11-20-2012, 05:32 PM | #61 |
| Re: UGC Super Viper Bully |
11-20-2012, 05:52 PM | #62 |
| Re: UGC Super Viper Bully You and I are in the same boat. I have the Super Bullies without the funds to finance a quick build, so I live vicariously through all the other threads here in this section |
11-21-2012, 11:26 AM | #63 | |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
A super is a good project to build slow, cost aside, it is alot of fun to build the big trucks . Learning to drive them competitively usually takes longer than the build does Quote:
11-21-2012, 11:35 AM | #64 |
03-24-2013, 12:47 PM | #65 |
With ECC on the horizon and my super ticket payed for, it is time to make time to at least get this running. Delrin Cnc cut chassis to validate a few things before we commit to CF. |
03-24-2013, 07:05 PM | #66 |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
Does that one drop down in the back more than the one I have?
03-24-2013, 09:35 PM | #67 |
04-10-2013, 12:44 AM | #68 |
Clocked the front tubes since I won't have time to finish the delrin ones before ECC. For those of you familiar with the term "Hemi under glass", I bring to you Vapor under plastic The br00d Vapor can is stuffed with a slotted arm br00d Limited Edition 35t double! Time to start on the rear axle... Tic toc |
04-13-2013, 04:29 AM | #69 |
I might actually have a running Super for ECC... |
04-13-2013, 08:11 PM | #70 |
04-15-2013, 09:41 AM | #71 |
You done yet? Have a great time at ECC, wish I could make it back but I used up my vacation days for Nats. I'll be there next year. You southern boys should come up for the Northeast National Qualifier here in PA. Good Luck |
04-16-2013, 10:39 AM | #72 | |
| Re: UGC Super Viper Bully Quote:
Thanks John! I'll miss seeing ya this time. No not done :( I have been laid up sick since the last post. I went to work today and they sent me home because I "looked grey" so I'll get some work done. | |
04-18-2013, 03:38 AM | #73 |
Sick turned out to be Pneumonia... After waking up with a 102+ fever several days in a row I saw the doc yesterday. Antibiotics and respiratory steroids... A beautiful thing! I am electronics installation and shortening 3 more tires from 8" to 7.75" away from having the beast running for ECC! Then pushing Juan to get the CF ones available. This is the 1st Super I have built that will bias in front of where the lower links meet the chassis! 3 2go BRSL's! I never was happy with FXR's in my Super. Stuff I wanted to get done that just won't happen for ECC: Ti Tie Rods - will be using 8/32 all thread sheathed in 1/4 Alu Delrin tubes I will probably be putting the axles and a lot of other stuff up for sale after ECC. I'm in contract to buy a house and need to get the cash reserves up a little before closing. Only the axles from this rig though, there are certainly some SUPER plans coming! |
04-18-2013, 10:17 AM | #74 |
RCC Addict Join Date: Jan 2010 Location: Dallas
I will be real curious to see how you link up your ESC's considering how BRXL's don't program together. My mount setup is just a real shame in terms of clean and simple.
04-18-2013, 04:49 PM | #75 |
| Re: UGC Super Viper Bully The same way I did the micros in my berg. 1 power source feeds both esc's and 1 at a time plug them into ch2 for calibrating with the remote.
04-18-2013, 08:36 PM | #76 |
For some strange reason Mark Reel told me that would not work on the BRXL, and recommended using seperate connectors. I am not sure why your way of doing it would not work though. I am going to see Mark this weekend. I will ask him again.
04-19-2013, 10:28 AM | #77 |
| Re: UGC Super Viper Bully I have never had an issue with them like that....however, a simple micro deans connection on one of the leads on each ESC will solve any potential issues.
04-20-2013, 06:20 AM | #78 |
intersting. This might save me a mess of wires!
04-20-2013, 11:25 PM | #79 |
Ice Links are going to look gooooooood on this baby |
04-22-2013, 03:17 PM | #80 |
Heavier than I was hoping for, but for a 65:1 Super Bully that I have only done part of the planned machining too, I'll take sub 8 lbs. There is probably at least 4 Oz. of knuckle weight that can come out, and the battery I will use is about 2oz lighter than the one pictured. So under 7.5 lbs will be RTR. Not bad since this beast was 10.5 lbs at ECC last year Last edited by DickyT; 04-22-2013 at 03:22 PM. |
UGC Super Viper Bully - Similar Threads | ||||
UGC Viper Bully unfinnished project | henlo | RC4WD Bully | 27 | 02-16-2012 06:35 AM |
Spare parts UGC Viper Bully build | vodka child | RC4WD Bully | 57 | 11-17-2011 05:15 AM |
My UGC Viper Bully | cumminsontherocks | RC4WD Bully | 29 | 09-29-2011 06:23 AM |
UGC VIPER Bully build!!! | beidave | RC4WD Bully | 13 | 05-16-2011 12:10 AM |
UGC Viper | yeahright | Axial XR10 | 7 | 05-01-2011 09:57 PM |
