08-20-2012, 10:26 PM | #81 |
| Re: losikid's anorexic 2012-2013 comp rig Yea, when i start gram pinching again i'll defiantly shave the side walls., but for now i'm just gonna get it wired up and tinker with geometry.
08-23-2012, 11:26 AM | #82 |
So, figured i'd get afew more pics i missed before.
09-08-2012, 11:51 PM | #83 |
Just got a HH sensored outrunner mounted up, along with all my other elces....all thats left is to solder everything together...oh and body panels and such.
09-12-2012, 02:08 AM | #84 |
Quarry Creeper Join Date: Apr 2007 Location: Northern PA where the rocks grow wild
| Re: losikid's anorexic 2012-2013 comp rig Very nice, I'm diggin the super bully knuckles & XVD's. Can ya tell me exactly what parts I need to buy to do this? Obviously the Bully Knuckles & XVD's but did ya have to trim or machine the XVD's? Or do ya gotta use 2 short sides?
09-12-2012, 02:14 AM | #85 | |
| Re: losikid's anorexic 2012-2013 comp rig Quote:
You have to have aluminum LCC C's, way too much material is taken off to be structurally sound with plastic. You'll also need some steel threaded inserts | |
09-12-2012, 10:51 AM | #86 | |
That's what I figured ya did, but wanted to double check & make sure. I will definately get ahold of D-Lux for the knuckles. That is a killer steering mod. Thanks for the info & outta the box thinkin. | |
09-12-2012, 01:41 PM | #87 |
Rock Crawler Join Date: Oct 2009 Location: Knoxville
| Re: losikid's anorexic 2012-2013 comp rig Ohhhh, didn't know they were out yet. That is what I want to see pix of. Awaiting your thoughts!!!!! Edit: They are not out yet.....what the.....I sense some trickery going on! Still want to hear about it though. Last edited by dentonmac; 09-12-2012 at 01:45 PM. |
09-12-2012, 04:14 PM | #88 |
| Re: losikid's anorexic 2012-2013 comp rig |
09-12-2012, 04:15 PM | #89 |
Its not a stubby though, just the regular sized one...and 8 mag
09-13-2012, 07:06 AM | #90 |
| Re: losikid's anorexic 2012-2013 comp rig Looking at JRHs and EePees videos of the 8 mag in their Wraith and LCC, it is pretty dang impressive. I can't imagine how the 14 mag could be that much smoother, but.....we'll see. Just curious, why do you want the stubby over the regular 540 size? Weight? Fit? Still very interested to her your impressions. I am looking hard core a these. |
09-14-2012, 12:57 AM | #91 | |
Rock Crawler Join Date: Jan 2008 Location: NORWAY
09-14-2012, 07:17 AM | #92 |
| Re: losikid's anorexic 2012-2013 comp rig My bad, dude, I spelled it wrong. Its Eeepee. Here is the link. Sensored Outrunner motors- Revolver S |
09-17-2012, 01:41 PM | #93 |
So, the cap for my rs show'd up last week, and started to get everything wired up this weekend and realized i ordered the wrong plugs for the micro rx i'm going to use ...so, no new news, hopefully next weekend i can get it finished up. As all i have left is shorten all my battery cables, put on micro servo connectors on the leads, and wire in the frsky module into my gt3c
09-17-2012, 02:10 PM | #94 | |
What did you get? Is it able to run 4s? | |
09-17-2012, 03:35 PM | #95 |
Same as stock 330uf 16v i think....3s max
09-17-2012, 04:54 PM | #96 |
Thanks! Do you think that the ones used to make the FXR able to run 4s, will do the same for the RS. Or am I just asking too much of it. Thanks in advance. |
09-17-2012, 05:05 PM | #97 |
09-17-2012, 05:12 PM | #98 | |
09-17-2012, 08:30 PM | #99 |
| Re: losikid's anorexic 2012-2013 comp rig Thanks guys!
09-21-2012, 01:19 AM | #100 |
All i am lacking right now is a place to solder where i don't need to worry about the smoke alarm above my head. I'm going to try and find a spot somewhere this weekend where i can solder deans onto all my lipo packs and solder up my esc...everything else is done i think. A few things need to be tweaked but that can happen later down the road. I think i'll get some bad ass poser pics before getting any rock rash on it though, spent way to much money on new pretty plastic for no good pics I am highly considering dropping all the additional knuckle weight i bolted on though, the rear end is too light and it doesn't stay planted if the front tire drops into a hole. Plus, its easy weight to lose Also, for those wondering, at full shock extension, my belly clearance is 3.25" and it follows that all the way through my rear links to the tires. |
losikid's anorexic 2012-2013 comp rig - Similar Threads | ||||
2012 Comp Rig build done XR/Mantis | mgauger | Axial XR10 | 50 | 04-17-2012 07:22 AM |
SCRCC Comp 2012 Series Comp #5 @ Falls Park March 4th, 2012 | ittybitty | Competitions | 133 | 03-14-2012 09:32 AM |
My 2012 1.9 comp rig | mgauger | Losi Mini-Rock Crawler | 8 | 01-10-2012 06:09 AM |
2012 Poison Dart comp rig | poncho_ponch | Axial AX-10 Scorpion | 14 | 01-07-2012 01:07 PM |
losikid's losi comp crawler | losikid | Team Losi Comp Crawler | 136 | 09-03-2011 09:40 PM |
