09-25-2012, 10:32 AM | #21 | |
Quarry Creeper Join Date: Aug 2011 Location: Sacramento
| Re: Rims with an offset... Quote:
09-25-2012, 10:42 PM | #22 |
RCC Addict Join Date: Jun 2007 Location: MESA
Don't get me wrong cause yours look sick but are bead-locks in the works at all? I personally hate the need to glue the tires to the rims. What materials are you planning to work with? Aluminum or plastics? |
09-26-2012, 07:37 AM | #23 |
RCC Addict Join Date: Jan 2011 Location: Forest Floor
Not looking at true bead-locks right now. 3D printers do plastics very well. Rigid fully functional plastic parts direct from the printer. We can make the rim with a slightly enlarged rim diameter to make a better friction fit. Currently working on easy projects. Once I have the machine I will be able to learn what is possible concerning tapped holes. It should not be an issue. But I've given up on my RC4WD rims. I mounted a set of tires on them, being very careful not to over tighten the screws, now at least 3 screws are locked in on every face. May as well be glued! lol As far as machining the hex... Looks like you just cut it with an end mill. Leaves smaller flats for the hex to fit into, but it seams to work. |
09-26-2012, 08:10 AM | #24 |
Here are some random images. |
09-26-2012, 08:12 AM | #25 |
Rock Crawler Join Date: May 2011 Location: Bama!
What size alen head do I need For the rc4wd beadlocks because .05 is to small and 1/16 is too big I even tried t4 and t5 star bits? You wouldn't happen to know would you?
09-26-2012, 08:26 AM | #26 |
It's .05" but the screws are very poor quality and you must use a high quality tool, not a worn out one. ;) Good luck is all I can say...
09-26-2012, 09:10 AM | #27 |
RCC Addict Join Date: Jan 2009 Location: Jacksonville Illinois
09-26-2012, 09:23 AM | #28 |
I bought a brand new set and was using those!!! Should I try another set or what
09-26-2012, 09:25 AM | #29 |
Your rims look awesome!!!!
09-26-2012, 12:46 PM | #30 |
Quarry Creeper Join Date: Mar 2011 Location: norcal
I like the color of the wheels in this pic. |
09-26-2012, 01:04 PM | #31 |
RCC Addict Join Date: Aug 2012 Location: Philippines
Would you call that gunmetal or bronze?
09-26-2012, 01:56 PM | #32 |
looks almost like black chrome? kinda like the bnd crawler wheels
09-26-2012, 02:16 PM | #33 |
idk if this is possible but what if you make a 2 part rim.the red(spokes) could be one part and the blue(wheel body i guess) could be another part. an advantage to this is that id be easy to put your own offset. sell just the wheel body and make multiple offsets of just the spokes |
09-27-2012, 11:36 AM | #34 |
Quarry Creeper Join Date: Apr 2011 Location: North Alabama
I am really interested in this. I have wanted a new set of rims for mine. As far as a slightly larger rim make them in the size of the sumo micro crawler. I used a set of those wheels and did the DANALLY wide mod on them. They are just slightly larger than stock mcrc wheels. I mean enough that they hold miclaws with no glue and even in hard binds.
10-01-2012, 06:00 PM | #35 |
Here are some more ideas in the works. |
10-01-2012, 06:02 PM | #36 |
Yes!
10-01-2012, 06:35 PM | #37 |
Rock Crawler Join Date: Apr 2012 Location: NewHampshire
So when are these coming out?????
10-01-2012, 07:19 PM | #38 |
Full on Micro-porn.
10-01-2012, 07:33 PM | #39 |
No idea how long it will to get set up for selling. Hoping by year end, sooner if possible. Here's some more images. |
10-01-2012, 08:58 PM | #40 |
any idea on a price?
Rims with an offset... - Similar Threads | ||||
Axial offset rims... | h8z2luze | Team Losi Comp Crawler | 7 | 08-11-2009 09:22 PM |
Most offset rims? | James Luce | Tires and Wheels | 6 | 12-12-2005 05:42 PM |
