08-05-2011, 08:17 PM | #161 | |
RCC Addict Join Date: Sep 2010 Location: Malta, NY
08-05-2011, 10:00 PM | #162 |
Rock Crawler Join Date: Apr 2011 Location: Sonoma County
08-06-2011, 01:05 AM | #163 |
Pebble Pounder Join Date: Nov 2010 Location: Mesa
hmmm thats strange because with my spare creeper kit with the updated driveshafts the alluminum covers cover the entire pin. I am running one on the front now just to see how it holds up. So far so good. I've twisted the traxxas male shafts but have never broken the metal yokes yet. The new updated venom shafts seem to hold up really well but you should see why the cover's dont encase the entire pin, mine does. I always carry my extra traxxas shafts though just in case!
08-06-2011, 04:06 PM | #164 |
Here is a better picture of the shaft break: I also noticed this.... |
08-06-2011, 04:07 PM | #165 |
I cut the body down more every week: I should just get the vulture chassis shouldn't I |
08-06-2011, 08:49 PM | #166 |
08-07-2011, 09:47 PM | #167 |
Thats where most all stock shafts break. The new pin locks so far for me have worked great. Still operational after 5 hrs of chasin those moa's, very successfully I might add!
08-11-2011, 09:22 PM | #168 |
Could this chassis work with the creeper? It is an unknown kamikaze. I want to buy the losi shocks off of this and was wondering if the chassis would be worthwhile... |
08-11-2011, 09:49 PM | #169 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
| you would have to drill custom holes for the skid plate...but just about any chassis can be modified to work with just about any set up you can imagine....
08-11-2011, 09:50 PM | #170 |
Rock Crawler Join Date: May 2010 Location: Albuquerque
Well I would imagine that it would work with enough customization of links and whatnot
08-13-2011, 02:09 PM | #171 |
I added the new skid plate which has the sloping front in it. It seems like there's more play between the left and right wheels on each axle than there should be. I think I need to JB weld the diffs...I just locked it with a spacer earlier and i think something is messed up in there Also, I fixed the driveshaft that broke. I had to sand down the pins a little bit in order to get the venom pin keepers to fit over them. |
08-13-2011, 09:35 PM | #172 |
It'll be a while before I get to cut some parts. One more class and I can use a Tormach CNC machine... I decided where I want the holes to be and drew over it. chassis possibilities: I like the idea of a vw bettle like profile so it is good at rocking back and forth upside down. It will have 4 chassis pieces so that the shocks and links can be mounted in the best locations width wise. Instead of tin or sheet plastic I want to make the panels out of Hylite. I have some 1.2mm thick stuff. It's really cool. Its aluminum sheet sandwiching polypropelene so its super light but really stiff. (Its kind of like an I-beam effect but for sheet material) That hylite will be screwed onto the chassis to reinforce it. Here is an Ipad case I designed with it (http://joby.com/gorillamobile/ori-2/) Because of this maybe I can make the chassis even thinner... |
08-19-2011, 12:19 PM | #173 |
No comments on the chassis i guess... One of my wheels had the red hexnut jammed in off center. lame. Here are what my diffs look like: I jb welded them. I re-installed them without the plastic piece that used to slide the red part with the pins in it in and out of the diff. Do people keep that little c shaped piece in for some reason? I took them out. |
08-19-2011, 01:16 PM | #174 |
Quarry Creeper Join Date: Aug 2010 Location: Sheboygan
I like the 3rd and 5th chassis myself.
08-19-2011, 04:48 PM | #175 |
08-19-2011, 05:39 PM | #176 |
Simple question. If you have 2.2" wheels and you mount them on thin wheels, are they still in the same class during competition as rigs running the stock width wheels? Even though your wheels are much larger in diameter now? Seems like cheating so I want to do it |
08-19-2011, 06:15 PM | #177 |
max diameter is 2.2 inches...google---> USRCCA RULES look for 2011 rules
08-19-2011, 06:55 PM | #178 |
Quarry Creeper Join Date: Apr 2011 Location: Canada
| drawings
I wish i was that talented, they do look like bird skulls though |
08-20-2011, 01:06 AM | #179 | |
RCC Addict Join Date: Apr 2010 Location: Ringwood
crawling and setting up a rig is all about compromise | |
08-20-2011, 01:23 AM | #180 |
| Is this what you meant to ask^^^^^^^^^^fixed yellow text?
Tags |
3d print, build, creeper, step by step, venom |
