01-29-2011, 11:42 PM | #201 |
Rock Crawler Join Date: Oct 2010 Location: Reno
It does sound impossible. But that is why I said attempt. Honestly what I'll be doing is hand making rip offs of the losi comp parts. I hope it doesn't look like crap or weigh a ton.
01-30-2011, 12:54 AM | #202 |
RCC Addict Join Date: May 2010 Location: Los Altos, California
hahaha, good luck with that man!
01-30-2011, 04:35 AM | #203 |
I wanna be Dave Join Date: May 2010 Location: The east coast
like any crawler we all want to try and improve them at as low a cost as possible. toyotatrucks83, given i have never gotten my hands on an MRC or see it run i'll trust your assessment. like you my son has been beating the crap out of his EMS and outside of the front axle issues it is holding up great, better than i expected. once i get a tap to do my zero ackerman mod i'm going to see how much of a turning radius improvement i get. your idea of taking off the e-clip that holds the bearing in place to get the extra 1/8" will probably help get me to the max steering possible with the stock dogbones (without pushing them to the break point). if that all works i have an idea of how to swap the knuckles and servo around to do a behind the axle (BTA) steering setup. with those changes i think i will be done with the EMS. one my son is ready to something bigger i'll invest in a different rig. |
02-02-2011, 06:34 AM | #204 |
i still need to drill and tap my aluminum knuckles to get to zero ackerman but i did make some additional changes. based on toyotatrucks83 seeing that if you remove the e-clip from the front dogbone you can push it out further into the stub axle cup i thought that would buy more steering angle without the dogbone jumping out of the cup. by taking off the e-clips and putting a small piece of rubber between the shafts inside the locker (to keep pressure on them to push into the drive cups) you can get more steering angle. after running it a little i did notice that the rubber doesn't compress enough to let the dogbones push back into the locker as they rotate, causing them to push back out against the knuckle. a minor issue that i plan to correct by putting in a small spring instead of the piece of rubber. bottom line is getting to zero ackerman and pushing the dogbones further into the stub axle cups has gained us a noticeable improvement in steering angle. this is probably the most you can do with the stock equipment but i'm pretty happy. need to get it back in my son's hands so he can beat the crap out of it! attached are some pics that i hope show the story. Last edited by jebster; 02-02-2011 at 07:44 AM. |
02-02-2011, 07:55 AM | #205 |
Jebster, it looks great. I think I will setting up my front axle just like that being swapping in Losi parts is a complete fail. Now are you using EMS knuckles or MRC knuckles? Also I noticed your new cleaner looking steering link. Very nice. |
02-02-2011, 09:15 AM | #206 |
| the plastic knuckles in the pics are the original EMS knuckles. i did by hot racing MRC aluminum knuckles which are a direct replacement for the EMS knuckle. once i get the aluminum knuckles drilled/tapped i'll swap them out with the plastic hubs. that should make the front end pretty bulletproof. still not able to steer as good as my venom creeper but it is better than stock. besides, my son doesn't notice the limited steering. and i guess at the end of the day it really is his rig! |
02-02-2011, 09:22 AM | #207 |
given the longer drag link length i couldn't use the stock plastic drag link so i had some parts laying around that i used. by the way, i forgot to mention one other minor change i made. on the rear i removed the drag link and attached the knuckles to the axle (see pic below). toyotatrucks, i do appreciate all your research into the MRC parts. it has helped alot and saved me some money. this is one of the reasons i support this site! |
02-02-2011, 09:36 AM | #208 |
Jebster, thank you for the picture of the rear. Ive been racking my brain how to get rid of the link in the rear that is not needed. Your welcome for the research on the MRC axle info. One of us was going to have to do it. You are helping me a tremendous amount, and saving me money with your info on the EMS axle build. I was going to buy some of those MRC Pro knuckles since you said the MRC knuckles are a direct bolt on. But I may pass since you are able to make the other ones work. |
02-04-2011, 11:28 PM | #209 |
Anyone have a link for the EMS aluminum C hubs?
02-04-2011, 11:37 PM | #210 |
| http://www.nitrorcx.com/51c00-680003.html Hope this is what your looking for. |
02-05-2011, 04:20 AM | #211 |
looks like the right pieces to me. it is funny how they have aluminum replacement parts for just about everything (knuckles, axle housings, c-hubs, wheel hexes, wheels, etc) but none of them address the steering limit weakness.
02-05-2011, 09:49 AM | #212 |
Newbie Join Date: Jun 2010 Location: bellingham
took a couple days to get a hold of nitrorcx, but i sent my radio off. i still need to do some mods.
02-05-2011, 09:53 AM | #213 |
It is a bummer that they are all just direct replacement parts. Oh well. Some of them are useful. Like the c-hubs. That aluminum diff may come into play if we happen to tear apart the plastic ones by pulling the axle out the extra 1/8". Hopefully not.
02-05-2011, 10:23 AM | #214 |
| i agree that the c-hubs are the most useful. the aluminum knuckles would be good but you can get hot racing ones for half the cost. i'll keep everyone posted if pulling the axles out the extra couple millimeters causes a failure. nothing so far.
02-06-2011, 03:26 PM | #215 |
Rock Stacker Join Date: Nov 2010 Location: Ned
I have also removed the c clips and used a piece of thin rubber between the shafts and have filed the knuckle to gain steering angle. I have upgraded just the motor and am having great results with out the axel popping out or binding.
02-06-2011, 06:48 PM | #216 |
| glad to here things are going well for you. i do like the rig in my current setup and my son love's driving it. i don't see any significant changes in the future (maybe a BTA steering mod?).
02-06-2011, 09:56 PM | #217 |
current pics http://www.flickr.com/photos/mrjoels...n/photostream/ http://www.flickr.com/photos/mrjoelsman/5424202060/ Last edited by joelsman; 02-06-2011 at 10:11 PM. |
02-07-2011, 11:46 PM | #218 |
Nice job Joel. I wanted to get some pictures up of my son's new toy. It is still a work in progress. Here is the idea. The garbage portion of the truck will become a trailer. Here is the truck almost done. I put a piece of board that is to big on it as a flat bed for tonight. I'll cut it down to size and paint it black tomorrow. |
02-08-2011, 04:17 AM | #219 |
that is a pretty good idea. my son loves garbage trucks and vehicles that can haul stuff around. i might think about doing this myself.
02-08-2011, 10:58 AM | #220 |
Sweet frame! Thought i would give and up date on my build. I put a cut down pen spring in my left rear shock to cut down TT. Are you 4 link guys still getting TT? I also re-soldered my Batt into a brick shape and stuffed it upfront. Also used a ancient futaba servo. I have cut down my soft springs about a 1/4 inch in the front. Grooved my tires (no gain) Heres some pics. http://i1128.photobucket.com/albums/...a/IMG_0110.jpg http://i1128.photobucket.com/albums/...a/IMG_0109.jpg http://i1128.photobucket.com/albums/...a/IMG_0106.jpg http://i1128.photobucket.com/albums/...a/IMG_0105.jpg |
