06-26-2012, 08:36 AM | #21 |
RCC Addict Join Date: Jun 2005 Location: St. Albans
| Re: losikid's anorexic 2012-2013 comp rig
What's the weight savings on the chassis from just swapping to the CF?
06-26-2012, 02:14 PM | #22 | |
| Re: losikid's anorexic 2012-2013 comp rig Quote:
I do know one thing though, never try and self tap delrin with aluminum button heads... | |
06-26-2012, 02:20 PM | #23 |
| Re: losikid's anorexic 2012-2013 comp rig Yeah, that never ends up working out well, does it?
06-26-2012, 08:14 PM | #24 |
There is no screw worse than the 4-40 button head! I did all mine in cap head screws since I hated them so badly.
06-26-2012, 08:50 PM | #25 |
Defy Gravity Join Date: Nov 2009 Location: wells, mn
| Re: losikid's anorexic 2012-2013 comp rig i coulda told ya that one, just tried the same thing a couple days ago and as far as weight savings going to carbon, you're really gaining. i weighed my chassis a while back when i put it together. chassis, aluminum hardware, no servo or trans was right around 3oz, the thickness decrease and the lighter material ought to make this thing stable as all get out. i still can't tell you how it will react being made of cf, i'm interested in your findings on it.
06-26-2012, 09:40 PM | #26 |
So, the cf topper is about 50% lighter than the delrin topper...the delrin chassis and topper weights 58 grams so the cf topper and chassis probably weighs 29 grams...so i'm saving about an 1oz of weight
06-26-2012, 09:41 PM | #27 |
| Re: losikid's anorexic 2012-2013 comp rig Yea i hate the things...i may swap out to flat heads and flat head washers...they have alot deeper hex. I'm really afraid to use alum button heads now |
06-27-2012, 12:17 AM | #28 |
So no new news today, probably won't have any tomorrow as i have alot of stuff to get caught up on....hopefully i can get this thing assembled by friday, and get it wired and painted up next week. I'm hoping the bully axle conversion plays nice... |
07-02-2012, 06:51 PM | #29 |
i did a rough weigh in with all the misc stuff i have. Sub 5 lbs rtr. I think sub 4 might be possible. if i get crazy with gram pinching and holmes gets the outrunners. I am totally going to make this thing sub 4 if i can. I know a solid 4 oz can be pulled out of the chassis as the stubby outrunner is 3 oz lighter than my tekin and hacking away unwanted delrin and doing alum tranny hardware should add up to atleast an oz.
07-02-2012, 07:23 PM | #30 |
Quarry Creeper Join Date: Oct 2011 Location: Shirley
not to throw the thread off topic but whats the major difference between inrunner and outrunner motors? and benefits
07-02-2012, 08:29 PM | #31 | |
out runners also have alot more rotational inertia, so they can maintain the power easier once they are going...kinda like what a flywheel does on a engine. This can lead to shrapnel though as the drivetrain takes a harder blow on sudden binds | |
07-04-2012, 10:16 PM | #32 |
Here's a picture of my shaft(s) V2(left), V3(middle), Super Bully(right) |
07-05-2012, 01:38 PM | #33 |
Also, not only will the bully shafts make my front axle bullet proof, i also gain afew degrees in steering
07-05-2012, 09:35 PM | #34 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
You forgot to mention the other really cool thing! They are wider!!!!! |
07-05-2012, 10:32 PM | #35 |
| Re: losikid's anorexic 2012-2013 comp rig The coolness of the width is cancelled out by the scrub it brings with it...basically the same thing you would get with really wide hubs...right now, i took 5/16" of hub spacing off each side compared to my losi setup...i'll still be wider than stock.
07-05-2012, 10:43 PM | #36 |
There should not be any more scrub than your losi had if you run your car at the same width. If you run your car wider, then yes but that would have been the same with the Losi. At the least you dont have to run giant hubs with spacers anymore. |
07-05-2012, 11:05 PM | #37 |
| Re: losikid's anorexic 2012-2013 comp rig What i meant is that the bully's won't give anymore width without more scrub. The c's/pivot point would have to be moved out...
07-05-2012, 11:23 PM | #38 |
Gotcha. I still see a serious benefit in not having to run bigger hubs/spacers. Wider tubes would be ideal though. |
07-06-2012, 11:01 AM | #39 |
Well shoot, I was hoping for the wider width without as much scrub, but it would be nice to not run wideners anymore! Would an xr axle provide a wider pivot point? Last edited by Tgreer; 07-06-2012 at 11:04 AM. |
07-06-2012, 11:59 AM | #40 |
Bottom line, you need to move the C hub out. It has nothing to do with the axles or the knuckles.
losikid's anorexic 2012-2013 comp rig - Similar Threads | ||||
2012 Comp Rig build done XR/Mantis | mgauger | Axial XR10 | 50 | 04-17-2012 07:22 AM |
SCRCC Comp 2012 Series Comp #5 @ Falls Park March 4th, 2012 | ittybitty | Competitions | 133 | 03-14-2012 09:32 AM |
My 2012 1.9 comp rig | mgauger | Losi Mini-Rock Crawler | 8 | 01-10-2012 06:09 AM |
2012 Poison Dart comp rig | poncho_ponch | Axial AX-10 Scorpion | 14 | 01-07-2012 01:07 PM |
losikid's losi comp crawler | losikid | Team Losi Comp Crawler | 136 | 09-03-2011 09:40 PM |
