08-09-2018, 07:41 PM | #401 |
I wanna be Dave Join Date: Apr 2012 Location: Merrill, WI
| Re: Ascender Build
Mounted and ready to weather. Sent from my ZTE A2017U using Tapatalk |
08-10-2018, 03:02 PM | #402 |
| Re: Ascender Build
So I have been trying to find a dually rear wheel set even if its not beadlock but I just can't find one. I am trying to find something that holds the stock width but no luck with that in 1.7 or 1.9. I really don't want to run a 1.55 as the stock wheels are supposed to be 19.5" for a truck wheel. I might just say no dually and pick up a set of RC4WD hummer wheels or just use the ones I have that look more so like half ton 50's wheels. My other option is to design my own wheels when I get the 3d printer? I guess time will tell.
08-10-2018, 05:22 PM | #403 |
RCC Addict Join Date: Feb 2016 Location: Princeton, North Carolina, USA
| Re: Ascender Build
Here's an idea so stupid if you tell anyone I even bothered to share it I'll deny it emphatically, but what the hell... What if you took two relatively short, narrow 1.9 scaley tires...93mm MSTs say, and narrow wheels, and mounted one with a regular flat nut, not a convex lock nut (which I don't have so imagine)... Then, you tapped a short rod (Axial strut for example) to your stub shaft thread (M4, M5?) and mounted it to the stub shaft...shown mounted to the second wheel/tire here... Then you mounted said second tire to the outer end of the mounted rod/strut with a screw (M3 here for effect)... Then you'd wind up with this... Stupid, right? Yeah, I thought so too. Forget I said anything. Last edited by 2mtech; 08-10-2018 at 05:29 PM. |
08-10-2018, 05:30 PM | #404 | |
| Re: Ascender Build Quote:
Sent from my ZTE A2017U using Tapatalk | |
08-10-2018, 05:34 PM | #405 |
| Re: Ascender Build
Looking forward to seeing what you work out. I'd suggest using the same size tires for the dually sets, which I just noticed I didn't. You could just get the King Kong wheels & tires...they're 1.7's and not too pricey. Probably wouldn't use the tires... https://www.asiatees.com/display?Kin...d=149795&pid=1 Last edited by 2mtech; 08-10-2018 at 05:43 PM. |
08-11-2018, 07:39 AM | #406 |
| Re: Ascender Build
Starting to look like I want it. Don't mind the gangsta lean, it Only has tires on one side. Sent from my ZTE A2017U using Tapatalk |
08-12-2018, 09:22 AM | #407 |
| Re: Ascender Build
Truck on hold while a work on my little side project. Sent from my ZTE A2017U using Tapatalk |
08-13-2018, 02:28 PM | #408 | |
Looks like the end will justify the diversion. Last edited by 2mtech; 08-13-2018 at 02:39 PM. Reason: words | |
08-13-2018, 02:34 PM | #409 | |
I used to design and build automated industrial equipment so building this 3d printer is quite fun! Sent from my ZTE A2017U using Tapatalk | |
08-13-2018, 02:41 PM | #410 |
| Re: Ascender Build Ambitious, to be sure. Going to start with dually wheels or simpler?
08-13-2018, 02:43 PM | #411 |
| Re: Ascender Build |
08-13-2018, 03:48 PM | #412 |
| Re: Ascender Build
Coupling nuts will accomplish dual rear wheels the way 2mtech suggested. Nice 3d printer! |
08-13-2018, 04:46 PM | #413 |
| Re: Ascender Build
I was thinking about doing something similar to this. https://youtu.be/gtILWYA1wLI/ Sent from my ZTE A2017U using Tapatalk |
08-13-2018, 04:55 PM | #414 |
| Re: Ascender Build
I like that better. Makes the duals sit the axle without sticking out, like tubbing it.
08-13-2018, 05:05 PM | #415 |
08-13-2018, 05:14 PM | #416 |
08-19-2018, 05:38 PM | #417 |
| Re: Ascender Build
Well turns out I have a bad axis controller on my X axis so I played with the trucks a little. Sent from my ZTE A2017U using Tapatalk |
08-19-2018, 05:45 PM | #418 |
08-19-2018, 05:46 PM | #419 |
| Re: Ascender Build
My kitties don't like my new friend so he's my new helper Sent from my ZTE A2017U using Tapatalk |
08-20-2018, 06:26 AM | #420 |
| Re: Ascender Build
Wheels are starting to look like I want. Need to dull them up a little yet and maybe a little more rust. Sent from my ZTE A2017U using Tapatalk |
Ascender Builds - Similar Threads | ||||
New build ascender | jmarsh1976 | Vaterra Ascender | 32 | 01-05-2016 01:14 PM |
Ascender build | Markeje | Vaterra Ascender | 13 | 09-24-2015 09:08 AM |
Ascender Build | seth556 | Vaterra Ascender | 12 | 01-05-2015 03:13 AM |
My Ascender Build | wax | Vaterra Ascender | 1 | 10-22-2014 05:38 PM |
