09-03-2011, 07:09 PM | #3001 |
Pebble Pounder Join Date: Apr 2010 Location: Olympia
I am currently running a MMP ESC and a 7 turn puller. I want to run 4 cell though. Not to worried about price I want a really powerful fast motor, what would you recommend? Its is a wraith if that makes a difference w/ a stock trans(I will be uogradeing as I break it)
09-05-2011, 11:27 PM | #3002 |
Pebble Pounder Join Date: Aug 2007 Location: Da Springs
Hello John, I would like to order a motor from you for my Wraith, but I am having a hard time with ordering it on the site. I am looking for the following. Thanks for your help. Please feel free to send a PM. TorqueMaster Pro base, torque and efficiency tuned (highest quality) 21 turn wound on 5mm web armature 10mm comm diameter Standup brushes |
09-06-2011, 08:54 AM | #3003 | |||||
I would recommend keeping all ground wires in the system, so you would have the yellow signal and the black or brown ground going into the RX from the servos. Quote:
glad to hear, thanks for letting me know! Quote:
If it is not listed in stock on the site, you can always select "custom" and we will ensure you get one built as fast as possible. Otherwise I think your motor combination looks like an awesome build! | |||||
09-07-2011, 07:28 AM | #3004 |
Quarry Creeper Join Date: Oct 2008 Location: Stink Grove
Hey John I got a xr10 did homebrew steering mod but my link is steel and is very atracted to my motor Will this cause any ill effects on the motor? Thanks |
09-07-2011, 07:30 AM | #3005 |
Nahh, don't worry about it. If anything it may slow it down just a touch, but I doubt it.
09-07-2011, 11:23 AM | #3006 |
Rock Stacker Join Date: Jan 2009 Location: firenze
| Quote: which one do you suggest to be mounted on an Emaxx for light crawlig and some bushing? 2S lipo and, if fit, your BL-XL thanks Marco |
09-07-2011, 11:47 AM | #3007 |
I did get em, we should be able to waterproof them within a few days here. I would suggest the 7t for an emaxx. If you are going to use two motors then you could get away with the 6t. |
09-07-2011, 01:04 PM | #3008 |
Rock Crawler Join Date: Jun 2010 Location: Yelm,WA
John, Please see the picture below. Yesterday I brought my 25T Torquemaster Pros to my buddies to use his Trinity motor lathe to cut my comms for the first time, when I tore the front motor apart there was a small nick in the commutator. I figured that a few passes on the lathe would remove the nick, but after a few passes it's still there, I'm worried if I keep removing material to get rid of the nick there will be no material left on the comm. so I just stopped while I was ahead. What would cause this nick in the comm? Defective comm? Hopefully this motor is not garbage material now |
09-07-2011, 01:12 PM | #3009 |
Typically that sort of pitting is caused by going too far between maintenance intervals, running negative timing, or running laydown brushes. That is a pretty nasty pit there, but if you want to get some more time from the motor you could try running it now. We wouldn't wind an armature with that defect from the factory, it would be trashed before we even spent the time on it. Looks like your buddies bit needs sharpening or the feed rate was too fast, that is a pretty rough cut. |
09-07-2011, 01:46 PM | #3010 |
09-07-2011, 06:41 PM | #3011 |
Quarry Creeper Join Date: Sep 2010 Location: Big hands, Little tools.......GRRRRR
John, I have been waiting for the Revolver S, but build time is rapidly approaching and I can't wait any more. I have a Summit trans tube scaler that I am about to re-build. I will be using it for crawling and trails and probably some G6 events. I have my eye on a Waterproof Rock Racer Combo on your site with a 21 turn motor. The plan is to run 2 3s 2200 mAh batteries in parallel for long run times, and a 62/12 or 62/14 for a spur / pinion combo. Any suggested changes or am I on the right track? Thanks in advance for the info. |
09-08-2011, 05:50 AM | #3012 | ||
09-08-2011, 09:38 AM | #3013 |
| one or two motor?, remember i want to drive with your esc...
09-08-2011, 09:55 AM | #3014 |
You should be fine with my ESC and two motors.
09-08-2011, 10:03 AM | #3015 |
09-08-2011, 01:47 PM | #3016 |
Sounds like you are on the right track to me. If you are wanting a motor that lasts longer I am going to start building Checkpoint edition motors soon. I have all the parts here, just need to update the site and wind up some arms for them.[/QUOTE] Thanks John! Looks like all I am waiting for now is your site to be updated! |
09-08-2011, 03:00 PM | #3017 | |
I still needed to make more passes on the comm in order to make a fresh surface all the way around, the sides you can not see are the ones that have a nice clean cut, it was a little out of round. | |
09-08-2011, 03:34 PM | #3018 |
Looks like a 35t from the wire size, I would cut it after every two comps or 30 ish minutes of runtime if you want peak motor life and performance. How long did you go? It is strange that that particular segment has such a deep pit but the others do not.
09-08-2011, 05:28 PM | #3019 |
Id say prob like 6 comps ( few where I broke early and didn't get to finish the day), although I did tear the motor apart several times for cleaning and lube of bearings but no comm cut. I switched to some 35 turns a while back but the ones in the pic are 25T
09-13-2011, 03:00 PM | #3020 |
Pebble Pounder Join Date: Aug 2008 Location: Wichita Falls
HH, On the Wraith, I'm looking to setup for all crawling but need some wheel speed for tougher obsticles. Comparing the crawlmaster and torque master, what is the benifits of one over the other in crawling aspect? And i'm thinking either 20t crawl or 35t torque with your br-xl esc. Also, what gearing do you recammend for that setup? |
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
