07-06-2012, 01:13 PM | #41 |
| Re: losikid's anorexic 2012-2013 comp rig |
07-06-2012, 01:18 PM | #42 |
Defy Gravity Join Date: Nov 2009 Location: wells, mn
the sds builder's kits really do start looking attractive for that.
07-06-2012, 05:08 PM | #43 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
07-06-2012, 07:23 PM | #44 | |
| Re: losikid's anorexic 2012-2013 comp rig Quote:
I must have missed it. The super shafts are long enough... | |
07-13-2012, 03:08 PM | #45 |
I need to clean up the work area abit, but i'm aiming to get the bully conversion done this weekend (I finally got some new cutting bits and fiber wheels for the dremel), hopefully have it driving in the next week...
07-14-2012, 11:35 PM | #46 |
Well with lack of a 10-32 tap that works with a damn (or i may just be a bad operator ), my front axle is put on hold till i can get a good tap. So i got my rear axle linked up and my topper mounted. I'm going to attempt getting body panels done this weekend instead of an axle.
07-15-2012, 02:37 PM | #47 |
I'm considering doing clear body panels and a black delrin roof panel. Why hide the transmission |
07-15-2012, 02:56 PM | #48 |
show that baby off! interested in how you do your panels, i gave up after about an hour |
07-15-2012, 06:04 PM | #49 |
Pebble Pounder Join Date: Sep 2011 Location: Albuquerque
Thought I was the only one doing clear panels. Tho my chassis isnt as cool
07-23-2012, 12:12 AM | #50 | |
Maybe now with a feather weight motor i don't have to worry about off camber situations when my motor is down hill | |
07-23-2012, 12:05 PM | #51 |
Rock Crawler Join Date: Oct 2009 Location: Knoxville
Just thinking out loud. Not an attempt to derail, or thwart your thread. I am speaking as someone still learning and trying to wrap my brain around all this. Also, I have never driven a rig that was super light weight, so I am speaking purely theoretically. What is the wide reaching allure of going with featherweight rigs? I do understand that removing weight in some places is better. Example: wheels - lower rotating mass, better run times, less stress on driveline, and on and on. Most of that can be taken care of with knuckle weights. But there are components that HAVE to weigh a certain amount. Example; tranny (with dig servo), there is only so much that you can take out to make it lighter. It cannot be anywhere but (up high) as spring weight on the chassis (and the chassis...only so much, though your Phoenix is pretty amazingly light as it is). So the weight loss has to come from somewhere else…only place to pull from is down low. Wheels, wheel weights, knuckle weights, links. To me (note: not saying much) that would effectively raise your center of gravity. Am I looking at this wrong? I know my beloved LCCs needs to lose some weight, but I am very impressed with how it is driving now. So it is hard for me to justify tearing into them (and the downtime). I really appreciate the life and innovation that you and Pete continue to breathe into the LCC platform. Please keep it up. Oh and I love your OKRC avatar. Very cool! Last edited by dentonmac; 07-23-2012 at 12:10 PM. |
07-23-2012, 01:26 PM | #52 | |
I'm not ultra worried about axle weights, i'm going from v3 shafts to bully shafts which probably will weight at least twice the amount of v3 shafts. Getting the chassis as light as possible will give me insane stability, and keep amazing ground clearance. All in a shafty | |
07-23-2012, 03:10 PM | #53 |
Thank you...truly amazing. Very interested to see how it turns out. And your impressions how it compares. Thanks again. |
07-26-2012, 10:30 PM | #54 |
So i got 2 C's and 1 knuckle shaved to work together...now one more knuckle and i can start cutting down bully shafts to length. I'll post up pics of everything shaved down, and tips i figured out once i'm done....then i'll put down a coat of paint to get rid the ragged dremel marks. I'n decided if i want to make my knuckles and C's black or add some pop and make em red. |
08-04-2012, 07:48 PM | #55 |
Very interested, I am going to breathe some life back into my LCC as a sportsman for next season. Keep up the great work! |
08-06-2012, 07:29 PM | #56 |
Hopefully artr tomorrow, probably won't be running till i get the new holmes outrunner
08-13-2012, 11:54 AM | #57 |
Any updates?? switched the LCC over to a sportsman and am loving it. Still looking for a LNC tranz. I don't need the LCC tranz any more.
08-13-2012, 08:19 PM | #58 |
No...got busy again.
08-14-2012, 06:25 PM | #59 |
Just got done grinding everything...alot of dremel work needs to be done. I'll have pictures up here later tonight before i paint everything.... It is a turning beast though. I ground my c's and knuckles down almost as much as they can, and it still bottoms out on those before the axles. . It looks like tires will get into my links pretty bad. I may grind em down farther later down the road if i space out the tires more or think i can shove more tire into the link. Its at 10.5" wide right now (outside of tire to outside of tire). Whats stock losi width? |
08-14-2012, 08:13 PM | #60 |
on ax offset wheels, that's my current track width, so about a 1/4" less per side to stock losi wheels.
losikid's anorexic 2012-2013 comp rig - Similar Threads | ||||
2012 Comp Rig build done XR/Mantis | mgauger | Axial XR10 | 50 | 04-17-2012 07:22 AM |
SCRCC Comp 2012 Series Comp #5 @ Falls Park March 4th, 2012 | ittybitty | Competitions | 133 | 03-14-2012 09:32 AM |
My 2012 1.9 comp rig | mgauger | Losi Mini-Rock Crawler | 8 | 01-10-2012 06:09 AM |
2012 Poison Dart comp rig | poncho_ponch | Axial AX-10 Scorpion | 14 | 01-07-2012 01:07 PM |
losikid's losi comp crawler | losikid | Team Losi Comp Crawler | 136 | 09-03-2011 09:40 PM |
