02-12-2013, 05:40 PM | #101 |
Quarry Creeper Join Date: Dec 2012 Location: Spokane Valley
| Re: Mad torque build, cheap and easy
Cut some spokes out of my rear wheels today, I'll probably do it to the front as well. I think it looks good and the wheels don't flex unless you push pretty hard. After that I went outside to screw around on my rocks and my second solar d772 servo took a crap, did the exact same thing as the last one. Guess it's time to nut up and save up to get a hitec 7980. |
02-12-2013, 06:07 PM | #102 |
RCC Addict Join Date: Apr 2009 Location: Behind the wheel
Looking good man. I like the 5 spoke wheels. Your gonna need some motors soon. |
02-12-2013, 06:14 PM | #103 |
| Re: Mad torque build, cheap and easy |
03-04-2013, 10:10 PM | #104 |
Little update, I got annoyed since I kept destroying servos so I let it sit for a while so I could do other things. But today I got another servo, (just a d772 that I'm running at 6v now, I'm seeing if it'll last since the 2 I burnt up were on 7.4) put it in and crawled for a pack and it did pretty good so I got excited about crawling again. That made me want to do some tire work so I siped the small lugs, cut off some of the side lugs and probably dropped around 10g for all 4 tires, I still need to shave the sidewalks too. Here you can see siped lugs left and unsiped right. Lugs I cut off Pile of rubber |
03-05-2013, 04:29 PM | #105 |
Went and ran a pack through it and it did fantastic. I can't believe how much siping the tires helped it climb, I was making climbs easier than I ever have before. I had also flipped my rear shocks so that probably helped too, so I went ahead and flipped my front shocks. What ended my session by stripping my aluminum servo horn after a big jump, I replaced it with a plastic one, we'll see how long that lasts lol. Here's a pic of one of the lines I made way easier than ever before, you can see all the rubber on the rock from previous attempts. |
03-05-2013, 06:56 PM | #106 |
Quarry Creeper Join Date: Aug 2011 Location: Antioch by a rock!
Nice chassis. Looks similar to mine. Nice job. Sent from my DROID BIONIC using Tapatalk 2 |
03-06-2013, 10:42 PM | #107 | |
| Re: Mad torque build, cheap and easy Quote:
So now I'm on the search for a decent cheap 55t motor. I'm looking at rc4wd motors, or something used off here. I'm being super cheap with this because, well, this is the "cheap and easy build" On another note, I broke a power wire while practicing recovering from rollovers today lol. | |
03-07-2013, 09:26 AM | #108 |
What do you guys think of fireball 55t motors? I'm thinking either 55t fireballs, 55t Holmes torquemaster sport, or ??? Any one suggestions. I like that the Holmes motors are rebuildable and I can set timing. Last edited by Nimyad; 03-07-2013 at 11:44 AM. |
03-07-2013, 03:16 PM | #109 |
The 55 fire balls are cheap. I have those in my MT. Its just how much you what spend. Bought mine on ebay $16 each Sent from my DROID BIONIC using Tapatalk 2 |
03-11-2013, 02:59 PM | #110 |
Newbie Join Date: Dec 2012 Location: spokane
You need to step it up like your uncle and cut N shut some tires!!!! Those are way small lol and just to clarify his uncle is sittin at 6.5lbs with bullys so he's only a lil chubby now.
03-11-2013, 06:41 PM | #111 |
03-13-2013, 10:22 PM | #112 |
Replaced some steel screws with aluminum screws and dropped a whopping 7g. It's something, so I'm pretty happy about it. Now I need to do some cf links/steering linkage, aluminum rod end balls, aluminum locknuts if I can find them, and more aluminum screws. Should drop a few oz.
03-14-2013, 10:34 AM | #113 |
Who else thinks a carbon fiber tierod would fray and get chewed up real easy? It needs to be sleeved...
03-21-2013, 04:46 PM | #114 |
So I ordered up some 40 series wheels, should be here by the end of the month then I'll cut and shut my tires. I'm still torn on what motors to get though, I'm really leaning towards the hh torque master sport 55t, but I'm just not sure. Guess I'll wait to see what pops up in the classifieds and go from there.
03-29-2013, 07:17 PM | #115 |
Little update, actually pretty substantial. Got my 40 series wheels and narrowed them up, 1.6oz a wheel so I won't gain much weight switching to 40 series. I also filled my front case with all berg gears (thank you Erik!) and dropped 20g over mt gears. Case with berg gears My narrowed wheels My uncles super bully Last edited by Nimyad; 03-29-2013 at 07:20 PM. |
04-03-2013, 08:11 PM | #116 |
So that picture with the gearbox was with a mt 4th gear, I added a berg 4th and it dropped 8g so the my gearbox with all berg gears weighs 100g. I went for a crawling session today, lasted about 45 min. I bent a rear link and a tire fell off cause the hex loosened up. So now I get to decide if I want to step up to 3/16 titanium or not. Only place I got pics was right here, this is also where I bent my link. |
04-03-2013, 11:59 PM | #117 |
HMMMMM I know a guy that has some 3/16 titanium he's not using Mow my lawn and its yours |
04-04-2013, 10:15 PM | #118 |
Quarry Creeper Join Date: Feb 2012 Location: Verdi, Nevada
sweet build! You boys up north have some gettin after it I DIG IT!!!
04-04-2013, 11:21 PM | #119 |
04-05-2013, 12:00 AM | #120 |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/superclass-crawlers/418316-mad-torque-build-cheap-easy.html | ||||
R.I.P Bobby Long | This thread | Refback | 02-27-2013 08:47 PM | |
Lets see your rc crawlers | This thread | Refback | 02-23-2013 10:36 AM |
Mad torque build, cheap and easy - Similar Threads | ||||
Exceed Mad Torque - Extensive Review and build thread | monkeyracer | Superclass Crawlers | 96 | 06-25-2016 07:55 AM |
Exceed Mad Torque Super Build | motoj550 | Superclass Crawlers | 38 | 10-22-2013 05:13 PM |
Exceed mad torque Build | dannymac | Superclass Crawlers | 17 | 01-30-2013 07:17 PM |
New To RC, Exceed Mad Torque Build | woodsracer | Superclass Crawlers | 17 | 11-08-2012 11:49 PM |
Brat Build(easy,cheap)(new rear bumper!!) | rebel35747 | Axial SCX-10 | 41 | 03-12-2012 01:01 PM |
