Thread: W.O.D. inspired family 4 seater buggy, "Southern Comfort" by CFM
Old 07-20-2012, 04:58 PM   #61
Metal shaper
Got the remote reservoirs done.
Clear Eyes, Full Hearts, Can't Lose
CarterFab is offline   Reply With Quote
Old 07-20-2012, 05:05 PM   #62
Default Re: W.O.D. inspired family 4 seater buggy, "Southern Comfort" by CFM
I like it a lot!!!
ScaleReady is offline   Reply With Quote
Old 07-20-2012, 05:24 PM   #63
www.team3sixrc.com
Great Job, I want to do this for the FOJV as well and was gonna actually contact you about it. But I need to make the shocks 85mm???
team3six is offline   Reply With Quote
Old 07-20-2012, 06:42 PM   #64
Metal shaper
So what's the problem Outlaw. It looks like the threads on the cap are 8mm x 0.5. We will basically be loosing an inch of overall length. That won't leave any adjustment for the spanner, but it will leave enough for it to at least screw back on in place. I would chop the reservoirs off too, cuz they will be rather large on the short shock.
You can't be scared all your life! Hahaha
Let me know
Carter Fab & Machine: Hand Made Customs
Old 07-20-2012, 07:19 PM   #65
Looking for new Trails
yoda@4x4's Avatar
I love the new King shocks they look great, chassis looks awesome can't wait to see it rolling...
yoda@4x4 is offline   Reply With Quote
Old 07-20-2012, 09:55 PM   #66
Where did you get the brass fittings for the rubber hose? And what size is it?
ngward79 is offline   Reply With Quote
Old 07-20-2012, 10:08 PM   #67
Metal shaper
Haha. Mind tricks son.
The "brass fitting" is actually a 2mm screw bolted into the cap. Ran a brass nut down on it. Cut the head of the screw off.
The "rubber hose" is actually a piece of silver solder wire wrapped with heat shrink used on wiring.
I drilled and tapped the reservoir, installed a 2mm screw, then sleeved a piece of solder that would leave enough on each end to be glued on to the screws of the cap and reservoir. Let dry. Heat the heat shrink and TA-DA!!
Just crap I had laying around that looked the part when assembled. Chose the "rubber hose" method over normal electrical wire due to the fact that I can shape it and it will hold.
Used a 2mm scale hex bolt for the schrader valve on the reservoir.
Old 07-21-2012, 12:09 AM   #68
Looks awesome
89lxmorepower is offline   Reply With Quote
Old 07-21-2012, 12:22 AM   #69
I think the reason being is that there is not really a format where they just bolt up like shocks or wheels. Only way to make them scale is to have the cans welded on and most people just aren't up for that.
I was thinking a pin spring inside to make it return to extension.
You mean like this?
I actually made them so they are adjustable up and down. Works really well.
War Pig is offline   Reply With Quote
Old 07-21-2012, 02:07 AM   #70
Wow on the bump stops! How much! Lol
matt_22 is offline   Reply With Quote
Old 07-21-2012, 03:44 AM   #71
Nice work
Just wait a few weeks....
Katan is offline   Reply With Quote
Old 07-21-2012, 08:02 AM   #72
www.team3sixrc.com
I was wondering when Tum was gonna say something.
Im pretty sure both him and I were the first with Functional Bump Stops. But his were made right.
Ohh and correction on the size. I need 90mm's
With remotes.
Old 07-21-2012, 01:52 PM   #73
Metal shaper
Yeah Tim, thats along the lines I was thinking. Gonna have to add some Teflon bumpers to mine though, can't be having metal on metal. Did you just weld the caps on once together?
Old 07-23-2012, 06:42 PM   #74
Metal shaper
Updated the front axle with some beef
Old 07-25-2012, 09:47 PM   #75
Metal shaper
Chassis is home at last. Bolted up the Titan 60 axles just to get an idea. Gonna make a few tweaks and figure out how to get the rear Ultimate 9 axle in there.
Would like to run scale links but these rod ends are pretty sloppy. Any suggestions? Might have to be happy with just scale hardware.
Got the "?" brand hubs modified the same way as LockedUp RC makes there's. Bored out the back side enough so that a normal lock nut still holds the actual wheel, then these screw down with the remaining threads from the shaft.
Man I got a lot of work to do and wife has me busy doing other stuff till next week. GAH!!!
Clay
Old 07-25-2012, 10:20 PM   #76
I must say that this rig looks spectacular.. fighting the urge to break out the credit card for one lol. great job.
SubaruDriftBoy is offline   Reply With Quote
Old 07-25-2012, 11:37 PM   #77
PapaGriz Yo
Grizzly4x4's Avatar
This thread gives me wood..........
Grizzly4x4 is offline   Reply With Quote
Old 07-25-2012, 11:51 PM   #78
The heims I have on one of my trucks are nice and tight. Side to side sitting in the link mounts, I shimmed with small conical washers though. Yours look different than mine. The chassis looks sick!
Bulldog is offline   Reply With Quote
Old 07-26-2012, 12:30 AM   #79
you could try the rod ends from McMaster-Carr.
joeyf is offline   Reply With Quote
Old 07-26-2012, 08:12 AM   #80
Man CRAWLER PORN can't turn away!
darkmanx is offline   Reply With Quote
W.O.D. inspired family 4 seater buggy, "Southern Comfort" by CFM - Similar Threads
"Southern Comfort" by CFM CarterFab Axial Wraith 687 08-13-2014 06:28 AM
"riddler" southern buggy build ROLANDROCKSHOP Axial Wraith 147 10-25-2013 01:54 PM
RECON G6 Challenge "The Superlift Southern Showdown G6" & "Outlaw Terra-X" DRIVNMF Recon G6 227 10-19-2012 10:26 AM
mg200 southern buggy build "HEADCASE" ROLANDROCKSHOP Axial Wraith 187 03-04-2012 06:35 PM
