01-16-2012, 07:42 PM | #161 |
Rock Crawler Join Date: Oct 2009 Location: San Diego
| Re: MONGO - built specifically to steal exotic cars off a speeding train If its on a train and its exotic then consider it stolen Not much fabrication going on. Been doing drawings/calculations on paper for the next stage of this build: hydraulic steering. Right now the idea is to have a master/slave setup that is actuated by a servo. Im sourcing a hydraulic pump also but my guess right now is when I get my hands on one it will be too bulky and heavy. Also power consumption might be an issue. We'll see. For now with the M/S setup I'm aiming for about 2:1 ratio but this may change depending on the size/space limitations. With all the measurements somewhat figured out I stared building the slave cylinder. This is the piston and rod so far. Stainless and brass with a couple of nitrile o-rings. Mocked up against the axle. |
01-16-2012, 08:51 PM | #162 |
Man I hope you make that work. At some point somebody's got to come up with a reasonable hydraulic steering...
01-16-2012, 09:57 PM | #163 |
Quarry Creeper Join Date: Nov 2010 Location: Sarasota, Florida
You do realize that when you invent the 1/10 scale hydraulic steering system you're going to have to patten it and make your million dollars and then share it with us fellows on RCC right? |
01-16-2012, 10:32 PM | #164 |
Pebble Pounder Join Date: May 2008 Location: australia
And,we have the gun building the prototype hydraulic steering... Credit Card ready |
01-16-2012, 11:15 PM | #165 |
Rock Crawler Join Date: Aug 2010 Location: Socal
The technology and pieces are already here. Just how much do you want to pay for them? There is a link somewhere in this thread for some pretty expensive hydraulic parts. Grapple/Boom Truck (VIDEO's) |
01-19-2012, 10:52 PM | #166 |
Newbie Join Date: Jan 2012 Location: medford
your machining work leaves me speachless.. i cant wait to see this thing in action... you definatley have to do a couple of the jump scenes off of the movie..
01-20-2012, 06:54 AM | #167 |
Newbie Join Date: Jan 2012 Location: Loudon, TN
That thing definitely caught my attention in Fast Five. I just never imagined that I would see an rc version of it. Especially one this cool! |
01-22-2012, 02:10 PM | #168 | |
| Re: MONGO - built specifically to steal exotic cars off a speeding train Quote:
Progress on the slave... Cylinder and end cap are aluminum. The ID will eventually be polished to a mirror finish to promote good seal for the piston rings. The end caps will eventually undergo some finish turnings as well as reducing the end wall thickness for more ram clearance. Next is to drill/tap some inlets and check the volume/travel with some liquid | |
01-22-2012, 05:38 PM | #169 |
Pebble Pounder Join Date: May 2008 Location: El Monte
bad. ass.
01-23-2012, 12:02 AM | #170 |
I wanna be Dave Join Date: Dec 2009 Location: Outside DC
Amazing as usual. Homemade. Major points for your ambition. |
01-31-2012, 01:41 PM | #171 |
short update. new rod made of heat treated 0-1 steel w/more realistic threaded ends. cylinder clamps are made of 7075 - the closer one is pretty much done, the one in the rear needs to be slit and threaded. |
01-31-2012, 03:25 PM | #172 |
RCC Addict Join Date: Jan 2011 Location: Bozangeles
Nice man, very impressive.
01-31-2012, 03:48 PM | #173 |
| Re: MONGO - built specifically to steal exotic cars off a speeding train |
01-31-2012, 05:14 PM | #174 |
RCC Addict Join Date: May 2010 Location: Midwest
Nice work.. you got some skillz |
01-31-2012, 06:03 PM | #175 |
MODERATOR Join Date: Oct 2010 Location: RC Land
Do you have a picture of what you are doing your machine work on? Your skills are killer Only having spent time myself attempting quality tube joints, I know and appreciate your perfect fitments. |
01-31-2012, 06:23 PM | #176 |
Pebble Pounder Join Date: Mar 2007 Location: Orange Park Jax Fl
Good LORD this thing is just sick
01-31-2012, 09:49 PM | #177 |
Pebble Pounder Join Date: Feb 2011 Location: .
Incredible work!! how are you going to anchor the piston to the rod to keep it from sliding?
01-31-2012, 10:21 PM | #178 |
I've followed this from the beginning so don't thank me, I should thank you for bringing such an awesome piece to existance and showing us!
02-02-2012, 02:47 PM | #179 | |
So I filled the system with some water(easier to clean up than oil should it leak) and cycled it to check travel, o-ring drag and just to see it move so here's a short clip of the first test. Overall worked well. The water near the seal closest to the camera is just because the rod is wet - not because the seal is leaking. Next is to mount it onto the axle Last edited by prifral; 02-02-2012 at 02:50 PM. | |
02-02-2012, 02:55 PM | #180 |
Rock Crawler Join Date: Jun 2010 Location: Colorado Springs
That's awesome! Can't wait to see it mounted up!
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/1-9-scale-rigs/332988-mongo-built-specifically-steal-exotic-cars-off-speeding-train.html | ||||
TIMBERJACK 480B DEBUSQUEUR | This thread | Refback | 03-01-2013 05:51 AM | |
"Mongo" - page 3 | This thread | Refback | 03-01-2013 03:38 AM | |
RCFansÒ£¿ØÃÔ|RCFansÂÛ̳ - Powered by Discuz! | This thread | Refback | 02-17-2013 08:33 AM |
