03-20-2012, 07:11 AM | #81 |
Rock Crawler Join Date: Jan 2012 Location: st.louis
Also, i used the black servo backs from the original servo mounts and used them as the nuts on the back of the btl kit. Later on i will cut them flat so they arent like triangles. But they work good. I also flipped my knuckles too.. just saying. I have updated pics on my thread if you need to see aanything. |
03-20-2012, 09:00 AM | #82 | |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
| Re: wanting a winner... build thread Quote:
03-20-2012, 10:40 AM | #83 |
Hah why didnt you just get them first.
03-20-2012, 03:21 PM | #84 |
I have had the traxxas shafts, I got the axial shafts with a whole aluminum axial xr-10 link set for 30$... So I got the links half price an the shafts for free! Depending on how you look at it... I just happen to notice they are pretty similar.. As far as the steering set up... I didn't get home till 9 an just threw that together so I had a start on it today after work.. its not staying that way, have to be up at 4 an was up till mid night when I slapped the btl plate on an connected the ota link at 430 this morning... Haha, I wanted to take the day off to work on it! Have to work to pay for the sickness tho! (Or the wife would be horribly mad at me!?) The shafts.... My female female with male insert inside the two female shafts is still holding up on the front so I haven changed it out yet.. still haven felt like drilling out the stripped set screw... To busy building other parts of it.. Last edited by winnerone23; 03-20-2012 at 03:24 PM. |
03-20-2012, 03:55 PM | #85 |
Sounds good.
03-20-2012, 08:58 PM | #86 |
Ok, so how retarded is just changing one little thing making such a huge difference! I put my btl plate on from Rmdw an just attacked my course at home.. ripped right thru spots it wouldn't even touch before! This is awesome! I think I'm goin to just keep changing one thing at A time so I know what every little thing changes... If it keeps getting better with everything I change, ill be stoked! Thanks venom an thank you Rmdw! Ok now for a question.. I had a 645mg on to start with(I have two, one off my nitro)... The one that was on my rig, when I pushed a wheel, just went left to right. Very loose, couldn't get it to turn the wheels on the carpet. The one out of my nitro is hard to turn, like its tight. I put the tight one on with the btl plate. It turns the wheels like no other now! Carpet test past with flying colors! WHat a diff! ... Now could this be cause my,loose, 645mg is shot or goin bad? Or does the ota steering make that huge an sweet of a difference? Last edited by winnerone23; 03-20-2012 at 09:07 PM. |
03-20-2012, 09:00 PM | #87 |
Where did you get your servo?
03-20-2012, 09:23 PM | #88 |
One with the rig, one with my nitro, I borrowed it from it... An got one off ebay.. suppose to have 209oz but not sure, it ran like the loose 645mg... But I'm not sure it was the servo or my steering set up I just had.. ? The way I had it setup was nice for clearance but not sure for steering power. Now I was running it without a Bec as well.
03-20-2012, 09:48 PM | #89 |
Oh. Hah ive borrowed about 3 from my 1/8 truck. Well crawlers are hard on servos
03-20-2012, 09:57 PM | #90 | |
Quarry Creeper Join Date: Jan 2011 Location: murrieta
Yes, I'd say your "loose" 645mg servo is going bad.....or did you happen to use a different servo horn? On the "loose" servo it may be a stripped horn if you did use a different one. | |
03-20-2012, 10:00 PM | #91 |
What do you mean loose?
03-21-2012, 03:32 AM | #92 |
Well the btl plate moves the servo up to use with the ota.. long hours no sleep.. lol. Same horn, two diff servos same model.. now the tight (to turn) one seems to have all kinda power.. I thought it made it slow or weak.. maybe it was the drag link setup I was using before the ota setup. I'm thinking maybe the angle of having the drag link up in the air gave it too much angle an lost turning power? Works great now! Now I'm real exited to get my castle field card to set up my Bec off default! Plus put the new servo on, at twice the power! (At minimum) |
03-21-2012, 11:05 AM | #93 |
That angle probly caused the servo to work too hard. If you think about it... Instead of the linkage being a nice sweep it's pushing down and over when turning left ....up and over when turning right. Ideal is to have the drag link parallel with the tie rod.
03-21-2012, 12:42 PM | #94 |
Rock Crawler Join Date: Nov 2011 Location: Paradise, ca
my steerings setup the same way no issues with it but i got a much bigger servo torque wise though
03-21-2012, 12:46 PM | #95 | |
03-21-2012, 03:14 PM | #96 |
I nave ur btl an ota on now Thomas, its awesome! Any ideas on why It's tight to turn my horn using my fingers? Anyone? It works great on the rig, I just don't want it using my battery up if It's bad.. I didn't use any other servos whit the ota tie rod to know but it works flawless that I can tell the way it is. Hoping when I get home my aluminum wheels, cs-170 an castle field link is there! Fingers crossed. Goin crawling with another guy when I get home so may not change anything till after, unless the field link is there to set up my esc an cc Bec.. when I get my wheels ill be putting my paradox dual foams in my rovers.. The stock foams I have in are cut to One inch like the dual foams an I like it. Can't wait to test the taller paradox ones!
03-21-2012, 04:45 PM | #97 |
Sounds likw your gunna have a full paradox creeper pretty soon.
03-21-2012, 08:12 PM | #98 |
Sure am! Can't wait! Just The chassis an Lincoln lockers to pay for yet, the rest is here! It all looks so nice too...
03-21-2012, 08:19 PM | #99 | |
03-21-2012, 08:30 PM | #100 |
wanting a winner... build thread - Similar Threads | ||||
Wanting to build a quadcopter | iamsuperbleeder | Non Crawler RC's | 21 | 03-25-2012 11:42 PM |
Wanting to build my own lcc | xThexFearedx | Team Losi Comp Crawler | 0 | 04-18-2010 11:26 PM |
T-shirt winner(s) thread | Cloak | General Crawlers | 23 | 08-14-2009 08:56 PM |
wanting to try another tuber build | iceman320 | General Crawlers | 8 | 03-29-2009 06:22 PM |
wanting to build a clod | PONYBOY87LX | Tamiya Clod Buster | 5 | 01-25-2008 11:52 AM |
