Go Back   RCCrawler Forums > Competitions and Events > Scale Comp Rules
Thread: SORCCA rules comments, suggestions, and questions
Old 01-02-2012, 12:03 AM   #1
Default SORRCA rules comments, suggestions, and questions
Thanks for all your hard work on these rules SORRCA.
Not an easy task!
Pointman is offline   Reply With Quote
Old 01-02-2012, 10:54 AM   #2
Chassis & Tubework Vendor
Default Re: 2012 SORCCA scale rules
Not an easy task!
X2
I like the changes and clarifications.
MG200 is offline   Reply With Quote
Old 01-02-2012, 07:05 PM   #3
Looks good, nice job again guys!
I like that winching was bumped up to 2 pts. Locally we're going to penalize 3 pts. just to deter folks from pulling out the winch without even trying or attempting a section/obstacle.
gdb85 is offline   Reply With Quote
Old 01-02-2012, 07:54 PM   #4
666
MODERHATER™
666's Avatar
Let the series begin!!
666 is offline   Reply With Quote
Old 01-03-2012, 09:37 AM   #5
Could I get some clarification on this one:
All vehicles should have the motor, transmission, and electronics covered and hidden when viewed from the top and sides. Batteries must be chassis mounted and should be hidden from view.
This sounds like it excludes body mounted battery boxes. I have one of the tool boxes from one of our vendors mounted in the bed of my Hilux that holds the battery. I have seen many people use ammor boxes in the beds or on flat beds for the same thing. This rule seems to say that the battery has to be seperate from the body and has to have the Battery box/battery skid/bare battery strapped on the chassis?
neillarson is offline   Reply With Quote
Old 01-03-2012, 09:41 AM   #6
666
MODERHATER™
666's Avatar
Basically what it is saying is the battery can not be mounted to the axles.
Having it hidden in the box is good!
Old 01-03-2012, 10:13 AM   #7
Thanks for the quick response, but knowing some of the sticklers for rules, could we modify that line to read:
Batteries must be chassis or body mounted and should be hidden from view.
Or am I being too anal about this?
Old 01-03-2012, 10:15 AM   #8
666
MODERHATER™
666's Avatar
Your all good.
I brought it up.
Old 01-03-2012, 10:29 AM   #9
Moderator
badhoopty's Avatar
another question, if this thread isnt appropriate i apologize.
class 2 tires - the rules just say sniping and cutting is allowed, but can they be cut and shut as long as they fit the height requirements?
badhoopty is offline   Reply With Quote
Old 01-03-2012, 10:41 AM   #10
No cut and shut in class 2.....that is for class 3 only.
War Pig is offline   Reply With Quote
Old 01-03-2012, 11:59 AM   #11
Suck it up!
Duuuuuuuude's Avatar
I know this is going to sound weird, but what is the official definition of a boat side?
Example: I want to add a plate from the bottom of the frame to the lower outer edge of the cab that will not change the cab structure, position, or dimensions. Would that be considered a boat side or a skid?
Usually when I think "boat side" I think modification to the cab/body to gain clearance, so that is why I'm asking.
Duuuuuuuude is offline   Reply With Quote
Old 01-03-2012, 12:04 PM   #12
X2 as I had my Hilux skids designed to have delrin plates between the bars and running from the cab bottom edge to the frame. No mods to the body.
Old 01-03-2012, 01:06 PM   #13
A boatsides is where you remove material from the body and replace it with a plate skid to gain clearance. We could define everything in the rules.....but I don't think anyone wants that. That's what this thread is for....question away!
Old 01-03-2012, 02:11 PM   #14
Suck it up!
Cool, that's what I thought but just wanted to be sure. Didn't want to get bumped up a class because of some skid plates.
Old 01-03-2012, 03:17 PM   #15
If you have Tuber: metal -8
Do you you still get
Tube accessories
• Sliders: (both sides) metal -3
sally1800 is offline   Reply With Quote
Old 01-03-2012, 03:22 PM   #16
Tube accessories
yes.. The only thing you cant get is the shock mounts
sloppy is offline   Reply With Quote
Old 01-03-2012, 03:42 PM   #17
Here what I came up with for some popular stocker's ?
Stock Wraith
Plastic tuber 4
Plastic sliders 1
Front bumper 1
3D 4
Lights 2
Total 12
Stock Honcho
Tube Bed 1 Honch is not a Truggy read the rules
Plastic Sliders 1
Plastic Bumper 1
Spare Mount 1
Spare 3
Total 7
(Must replace the ladder frame behind the cab with tube, and must extend past the rear axle pumpkin to be legal.
Old 01-03-2012, 04:07 PM   #18
Moderator
badhoopty's Avatar
Tube accessories
so for example would a wreckluse have sliders? would you count the horizontal tube rails that are between the body and boatsides?
Old 01-03-2012, 06:04 PM   #19
Stock Wraith
Plastic tuber 4
Plastic sliders 1
Front bumper 1 stinger -1
3D 4
Lights 2
Total 12 13
Stock Honcho
Tube Bed 1 Honch is not a Truggy read the rules roll bar hoop -1
Plastic Sliders 1
Plastic Bumper 1
Spare Mount 1
Spare 3
lights? 2
Total 7 10
If something has tube or plate that allows it to slide over something and not damage the body or panels, then we are giving points for sliders. Too many variables to get more technical than that.
Old 01-03-2012, 06:07 PM   #20
DISTURBIN' tha PEACE's Avatar
Great!
DISTURBIN' tha PEACE is offline   Reply With Quote
SORCCA rules comments, suggestions, and questions - Similar Threads
Comments, Suggestions and Questions. Rockpiledriver RCP Crawlers 755 05-01-2015 04:01 PM
2012 SORCCA rules in effect! War Pig Scale Nationals 16 03-19-2012 10:53 AM
2012 SORCCA Scale Rules War Pig Scale Comp Rules 2 01-01-2012 10:48 PM
Am I on the right track? Comments and Suggestions needed. Kingofthehill Tamiya TLT Crawlers 4 02-22-2007 12:34 AM
