11-07-2009, 08:50 PM | #1921 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
John,,I have a CCBEC that I got from HH hooked up in my 2.2 directly to the battery then directly to the servo only with the servo control wire plugged into the Rx. I run a 2S with Deans and a Rooster Crawler which powers the Rx. The CCBEC quit working today right at the beginning of a course in a local comp. It worked fine til then,,I have checked battery voltage and the test battery has 8.2 volts. I also checked continuity from the connector to the solder pads visible through the end of the blue shrink wrap cover..it is getting power through the wires but the "POWER ON" led is not lit and there is no output voltage. I talked to a few people at the comp and no one has heard of a SMOKED CCBEC on 2S. What do you suggest? Thomas |
11-08-2009, 08:13 PM | #1922 |
Quarry Creeper Join Date: Nov 2009 Location: Hickory,NC
JRH I just want to say THANK YOU for your dedication to this support forum. I know it takes alot of your time. I really appreciate your knowledge, help, and explanation of things here. I've been reading posts here and there and have learned alot. I just wanted to say THANK YOU for your time and effort. |
11-08-2009, 08:37 PM | #1923 |
Pebble Pounder Join Date: Mar 2008 Location: Amarillo
I know it's possibly a stupid question but, I've got a guy that's wanting to sell some Holmes Hobbies 5T Puller motors on another forum, wanted to check to see if they're legit or not since I can't find anything about a 5T anywhere on the site.... also, if they are infact a legit motor, is there a reason they're not sold anymore? what're the specs on the motors as far as Kv rating and such? most importantly, being used motors, what's a reasonable price for them? |
11-09-2009, 11:09 AM | #1924 | ||||
I would say get more capacity than you think you need. You can always have a backup pack if it doesn't fit. Quote:
Yeah, I used to carry 5t motors. I don't remember the exact kv of them, but they are really fast. 2s is plenty of voltage, but they can handle 3s for very short periods of time if you want to wear them out. Depends on how heavy they are used. I see them for $60 in near new condition. | ||||
11-09-2009, 11:47 AM | #1925 | |
11-09-2009, 11:53 AM | #1926 |
Too fast for a crawler? Not in my opinion, but I run 55t on 6s in my comp rig. You could gear it down to be plenty slow on 2s.
11-09-2009, 12:40 PM | #1927 |
11-10-2009, 02:05 PM | #1928 |
Quarry Creeper Join Date: Oct 2009 Location: 707
how is the new novak 45t's wheel speed/torque on a ax10? is it worth getting? or whats a better ax10motor?????????????????
11-12-2009, 08:56 PM | #1929 |
Quarry Creeper Join Date: Oct 2008 Location: Crawlin' in NorCal!
| Brushed motor for Losi CC?
Wondering what you would suggest in your motor line up as far as brushed motors for the Losi CC. Currently I have a tekin fxr and just don't want to drop the dough on brushless. Is there any brushed motor you offer that would be a good combo for this? Thanks for any info! Quintin |
11-12-2009, 10:10 PM | #1930 |
Rock Crawler Join Date: Oct 2009 Location: SO CAL
Hey are you going to have sidewinders back in anytime soon? Your site shows none in stock...?
11-13-2009, 08:07 PM | #1931 |
Quarry Creeper Join Date: Apr 2007 Location: Harrisville, UT
Hey, Just wondering if you had an idea of when you are going to produce more torquemaster mini motors? I can't find one I like for anything!
11-13-2009, 08:22 PM | #1932 | |||
I have some more on order from the factory, now that you mention it. Should be a few weeks or so, the end of the month is a good estimate. | |||
11-13-2009, 09:50 PM | #1933 |
Okay, I just got a LCC today. What is your best recommendation in brushed and brushless motors for it (Cobalt Puller 7t) and why. What esc and why (HH-TMBR-XL OR Mamba)? Thanks
11-17-2009, 11:58 AM | #1934 |
ok, now that you have sidewinders in... ive heard mixed reviews of programming it without the link cable, is it possible without it? and do the ones you just got in come pre-programmed with the 3.19 software to have the stronger drag brake?
11-19-2009, 10:10 AM | #1935 |
RCC Addict Join Date: Feb 2008 Location: Nevada
getting a better motor for my new rig coming.....Bully kit would a 10t puller fit this rig? and is a 10t like a 45t? i have a DX3R and FXR so it needs to be brushed.......not sure if these are brushed or brushless motors thanks also running a 3s lipo and bec @6v Last edited by prusik333; 11-19-2009 at 10:22 AM. |
11-20-2009, 09:19 AM | #1936 |
Quarry Creeper Join Date: Jul 2009 Location: Derby
| torquemaster mini motor. What pinion for MRC
My Son picked up a used MRC and it has this motor in it.. Looking for a recommendation as to what pinion to use. It seems to have a ton of torque, but hardly any wheel speed. I haven't looked at the pinion yet to see what it already in there.. But I figured I'd ask the expert |
11-20-2009, 09:46 AM | #1937 | ||||
ESC, I like my TM brushed ESCs for brushed motors, and the Mamba Pro for sensored stuff. Smooth and reliable for both. Quote:
Should have a good bit of wheelspeed, a touch more than stock on 2s. What battery is he running? | ||||
11-20-2009, 11:25 AM | #1938 |
He's got a 2s Lipo from Losi. Don't know the C rating on it though.. I think he's running the stock pinion in it.. I'll check this weekend I was wondering if he needed to rebuild it.. You still have the parts for that? Thanks for the prompt reply!! |
11-20-2009, 11:29 AM | #1939 |
I have a few parts, but will be getting in more in just a few short weeks.
11-20-2009, 11:45 AM | #1940 |
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
