02-15-2013, 07:49 PM | #41 |
Quarry Creeper Join Date: Sep 2012 Location: Grande Prairie Alberta
That's amazing just read the thread from the start i just wish I had the funding to do a build like this are you going to get the hard top for it
02-15-2013, 09:02 PM | #42 |
Rock Crawler Join Date: Oct 2010 Location: Nor Cal
| Re: Pham's VP Axial SCX-10 JK Jeep Wrangler Unlmited Rubicon - Unlimited Budget Proje Thank You! Never too late to work on your own rig just take your time building up, I do plan on going with a hard top when I do my own color body.
02-16-2013, 09:58 AM | #43 |
Pebble Pounder Join Date: Jan 2013 Location: Zürich
Looks pretty expensive and nice :-)
02-16-2013, 12:59 PM | #44 |
Quarry Creeper Join Date: Jul 2011 Location: charlotte
im going to have to steal the esc mount that is so damn clean...where are you going to hide the rx?
02-17-2013, 08:16 PM | #45 |
Pebble Pounder Join Date: Apr 2011 Location: australia
What stock parts are needed from the kit to build these awesome axles . Example did you use the stock bearings or do the VP Currie Axles come with all that is needed ? What did u end up running in the diffs? Could you give the part # needed to build the bullet proof transmissiion from Robinson racing please . RR 1542+1541 replaces ax80010 , yes/no ? RR 1550 replaces the axial slipper unit/spur gear assembly ax30412,ax30411,ax30672 , yes/no ? What replaces the 20T drive gear ax30394 ? |
02-17-2013, 09:34 PM | #46 | ||
| Re: Pham's VP Axial SCX-10 JK Jeep Wrangler Unlmited Rubicon - Unlimited Budget Proje Thanks Quote:
-The only thing stock that I used were the stock rear shaft. Example did you use the stock bearings or do the VP Currie Axles come with all that is needed ? -I did not use the stock bearing but since left the stock axles alone for another project but you could use all of the stock bearings on the new Currie Axles. What did u end up running in the diffs? -For diffs I'm using AX30401 Heavy Duty Bevel Gear Set 36T/14T with VP Lockers Could you give the part # needed to build the bullet proof transmissiion from Robinson racing please . RR 1542+1541 replaces ax80010 , yes/no ? -Yes, both RR 1542 and 1541 is what I'm using! RR 1550 replaces the axial slipper unit/spur gear assembly ax30412,ax30411,ax30672 , yes/no ? -I'm not using any of those parts I'm using a Locked spur gear with no slipper. AX30197 Drive Gear Shaft 5x43 3Racing Spur Gear Adaptor For AX10 Scorpion Part #: AX10-02/GR with a Kimbrough 84t 48pitch spur gear with a Robinson Racing Pinion Gear What replaces the 20T drive gear ax30394 ? -Just leave that stock. Hope this all helps | ||
02-17-2013, 10:20 PM | #47 |
Thanks . Just to confirm then all I need is Ax10-02/GR and a spur gear of my choice RR 1587 and RR 1541 Rr 1542 and keep the stock drive . I`ll be running the VP Transmission housing and the VP gear guard do I still have to get a motor plate or is that come with the gear guard ? Last edited by patrol king; 02-17-2013 at 10:55 PM. |
02-18-2013, 10:01 AM | #48 | |
| Re: Pham's VP Axial SCX-10 JK Jeep Wrangler Unlmited Rubicon - Unlimited Budget Proje Quote:
VP gear guard comes with the motor plate no need to buy anything else with it.. | |
02-18-2013, 11:06 AM | #49 |
I seen a guy on Facebook and maybe here called bgr fab he makes a front bumper that looks similar to the stock that I think would suit this build good
02-18-2013, 11:59 PM | #50 | |
02-19-2013, 11:59 AM | #51 | |
02-19-2013, 09:21 PM | #52 |
Can't wait!!
02-22-2013, 04:40 PM | #53 |
Pebble Pounder Join Date: Jul 2011 Location: NorCal
Any updates? Sub'd |
02-22-2013, 07:08 PM | #54 |
Been super busy so I havn't gotten to work on my Jeep as much as I would like. So to start on the update I want to share with you guys one of the first proto type RC ROCK ARMOR rear bumper for the Axial Jeep JK. It will all be bolt on which will allow you to mount a rear winch with it's rear fair lead and also a hitch mount. I hope you guys like it, more updated to come stay tuned! Last edited by nissan_driver24; 02-22-2013 at 09:29 PM. Reason: bumper name |
02-22-2013, 09:15 PM | #55 | |
Prototype from who? Last edited by Wraith913; 02-22-2013 at 09:18 PM. | |
02-22-2013, 09:31 PM | #56 |
| Re: Pham's VP Axial SCX-10 JK Jeep Wrangler Unlmited Rubicon - Unlimited Budget Proje |
02-22-2013, 10:00 PM | #57 |
Thanks ill def be looking forward to the bumper is there plans for a front? I like the bgr fab front bumper It would suit you build good I think.
02-22-2013, 10:41 PM | #58 |
| Re: Pham's VP Axial SCX-10 JK Jeep Wrangler Unlmited Rubicon - Unlimited Budget Proje RC Rock Armor already has a front bumper that would work great for this BUT there may be something new in the making just stay tuned for that. |
02-24-2013, 08:28 PM | #59 |
Pebble Pounder Join Date: Dec 2011 Location: Monterey
awsome build so far man.
03-02-2013, 05:38 PM | #60 |
Any updates I love this build and want to see more
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-scx-10/423278-phams-vp-axial-scx-10-jk-jeep-wrangler-unlmited-rubicon-unlimited-budget-project.html | ||||
RCFansÒ£¿ØÃÔ|RCFansÂÛ̳ - Powered by Discuz! | This thread | Refback | 02-28-2013 06:13 PM | |
RCFansÒ£¿ØÃÔ|RCFansÂÛ̳ - Powered by Discuz! | This thread | Refback | 02-28-2013 01:22 AM |
Pham's VP Axial SCX-10 JK Jeep Wrangler Unlmited Rubicon - Unlimited Budget Project - Similar Threads | ||||
Rubi_con_Arni - Axial Jeep Wrangler Unlimited Rubicon | perseus71 | Axial SCX-10 | 79 | 08-11-2015 11:44 PM |
Axial SCX10 Jeep® Wrangler Unlimited Rubicon | jason | Scale Videos! | 16 | 11-03-2013 09:27 AM |
Axial SCX10 2012 Jeep Wrangler Unlimited Rubicon - AX90028 | BENDER | Axial SCX-10 | 379 | 07-02-2013 10:57 PM |
Axial Jeep Wrangler Rubicon Unlimited #2 | Rivas Concepts | Scale Videos! | 0 | 12-17-2012 10:48 AM |
New Axial SCX10 Jeep Wrangler Unlimited Rubicon Axial Promo Vid | B94Cast | Scale Videos! | 0 | 10-30-2012 12:20 PM |
