check it out. |
06-07-2010, 08:02 PM | #389 |
Hmmm. Quality motors.... I guess I might not be noticing it because I'm using mine in a Losi? |
06-07-2010, 10:34 PM | #390 |
Could be. I've been using mine in the berg mostly, 55t handwound 6s lipo and 8t pinions. Probably the low pinions hiding it for me. We will get it fixed. There are enough discrete steps in the PWM control that there is room for improvement. |
06-08-2010, 12:00 PM | #391 |
I tried resetting the endpoints again as well as 2 different radios(3PK and React) with the same results.
06-08-2010, 01:05 PM | #392 |
if it helps I was running 3 and 4s on a 21t 550 trinity motor, and a 30t handwound when I noticed it. **edit** it was also way worse in reverse. like half trigger was dead Last edited by XSRCdesign; 06-08-2010 at 01:29 PM. |
06-08-2010, 01:21 PM | #393 |
I am running 3s on a pair of 35T Warriors on a Berg and 3s and 4s on HH TMP 30T in a scaler. I have also seen with with 3s or 4s.
06-14-2010, 11:04 AM | #394 |
Just jump it! Join Date: Aug 2008 Location: Cedar City, Utah
Hey John. I purchased 2 of the BR-XL's for my super. Set them both up the same with the castle link before wiring up. Got them wired up today, one programmed easily, the other one will not beep and/or go into program mode, and it made a huge pop in my motor. It seems to have blown up something in the motor. ( I checked these motors the other day for forward/ reverse rotation/polarityand they were working fine. The one that popped will not work at all now???!!) I got some spare motors out and again the one works fine other will not beep or go into program mode. Both are wired the same. I Only had one plugged in at a time as i was trying to set up on a DX7 Stick radio. Options, Suggestions??? Last edited by rottenbelly; 06-14-2010 at 11:22 AM. |
06-14-2010, 11:58 AM | #395 |
Could be a DOA controller. I double test them all here, but sometimes you just don't know what may happen. You are more than welcome to send it in for a replacment or repair if needed.
06-14-2010, 12:02 PM | #396 | |
Sent. Tracking # 0309 1830 0001 9514 9285 Last edited by rottenbelly; 06-14-2010 at 12:46 PM. | |
06-19-2010, 06:00 PM | #397 |
I realized i didnt put any information in the package i sent back to you. But i sent back the esc that wouldn't program and was wondering if you had a chance to look at it? Thanks for any info. |
06-19-2010, 06:33 PM | #398 |
Name, initials, or something to go on?
06-19-2010, 06:52 PM | #399 |
| Justin lunceford. Senatobia, MS 38668. I was on my way out of town and just packed it up and sent it. Got to thinking about it at the comp today and realized you probably were wondering why a esc was stuffed in a box and sent to ya. Thanks for the help. |
06-21-2010, 01:19 PM | #400 |
Any update on this? Will I be able to get that esc replaced? If you need any more info let me know. Thanks again.
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/holmes-hobbies/200916-torquemaster-br-xl-big-brushed-power.html | ||||
HH TorqueMaster BR-XL new bad boy esc! | This thread | Refback | 10-04-2011 03:37 PM |
