02-19-2012, 10:20 AM | #201 |
RCC Addict Join Date: May 2010 Location: The heart of the south
| Re: 2012 SORCCA scale rules
No, the C3 tire size should never have been set to the largest tire that was available, since it is the Modified class, it should be set to 6" to give room for growth and changes from the manufacturers.
02-19-2012, 10:34 AM | #202 | |
Old guy Join Date: Jan 2007 Location: Northwest Arkie-saw and we got ROCKS!
| Re: 2012 SORCCA scale rules Quote:
And NO , you can't change the rules everytime a manufactor comes out with something out of the rules. I agree with that 100% . I just always felt the rule should have been 6 inch all along. RC4WD has listen to their customers and gave them what they want. It's not like they aren't going to sell any tires cause of the rule. I just thought it would be a nice tire to have in class 3. I guess a guy could take a lug out, or remeasure them and change the spec. I 'll have a set soon. I'll bet they are short of 5.8, but it's what the manufactors specs says, right. Rules are rules and I'll follow them, just something I thought the committee could talk about. I'm just 1 old guy with a opinion, don't mind me. | |
02-19-2012, 11:21 AM | #203 | ||
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
You all need to understand that even if 6" tires are legal, it doesn't mean that they look good on all Class 3 vehicles. They would look like crap on my '34D, but I would feel the need to run the biggest tires possible to be competitive. I don't want all the Class 3 rigs to look like Supers, which is the direction it's going without some rules to keep them looking like scale trucks. | ||
02-19-2012, 12:04 PM | #204 | |
I guess I might be running on my redneck coolness. You should come to the Big Meat Challenge at Disney, Oklahoma sometime and then you'll see what I'm talking about. | |
02-19-2012, 12:23 PM | #205 |
I'm building the red and white bronco at the begaining, tell me that the new tire won't fit that rig perfect. He's running 49s . 49s at 8th scale ,I would need a tire at 6.125. But I'm happy with 5.8. The 5.5 I have are just to small and make my rig look funny. Check it out. Rock Crawling Disney OK, Rainbow - YouTube http://www.youtube.com/watch?v=2ZTyk...endscreen&NR=1 http://www.youtube.com/watch?v=StUmJ...eature=related CLASS THREE BABY. Last edited by ROCKEDUP RICKY; 02-19-2012 at 12:30 PM. |
02-19-2012, 12:43 PM | #206 |
I wanna be Dave Join Date: May 2006 Location: akron
| Re: 2012 SORCCA scale rules |
02-19-2012, 03:32 PM | #207 |
02-19-2012, 05:44 PM | #208 |
RCC Addict Join Date: Nov 2006 Location: burlington
there's no reason to change the rules for this new tire. as i see it you have 6 month to were them down to spec.
02-19-2012, 06:06 PM | #209 |
02-19-2012, 06:45 PM | #210 |
but you can mod tires in C3 so manufactor spec's dont really matter.
02-19-2012, 08:10 PM | #211 | |
Tire size will be determined by advertised manufacturer specs (tires without available specs will be measured off the truck as mounted on the wheel laid flat). •Tire modification: Class-3 Modified. Tire reduction and narrowing is permitted, as well as all modifications listed above. • 146mm / 5.75" max tire size with a 2.2 max rim size (including spare). | |
02-19-2012, 08:58 PM | #212 |
so what you are saying is even if i reduce a tires it will still be out of spec because you have go by whats on the side wall. just kidding
02-19-2012, 09:00 PM | #213 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
I think what Joey is saying that wear or modified/accelerated wear would be a modification and therefor fall under the C3 mod rule,not manufacture specs. It really wouldnt be any different than cut and shut or lug trimming to acheive said hieght requirments as long as when measured, they actually meet the hieght rule. Is that where you are going with this Joey ? |
02-19-2012, 09:05 PM | #214 |
yes |
02-19-2012, 10:36 PM | #215 |
Cool, I guess if you take .025 off each lug, it will be within spec.
02-20-2012, 05:46 AM | #216 |
02-20-2012, 07:06 AM | #217 | ||||
I wanna be Dave Join Date: Dec 2008 Location: ?
I have not seen many tire match the company size on the side wall, | ||||
02-20-2012, 07:37 AM | #218 | |
"So a person shaves or reduces a tire, and then they're measured? Wouldn't you think that everyone will say they that shaved it to fit within spec? I have not seen many tires where the tire size matches the size on the sidewall." If you'd take a little time to look at what you type, it would be easier to answer your question Brian. So yes, in Class 3 where major tire modifications are legal, I suppose it would be legal to shave .025" off the OD of the tire to get it within SORCCA specs. No other tire is 5.8" OD, so you wouldn't have to do that any other tire to make it legal. You could also cut the tire down and remove one lug, that would bring it within spec as well. | |
02-20-2012, 08:27 AM | #219 | |
Problem I see is. People can make these fit without touching them being that there so close to legal size. Foam, rim width, tire wear. How easy it would be to make them fit and then rulers will have to be used. That throws the hole Company spec. size rule out the door. I do see your point that rules where made for 2012 every one or company knew of last years rules and should have made sure to fit into spec. If you change the rule to say 6in who to say some one will not make a 6.05 tire the next time or year. | |
02-20-2012, 09:17 AM | #220 |
Rock Crawler Join Date: Nov 2011 Location: Sin City
Sorry if this question has been asked before. Is the Dinky RC wraith cargo box considered a drop bed? It's pretty deep. It's got to be 1.5" or so. Or does this only apply to a pickup style drop bed.
SORCCA rules comments, suggestions, and questions - Similar Threads | ||||
Comments, Suggestions and Questions. | Rockpiledriver | RCP Crawlers | 755 | 05-01-2015 04:01 PM |
2012 SORCCA rules in effect! | War Pig | Scale Nationals | 16 | 03-19-2012 10:53 AM |
2012 SORCCA Scale Rules | War Pig | Scale Comp Rules | 2 | 01-01-2012 10:48 PM |
Am I on the right track? Comments and Suggestions needed. | Kingofthehill | Tamiya TLT Crawlers | 4 | 02-22-2007 12:34 AM |
