06-15-2013, 05:12 PM | #241 |
Quarry Creeper Join Date: Sep 2011 Location: Lexington
Much appreciated. I guess mine is correct then. Just seems like the rear axle would benefit from being turned forward more. Similar to the angle of the front axle.
06-15-2013, 11:10 PM | #242 |
Rock Crawler Join Date: Oct 2010 Location: Nor Cal
| Re: Pham's VP Axial SCX-10 JK Jeep Wrangler Unlmited Rubicon - Unlimited Budget Proje My fronts I lengthened the front lower links to match the rear lower links. I wanted the front axle to have the pinion shaft parallel to the ground so that I can get some positive caster. The way the rear you could always use a shorter upper link to have less pinion angle.
06-18-2013, 09:00 PM | #243 |
RCC Addict Join Date: Nov 2011 Location: cold state
06-18-2013, 09:14 PM | #244 | |
Rock Crawler Join Date: Jun 2008 Location: sacramento
| Re: Pham's VP Axial SCX-10 JK Jeep Wrangler Unlmited Rubicon - Unlimited Budget Proje Quote:
I think they explain it around 3:05 into the video. Jim | |
06-18-2013, 09:43 PM | #245 |
Rock Crawler Join Date: Feb 2012 Location: Michigan
| Re: Pham's VP Axial SCX-10 JK Jeep Wrangler Unlmited Rubicon - Unlimited Budget Proje |
06-19-2013, 01:25 AM | #246 |
Quarry Creeper Join Date: Jun 2013 Location: Escondido, San Diego, CA
06-19-2013, 08:52 PM | #247 |
Pebble Pounder Join Date: Jun 2007 Location: La plata
"Since I used a Tekin B1R speed controller as my light controller I was able to turn off and on certain lights at certain points." HOW???? |
06-19-2013, 09:09 PM | #248 | ||||
Quote: Quote:
I have four different light systems for various lights. When powering the B1R up in voltage each system requires a certain amount of voltage to turn on hence I'm able to do what it does. | ||||
06-25-2013, 02:35 PM | #249 | |
Rock Crawler Join Date: Aug 2012 Location: Los Angeles, CA
In regards to waterproofing, what are you doing to protect that Redline ROC 412 from the water? | |
06-25-2013, 02:51 PM | #250 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
This thing is so sick, glad I got to see it in person. You're lucky it didn't "disappear." |
06-25-2013, 03:05 PM | #251 |
| Re: Pham's VP Axial SCX-10 JK Jeep Wrangler Unlmited Rubicon - Unlimited Budget Proje The only thing I have done was seal up all of the extra motor screw with grub screws with Loctite there were 4 total. I did that to my honcho and ran all of Axialfest with not one hiccup.
06-25-2013, 03:21 PM | #252 |
Quarry Creeper Join Date: Jan 2007 Location: Shingle Springs
What about the hole where the 3 tabs come out for the motor wires?
06-25-2013, 03:35 PM | #253 |
06-25-2013, 08:24 PM | #254 | |||
As I stated to you at Axialfest, I was really impressed to see you Honcho climb past us as we winched our way up. An unforgettable memory that made quite an impression on me that I started to research the brushless ROC 412. How would you compare the performance of the ROC 412 vs. the Tekin 35T motor? Thank you | |||
06-25-2013, 10:07 PM | #255 | |||
I know exactly how you feel about the Honcho on the climb lol. I too was super impressed with the rig because it could never do that before with the old tires and motor. In my honest opinion the Tekin 35t should never be compared to the ROC 412. The ROC 412 once dialed in correctly is such an amazing motor, the wheel speed is exceptional without having to gear up a ton. I get 13mph out of both my Honcho & Jeep JK on 20/87 gear setup. The torque on the other is awesome just like the speed, if you get this motor please be prepared to use HD everything, steel everything, and ready to find weak links. I'm still finding weak links on my honcho even though it work great with every other system I have had on it. It was good seeing you and your son at Axialfest I hope to see you guys again soon. | |||
06-26-2013, 11:05 AM | #256 | |
For now, I'll stick with my 35T/FX-R combo in my Jeep build and see how that performs. Thanks again for your insight and my apologies for digressing from your build thread and it was good to see you at Axialfest. I'm glad we were able to make it. | |
06-26-2013, 11:49 AM | #257 | |
06-26-2013, 12:13 PM | #258 |
Pebble Pounder Join Date: May 2007 Location: Titletown
Never run a Roc412, But I have ran 45 and 55t However I just changed motors on my JK and ordered the 35T Pro Hand wound. If no one else has chimed in on it once I amd up and running I will give my feedback on the HD Pro 35. |
06-26-2013, 12:27 PM | #259 |
| Re: Pham's VP Axial SCX-10 JK Jeep Wrangler Unlmited Rubicon - Unlimited Budget Proje Ty, thank you for the clarification. Now I have a better understanding for comparison purposes. I'll be running 3s. Thanks again.
06-26-2013, 01:05 PM | #260 |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-scx-10/423278-phams-vp-axial-scx-10-jk-jeep-wrangler-unlmited-rubicon-unlimited-budget-project.html | ||||
RCFansÒ£¿ØÃÔ|RCFansÂÛ̳ - Powered by Discuz! | This thread | Refback | 02-28-2013 06:13 PM | |
RCFansÒ£¿ØÃÔ|RCFansÂÛ̳ - Powered by Discuz! | This thread | Refback | 02-28-2013 01:22 AM |
Pham's VP Axial SCX-10 JK Jeep Wrangler Unlmited Rubicon - Unlimited Budget Project - Similar Threads | ||||
Rubi_con_Arni - Axial Jeep Wrangler Unlimited Rubicon | perseus71 | Axial SCX-10 | 79 | 08-11-2015 11:44 PM |
Axial SCX10 Jeep® Wrangler Unlimited Rubicon | jason | Scale Videos! | 16 | 11-03-2013 09:27 AM |
Axial SCX10 2012 Jeep Wrangler Unlimited Rubicon - AX90028 | BENDER | Axial SCX-10 | 379 | 07-02-2013 10:57 PM |
Axial Jeep Wrangler Rubicon Unlimited #2 | Rivas Concepts | Scale Videos! | 0 | 12-17-2012 10:48 AM |
New Axial SCX10 Jeep Wrangler Unlimited Rubicon Axial Promo Vid | B94Cast | Scale Videos! | 0 | 10-30-2012 12:20 PM |
