01-14-2009, 03:02 PM | #461 | |
RCC Addict Join Date: Apr 2008 Location: In The Machine, "Turn the light back ON"
Did you have a slipper on the tranny? Also the new dig spools are thicker attach points. But running 8cell puller, there is going to be a weak link, and a 3mm set screw will be it. | |
01-14-2009, 03:28 PM | #462 |
RCC Addict Join Date: Oct 2008 Location: Alpine,CA
Nope no slipper, Nor should i have to run one. My transmission outputs should be the last thing i have to worry about. And the rebuild kit i bought is the same as last. Nothings changed. And i never said the screws broke. The screws were fine. The output's broke. Simple as that. Last edited by DiEzel; 01-14-2009 at 03:31 PM. |
01-14-2009, 03:55 PM | #463 | |
I will send you a new thicker dig spool next week when I have them. As for the fron out drive, you are right, the screw did not break, but your are not correct as to this not happening with steel. That much power on one or two contact points, That is the weak link. Two set screws will do the same thing. | |
01-14-2009, 04:00 PM | #464 |
If the front spool was 4130 or 300m, with thicker mounting points (Even as thick as stock would be nice) It would hold up to the power and abuse much nicer. I don't want you to think im coming down on your product Solomon. I Love the innovation and design you guys have. I personally believe the out drives need attention and a different material. Feed back right ? Heres a dumb question, and i'd love to test it if you made it.... What about utilizing ALL the holes on the "Diff" Gear.... Or Half.... 4130 outputs. Bulletproof. |
01-14-2009, 04:10 PM | #465 | |
The problem when you go to steel is the cost. You can use the stock front out put. No one will buy a dig for $100.00 when you can get them as cheap as $40.00. I hear what your saying, we cant build them out of steel and still compete price wise. Feed back is always good. | |
01-14-2009, 04:12 PM | #466 |
I would pay the extra to not have a headache. Thats my opinion. Maybe we can work something out and i can have you guys make me a "Special set"
01-14-2009, 04:21 PM | #467 |
Rock Crawler Join Date: May 2007 Location: Corona, CA
Can someone tell me if my replacement dig shipped out yet?
01-14-2009, 08:10 PM | #468 |
Quarry Creeper Join Date: Nov 2006 Location: hesperia
I have a couple concerns with a new DNA rebuild kit I just purchased... The first thing I noticed, The new center cog is still raw aluminum ?? I thought this was going to be hard anno'd ?? Raw aluminum VS coated aluminum is only a given, the raw is going to wear out...( like my last cog) at least the tolerance is better between the two on the new one. There isn't a gap between the two pieces...leadig the corner of the cog to wear out... The next thing I noticed was on the shifter fork, one leg is one thickness and the other is another.... Shouldn't these be the same ?? And then I noticed the Pin on shifter fork is not pressed in all the way and is sitting crooked ?? Shouldn't the fork legs be the same thickness and the pin be straight ?? I did notice they made the engagement areas deeper then before....but the slop between the fork and the rear output is allot... Just wondering, my next step is to take some machining into my own hands Business card and packaging is TOP notch |
01-14-2009, 11:19 PM | #469 | |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
Just a thought bud. | |
01-15-2009, 06:01 AM | #470 |
My point is this. I understand the cost would be raised, I understand not everyone wants to pay the extra cash. But i have one simple last question. Why in the hell should i have to go hunting for a stronger front/rear output when im PAYING for outputs already ? Because im running a bigger motor then most ? Give me break. Also. About the cost now that I've thought about it. DNA Dig - 65 bucks. Rebuild kit 30 bucks... I'm sitting at 95 bucks after 4 battery packs... I would of GLADLY spent 5 bucks more to have 4130/ 300m Outputs. Last edited by DiEzel; 01-15-2009 at 06:12 AM. |
01-15-2009, 07:11 AM | #471 |
| Can you e-mail customerservice@dna-rc.com with what part and address it shoukd have gone to? Thanks and we will get back to you. |
01-15-2009, 07:21 AM | #472 | |
Ok guy's. Here is what Don and I have decided. We are going to look at the cost of the steel parts. What we might need to do is offer a "standard" dig and a "Heavy Duty" dig. Then we would offer a upgrade kit for those who have a dig and want the steel internals. This is ONLY going to happen if the cost is still on this planet. Diezel, I understand your point. But even on a 1:1 crawler, when your running a 500hp big block turning 38's, when you get bound up you dont just dump the clutch and expect nothing to break. All you gus have good valid points. Thats why we are going to look at it and see if we can do something for EVERYONE. No an easy task but we will try. | |
01-15-2009, 07:25 AM | #473 | |
01-15-2009, 01:21 PM | #474 |
Email sent. Also if it helps Don was the person helping me.
