05-02-2018, 10:37 AM | #141 |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
| Re: Ascender Build |
05-02-2018, 10:44 AM | #142 | |
I wanna be Dave Join Date: Apr 2012 Location: Merrill, WI
| Re: Ascender Build Quote:
I might even put it in opened at the crotch cooler position! Sent from my ZTE A2017U using Tapatalk | |
05-02-2018, 01:06 PM | #143 |
I wanna be Dave Join Date: Dec 2016 Location: san diego
| Re: Ascender Build
'atta boy!!
05-02-2018, 06:32 PM | #144 |
| Re: Ascender Build
Problem corrected Sent from my ZTE A2017U using Tapatalk |
05-02-2018, 06:39 PM | #145 |
05-02-2018, 06:44 PM | #146 |
| Re: Ascender Build
Feeling nice and cool. I cut it out and then cut another piece for the wing then glued it on. I'm going to have to clean it up a little but it's on there Sent from my ZTE A2017U using Tapatalk |
05-02-2018, 06:47 PM | #147 |
| Re: Ascender Build Sounds easy enough. Is that a line of paint on the edge of the wing? I can’t tell, but it looks like the vertical support piece is represented
05-02-2018, 06:56 PM | #148 | |
05-02-2018, 07:03 PM | #149 |
05-04-2018, 03:20 PM | #150 |
| Re: Ascender Build
So due to the conundrum I find myself in my plan has changed. My son took my Ascender away from me and I had already acquired a body but he doesn't like it. So now I might put the f100 body on the shelf and build the bronco for myself. Decisions decisions. Sent from my ZTE A2017U using Tapatalk |
05-04-2018, 06:04 PM | #151 |
| Re: Ascender Build
Well the body wasn't what I expected but I can fix it I think. Sent from my ZTE A2017U using Tapatalk |
05-06-2018, 06:57 AM | #152 |
| Re: Ascender Build
So I set my wb at wb4 and I'm getting binding between the pan hard and the servo horn. Evidently it doesn't like the big aluminum servo horn. I guess the only option is to lengthen the rear and shorten the front links to pull it back. From what I can tell I have it set up correctly. Sent from my ZTE A2017U using Tapatalk |
05-06-2018, 07:57 AM | #153 |
| Re: Ascender Build
Starting to come together. Sent from my ZTE A2017U using Tapatalk |
05-06-2018, 10:23 AM | #154 |
| Re: Ascender Build
Getting closer on the fitment. I have the wb at exactly 12.3. I'm off a little bit but the mounts are almost identical to the body holes. I have everything set up to run a 3 link rear but I need to fab the mount for the frame. Sent from my ZTE A2017U using Tapatalk |
05-06-2018, 11:38 AM | #155 |
| Re: Ascender Build
Too bad your body is a little warped or something, but it looks awesome on your Ascender , wheels work with the looks too! WB1 and WB2 works with large clamp on Servo horn at least when servo is mounted on top of mounts, otherwise not much room and non-clamping horn is required. I’ve had good luck with Hudy reverse offset machined aluminum horns.
05-06-2018, 01:27 PM | #156 | |
Topless? Sent from my ZTE A2017U using Tapatalk | |
05-06-2018, 03:46 PM | #157 |
| Re: Ascender Build
Sons almost got his kit done! Sent from my ZTE A2017U using Tapatalk |
05-06-2018, 07:08 PM | #158 |
| Re: Ascender Build
Got more closer to the ideal set up. A little tweaking and I used the k5 rear mount to mount the body. I had to make a modification to the front body posts to move the body back a little bit. Now I have to finish buffing out the scratches. Sent from my ZTE A2017U using Tapatalk Last edited by mgputer; 05-06-2018 at 07:10 PM. |
05-06-2018, 10:02 PM | #159 |
| Re: Ascender Build
Busy weekend, i missed a lot of progress! Window wings look great!!! Bonus points for actually opening them! Bronco is looking nice too! Dont worry about scratches, i make fun of pristine trucks ;) Oh and for the servo, not sure if its still a prob, but maybe turn it sideways? |
05-07-2018, 07:22 AM | #160 | |
| Re: Ascender Build
I got the servo problem figured out. Now that I got the body my son might run it. He says it's way cooler than he thought. We had a busy weekend so I didn't get a lot accomplished. Im not worried about the scratches but some were bad. It's pretty good now. Quote:
Ascender Builds - Similar Threads | ||||
New build ascender | jmarsh1976 | Vaterra Ascender | 32 | 01-05-2016 01:14 PM |
Ascender build | Markeje | Vaterra Ascender | 13 | 09-24-2015 09:08 AM |
Ascender Build | seth556 | Vaterra Ascender | 12 | 01-05-2015 03:13 AM |
My Ascender Build | wax | Vaterra Ascender | 1 | 10-22-2014 05:38 PM |
