02-02-2010, 02:50 PM | #281 |
I wanna be Dave Join Date: Oct 2008 Location: I miss Rowdy
02-02-2010, 02:54 PM | #282 |
Sometimes at least. I played hooky from school today to catch up on work.
02-02-2010, 03:17 PM | #283 |
WOW! Thanks a million John! That is customer service!!! |
02-07-2010, 01:35 AM | #284 |
I wanna be Dave Join Date: Sep 2009 Location: Nor Cal
Hey John. love the BR-XL. SUPER SMOOOTH! Waterproofing looks great too Having one issue with mine though. With Holmes Hold on, my motor is trying to go backwards and forward instead of locking in neutral. It's like motor is fighting itself. Started smoking the motor, so I turned the feature off. tried adjusting deadband to widest and it was the same. Is Holmes Hold supposed to be set at very low% ? I have my drag brake at 70%. BTW, this is not installed in my comp crawler. It's in my Honcho with Tekin 55T and DX3R Also, the instructions aren't clear on how to select options with stick programming. I'm guessing that you use the throttle or steering wheel? But how? Seems like that part of instruction was forgotten or left out. I used Castle Link, but it would be nice to know exactly how to use the stick programming function. |
02-07-2010, 09:02 AM | #285 |
Try turning down the drag % to get it to stop creeping. It seems I have some more bugs to work out on the Hold, a new firmware revision is in need. I think I need to update my instuctions on line. I could have swore I put that part in there. Full throttle is a "yes" and full reverse is a "no" answer. |
02-07-2010, 11:10 AM | #286 |
I wanna be Dave Join Date: Jan 2009 Location: laying low
this may have been asked all ready but... can the castle field programmer change the lipo cut off on the HH esc's??? thanks |
02-08-2010, 09:49 AM | #287 |
RCC Addict Join Date: Oct 2008 Location: PA
I've read that the ESC comes with 4mm bullet connectors, is there wires on the connectors or do I need my own? Thanks! |
02-11-2010, 11:02 AM | #288 | |
You will need to supply wires | |
02-14-2010, 04:20 PM | #289 |
What gauge is the battery wires on there? I plan on running 12GA Deans Wet Noodle with a 35T Handwound on 3s LiPo, 12GA sound sufficient? Thanks a million, will be buying one next weekend! |
02-25-2010, 06:58 AM | #290 |
13ga battery wire comes on them, so 12ga is certainly sufficient!
02-25-2010, 04:54 PM | #291 |
Quarry Creeper Join Date: Jun 2009 Location: Who's asking?
Hey John any idea when the new firmware might be out? I'd really like to run the Holmes hold but I don't want to risk burning up another ESC. BTW- this thing ROXs even without the hold, the low end is so very smoooth. |
02-28-2010, 03:26 PM | #292 |
Rock Crawler Join Date: Feb 2006 Location: Cutting Comms
Hey John, I just bought a new BR-XL and Im having some technical difficulties. Just sent you an email about it from b_norton@rocketmail.com.
03-04-2010, 03:28 PM | #293 |
RCC Addict Join Date: Oct 2007 Location: Kennewick, Washington
I just picked up one of these used,how does one tell if it's the waterproof version? ( I don't want to find out the hard way it's not! )
03-04-2010, 03:52 PM | #294 |
There will be epoxy around the base of the heatsink. See the photo on John's website, the picture of the ESC there is the waterproofed version.
03-06-2010, 03:35 PM | #295 |
Rock Stacker Join Date: Dec 2009 Location: midland
Just got mine a little over a week ago, and it is a great speed control! Super smooth low end on it. My only complaints are I wish I could play with the throttle curves a bit, like the sidewinder, and the case could have been cut out alot cleaner. I got the waterproof version, and it looks like they just snapped off the top half of the case. Pretty ugly looking, I was kind of dissapointed, got a brand new speed control that looks like a kid played hack away on it. I emailed John but didn't get any response about it. And the sticker was messed up like it is in the pics when I got it. Its not really a big deal, but when you buy something new it should look nice and new. |
03-06-2010, 09:31 PM | #296 |
Yep, that is the WP version! It is a bit messy of a job to encase them, and I have improved my methods a bit. I am looking for a more professional way of doing it, right now it is just me working out of the basement. I sticker them myself, and that wouldn't pass the snuff though. Maybe it shifted in shipping, I can send another if you would like.
03-07-2010, 07:57 AM | #297 | |
03-07-2010, 08:02 AM | #298 |
Must have slipped by me. I take a knife to those edges normally.
03-08-2010, 08:05 PM | #299 |
is it possible for the Torquemasters to shut down from thermal overload?? This past weekend at Midwest, I beat the hell outta my crawler on the finals course, I worked my motors harder than I've ever worked em before and I had a glitch that lasted a few seconds. I had finished gate 4 and working my way to 5 and after several attempts up a crazy vertical climb, my truck shut down. It lasted about 6 or 7 seconds, I had no throttle, no reverse, NOTHING. after a bit everything came back on and worked fine again. But then the next day messing around at another comp spot nearby, I had it happen again, but I was not being hard on it at all. Just curious if this has happened to anyone else?? |
03-16-2010, 10:38 PM | #300 |
Rock Crawler Join Date: Dec 2008 Location: Marengo, Ohio
Hey John, i see there is no single motor turn limit. But what about dual motors ? I have mine in an emaxx based 1:6 scaler right now and was wondering if i could run dual Kershaw Designs 650s motors on 2s lipo. Thanks. |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/holmes-hobbies/200916-torquemaster-br-xl-big-brushed-power.html | ||||
HH TorqueMaster BR-XL new bad boy esc! | This thread | Refback | 10-04-2011 03:37 PM |
