03-28-2016, 11:20 AM | #221 |
Quarry Creeper Join Date: Jun 2013 Location: Twin Lake
| Re: RC4WDs New Micro Crawler
Looking for something with lower gearing for this thing, and wondered about a servo. Had a extra Tactic sitting around, so i decided to mod it to try that as a transmission. I took the controller board out along with the pot and pulled the pin on the final gear to let it rotate all around. I drilled a hole all the way through the final gear so i could put my homemade output on. It works good if you want to go really slow. I looked up the servo and is 0.17 for 60°, so that's around a sec for a full rotation. Thinking of getting a faster servo to try unless something else comes up first. I have around 2 hours on this mod and it is still running good. [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] |
03-28-2016, 11:39 AM | #222 |
Rock Crawler Join Date: Mar 2009 Location: Parker, CO
| Re: RC4WDs New Micro Crawler Quote: I have torn apart dozens of servos and used them for different things but I never thought of using one like that. That's awesome. I think you will like that on 3S. |
03-28-2016, 11:41 AM | #223 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
Nice. This is what many used to do before RTR micro crawlers were available using SSMT axles.
03-28-2016, 01:12 PM | #224 | |
Quarry Creeper Join Date: Jun 2014 Location: San Mateo
You are correct I was thinking of the BRXL, didn't know Tekin had a Micro! Quote:
03-28-2016, 01:20 PM | #225 |
The way I have mine now seems to be good with the Sidewinder Micro and the 2S lipo, the gearing is just not right, it moves quite quickly now, probably twice as fast as stock so it just needs to drop some top end and pickup some low end torque. I would think RC4WD just scaled down the trans in the GLII for this rig.. but who knows. Im going to try some different motors and see if I can find something that will improve the low end. IT's not a comp crawler or anything so to me I almost have it where I would like it, except for the suspension and steering, I still need to address that.
03-28-2016, 01:51 PM | #226 |
Rock Stacker Join Date: Mar 2016 Location: OK
I'd be happy if it had half the top speed and twice the torque of stock. The suspension and steering angle I can deal with.
03-28-2016, 02:28 PM | #227 | |
Edit.... Thats 3S lipo, havent tried it on 2S with the Sidewinder Micro. Quote:
03-28-2016, 05:51 PM | #228 |
| Re: RC4WDs New Micro Crawler |
03-28-2016, 06:26 PM | #229 | |
Newbie Join Date: Mar 2016 Location: Rockville
I am working on a very similar set up right now. I'm glad to see yours worked out. Seems quite torquey. Quote: | |
03-28-2016, 06:29 PM | #230 |
| Re: RC4WDs New Micro Crawler Last edited by Shape_Shifter; 03-28-2016 at 06:32 PM. |
03-29-2016, 09:34 AM | #231 |
Decided to try and get the original transmission to work even though the servo motor seems to be doing OK. Took the original motor and gutted it. Then i cut the can down and drilled a hole in the back plate for the extra shaft to come threw. I can cut more of the can down to make it shorter. I was thinking of mounting a gear to it or using it as a input shaft for a divorced setup. [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] |
03-29-2016, 09:37 AM | #232 | |
03-29-2016, 09:45 AM | #233 |
Sweet work Druxus that's exactly what I was saying seems like a good way to go for a divorced setup with a bigger motor. Are you going to mount the motor to the shaft or make a motor plate with a spur & pinion for some more reduction?
03-29-2016, 10:07 AM | #234 |
Yeah i was thinking a spur and pinion setup with a motor plate attached to the old can
03-29-2016, 12:10 PM | #235 |
| Re: RC4WDs New Micro Crawler There is nothing in the can. I am using it to support the shaft that has the original pinion gear in the transmission. It also had the right bolt pattern, thought it would be easier this way then trying to come up with a custom plate. Might be wrong but I'm gonna give it a try.
03-29-2016, 04:28 PM | #236 |
Newbie Join Date: Feb 2011 Location: new zealand
Good job, funny enough this was actually the method I tried for my first attempt at a divorced setup but decided to ditch it as I wanted to keep everything as scale as I could, no offense to your method though it is a good option and everyone can do it easy enough plus it's a good way to sacrifice that sucky little motor |
03-29-2016, 07:45 PM | #237 | |
I don't have one of these rigs so I have no idea what I'm talking about. | |
03-30-2016, 03:16 AM | #238 |
Quarry Creeper Join Date: May 2010 Location: Kaena Point, Hawaii
would you guy hurry up and figure it out so i can pay someone to fix mine lol
03-30-2016, 12:50 PM | #239 |
Newbie Join Date: Feb 2013 Location: Eastanollee
I just sent Dan my motor to see what he can do for winding and a pinion. there are replacement motors here for those of you who want to tinker. HSP 94480 1/24 Motor RC Off-road Climber/Crawler Parts 48022 - US$5.17 |
03-30-2016, 03:08 PM | #240 |
Why isnt anyone trying these types of motor? Is there just no room? http://www.ebay.com/itm/3-6V-DC-Smal...QAAOSwwPhWlnSD |
RC4WDs New Micro Crawler - Similar Threads | ||||
BWD Micro Wheel Weight System for the new Losi Micro Crawler! | billet works | Vendors Market | 19 | 10-18-2010 05:42 PM |
~Petition for RC4WDs next 1.9, 3.7" tall tire~ | STANG KILLA SS | Tires and Wheels | 105 | 02-03-2008 02:17 AM |
RC4WDs Aluminum 2.2 Hilux wheels | SuperSancho | Tires and Wheels | 5 | 04-29-2006 12:42 PM |
