08-14-2012, 11:12 PM | #61 |
| Re: losikid's anorexic 2012-2013 comp rig
Here's the ground down parts...I was in a hurry so i only snapped afew. When i do the sporty build i'll do a beter write up on the bully conversion Other than looking at the pics, here's tips The big sanding drums for dremels are the perfect dia. for inside the C. It'll burn afew up, but just zip it on through inside the c's. On bully knuckles, you'll see where it stops the outside curvature with a noticeable "line". Take a cutoff wheel and cut it off perpendicular to the Ears for the C Then mount the knuckles and mark the center of the axle/C ear on the knuckle (both sides), then mark the edges of the ear (bottom of the fillet/round). Take a cut off wheel. Cut about 3/16 to 1/4" in on the center, then 1/8" in on the edges. Then afew cuts inbetween. peel off the left over bits then clean it up with a endmill type cutter or sanding wheel. Then its just alot of guess and check |
08-14-2012, 11:20 PM | #62 |
Here it is as a roller. Its missing the rs, rx, bec, and the battery. Comes in at 4lb 8oz....it need to figure out how to loose 8+ oz Its gonna be extremely stable too. |
08-14-2012, 11:23 PM | #63 |
| Re: losikid's anorexic 2012-2013 comp rig |
08-14-2012, 11:35 PM | #64 |
Defy Gravity Join Date: Nov 2009 Location: wells, mn
sounds right, you and i have the same track, but you did a lot of scrub killing there.
08-15-2012, 12:29 AM | #65 |
RCC Addict Join Date: Dec 2011 Location: Australia Queensland!
Very cool dude |
08-15-2012, 02:10 AM | #66 |
I just measured the belly, its at 3"...looks like more. Hopefully it'll do well on the break overs This is with traxxas 2660 big bores |
08-15-2012, 06:56 AM | #67 |
Rock Crawler Join Date: Oct 2009 Location: Knoxville
Looking good, thanks for the pictures.
08-15-2012, 12:29 PM | #68 | |
Car looks really cool/great! Do you have an overhead shot of the steering at full lock? I guess I should have told you from the start, but I do offer the knuckles milled out. I bet your steering is going to feel a lot better with those knuckles having a longer arm than the LCC knuckle. Quote:
He will have the same amount of scrub with this setup at 10.5" wide as he would with a stock setup at 10.5" wide. | |
08-15-2012, 12:46 PM | #69 | |
| Re: losikid's anorexic 2012-2013 comp rig Quote:
No i didn't get an overhead shot of steering...forgot. It turns right to where my tires touch the links. So not much more. I'll probablly hack on steering components again in the future to max out the xvd's. x2 on the scrub.... | |
08-15-2012, 12:47 PM | #70 |
Check out the body lean form the motor |
08-15-2012, 01:06 PM | #71 |
i stand corrected on that
08-15-2012, 01:12 PM | #72 |
Quarry Creeper Join Date: Oct 2011 Location: Waterford
Shave down those khaos tires. The side walls are pretty thick and you can lose a little more. Sent from my MB855 using Xparent Blue Tapatalk 2 |
08-15-2012, 02:20 PM | #73 |
Pebble Pounder Join Date: Sep 2011 Location: Albuquerque
Id be interested in a side by side shot of the steering compared to stock.
08-15-2012, 02:55 PM | #74 |
08-15-2012, 03:16 PM | #75 |
Angle grinder? If not, you need one.
08-15-2012, 03:46 PM | #76 |
i tried my 4"x48" belt sander for shaving the sidewalls....didn't work out near as well as some quality time with the dremel. 1/2" sanding drum did great on my sedonas, a lot more control than the belt.
08-15-2012, 04:24 PM | #77 |
08-16-2012, 03:19 AM | #78 |
What size shocks are you running? Pat. |
08-16-2012, 11:21 PM | #79 |
3.5"
08-17-2012, 11:56 AM | #80 |
| Well you have to have friends on here willing to do you a favor. Or you could give yourself carpaltunnel and sand by hand :what: You will save a ton of weight though it might put you to your goal Sent from my MB855 using Xparent Blue Tapatalk 2 |
losikid's anorexic 2012-2013 comp rig - Similar Threads | ||||
2012 Comp Rig build done XR/Mantis | mgauger | Axial XR10 | 50 | 04-17-2012 07:22 AM |
SCRCC Comp 2012 Series Comp #5 @ Falls Park March 4th, 2012 | ittybitty | Competitions | 133 | 03-14-2012 09:32 AM |
My 2012 1.9 comp rig | mgauger | Losi Mini-Rock Crawler | 8 | 01-10-2012 06:09 AM |
2012 Poison Dart comp rig | poncho_ponch | Axial AX-10 Scorpion | 14 | 01-07-2012 01:07 PM |
losikid's losi comp crawler | losikid | Team Losi Comp Crawler | 136 | 09-03-2011 09:40 PM |