01-15-2009, 02:46 PM | #475 |
Rock Crawler Join Date: Aug 2008 Location: B.C.Canada
I would have paid more for a HD dig,, up to about $100. A $30 re.kit is nice to have available but i would rather pay $80-100 and never worry about all these issues.I bought the DNA cause i thought all the bugs had been worked out already. Maybe offer a line of HD parts to upgrade and give a discount to those who already have the older unit's. |
01-15-2009, 03:07 PM | #476 | ||
Lol. We dont want to compare apples to oranges do we ? If i had a 1:1 rig. And i had a 500hp Big block, Th400, Atlas II, High angle driveline's, and Dana 70/80 or 2.5 Rockwells.. Then yes i would expect nothing to break. Granted over time parts fail, Agreed. But your damn straight i would beat the living snot out of it if i had those parts. Quote:
01-15-2009, 08:49 PM | #477 |
Just jump it! Join Date: Aug 2008 Location: Cedar City, Utah
Hey now. I have a problem with my dig unit. Not only does the brass pin wobble, this whole aluminum piece in this photo does. If you look at the gap while you spin it you can see the whole thing wobble, not just the brass. I cant even run it because It has a bad binding spot on it. it you assemble it and try to spin the drive shaft by hand you cant, its that tight. I bought it from rpp hobby and was wondering if i should deal with you or you through them.. What are my chances of getting a replacement piece? Any info will help, thanks |
01-16-2009, 02:43 PM | #478 |
Holmes Hobbies Join Date: Jan 2007 Location: No Where
just got my chassis and wheels.Top notch product as usual with great support.Thank you guys |
01-16-2009, 06:24 PM | #479 |
True to Solomons pleadge to stand behind their parts, I recieved another rear outdrive to replace the last 2 defective/damaged ones. The new one arrived in the same FLAT PARCEL shipping envelope that the last damaged part arrived in. This part had a minor ding on the side of it, but it didn't seem to effect the part. I had told DNA that both of the outdrives were bad, but I only got a rear one, so I reused the stock AX-10 part for the front drive. The outdrives spin nicely and finally don't wobble, but as soon as I install the dig cover and the rest of the parts, I have a binding issue. I used my highly calibrated dyno-finger to spin the spur gear. When the dig is in the rear locked position, the spur gear spins freely. When I engage the 4wd position, I can feel that it takes at least 3X the effort to spin the spur gear, and I can feel the amount of resistance change every 1/2 revolution, like there is an internal bind. Am I missing something with the set up? I'm not using any type of white grease, as I don't want any 'stick-tion' within the unit. I used a graphite spray which goes on dry and will not attract dust or moisture. I am really at a loss, and my patience is almost gone. I didn't spend almost $100 for a dig unit and servo ( which cooked within 15 seconds because of the binding) to have to re-engineer it and tweek it to get it to work satisfactory. I want to call RPP and arrange for a return/refund, but I feel bad about sticking Corey with a bad part that he had nothing to do with, besides being a vendor for the product. Any ideas on what to look for that can be causing the internal binding? The tranny was a 1 season old case with brand new bearings and gears before I installed the dig unit. |
01-16-2009, 07:04 PM | #480 | ||
Ok guys. Here is what we are going to do. Monday we will send you both all new internals. Or send the trans and dig in and we will build them in house and send them back. Please e-mail what you would like to do. | ||
