03-23-2013, 10:00 AM | #141 |
Rock Crawler Join Date: Feb 2010 Location: rochester, mn
| Re: What shocks you running? |
03-23-2013, 10:14 AM | #142 |
Pebble Pounder Join Date: Apr 2006 Location: Spring Hill, TN
Thx. I grabbed a set for myself. Think I'm going to sell the 4 XD Piggybacks I bought.
03-23-2013, 10:17 AM | #143 |
03-23-2013, 10:29 AM | #144 |
I found them on Amazon. I must have got the last 4 on the planet. They seem perfectly nice to me but they are a little on the large size and there's not much room left around the back ones. In fact there's no room especially running with the rear Da Box installed. So, I have 2 XD 103mm Aeration shocks in the back and the 103mm piggybacks in the front. The mis-match bugs me a little but I suppose it's not that big of a deal.
03-23-2013, 10:37 AM | #145 |
Quarry Creeper Join Date: Jan 2013 Location: Spokane
Just wondering for crawling do you want 3 hole pistons or 1 hole pistons?
03-23-2013, 10:54 AM | #146 |
RCC Addict Join Date: Aug 2012 Location: Philippines
I'm guessing they're 110mm.
03-25-2013, 04:38 PM | #147 |
Rock Stacker Join Date: Mar 2013 Location: Newmarket
I've been experimenting with HPI wheely/crawler king shocks thanks to my friend. At 117mm extended and 77mm compressed I think they are the ticket. At this point I am looking at buying the aluminum threaded version and running my soft kit wraith springs. |
03-27-2013, 05:19 PM | #148 |
Man, those Kings are soft. Definitely a crawler shock. The XD's are much more suited to general bashing.
03-27-2013, 05:37 PM | #149 |
Rock Stacker Join Date: Mar 2009 Location: frederick
My stock RTR shocks are super soft right now. All the shock fluid has leaked out of them!!!!!
03-27-2013, 05:39 PM | #150 |
03-27-2013, 05:43 PM | #151 |
05-14-2013, 06:27 AM | #152 |
Newbie Join Date: Feb 2013 Location: Australia
Question for anyone that is using the proline powerstroke rear shocks, how much travel do they have? i am looking for a quality shock that has a little bit more travel than the stock plastic ones thanks |
05-18-2013, 11:13 PM | #153 |
Pebble Pounder Join Date: May 2013 Location: kinzers
Does anyone have video of how to make dual springs for integy 138mm shocks this is my first rc got it new rtr work in progress so far battery is up front parts-lots of integy chassis stiffeners VP stage 1, VP titanium 10pc links, ss hardware, bgr f/r upper shock mounts, and integy 138mm shocks, traxxas silicon 30wt, I love shocks and flex I would like to try some different spring options hope to have pics soon
05-20-2013, 02:49 PM | #154 | |
| Re: What shocks you running? Quote:
No video but I have used the following method on my Venom 138mm shocks. (essentially the same as the integy...) Use losi 4" springs of whatever desired rate you choose. use two upper spring retainers (the plastic "stepped" ring that separates pre-load adjusters from the spring itself) glued together to make a connector for two separate springs to fit aligned on one shock. (think RC4WD King Shocks spring setup.) Then cut one spring shorter to the desired length to fill the shock with a full length spring. You can use this to get dual rate springs, adjust pre-load without having to run the adjustment collar down so much. I also use two pair of needle nose pliers to adjust the last coil on the cut spring so it sits flat like the ends of a stock spring. Step 12: Have fun. | |
05-20-2013, 04:44 PM | #155 |
Thanks gbean gonna try that out did you use any heat when you adjusted the spring end I have worked with larger id, and wire size with a torch you can shape perfectly
05-20-2013, 06:12 PM | #156 |
You could, but with such small wire you may affect the rate...
06-03-2013, 01:34 PM | #157 |
I'm swapping out the 138mm Venom shocks in the rear of my Wraith for GMade XD piggybacks (103mm.) There was just too much travel in the rear. |
06-03-2013, 04:19 PM | #158 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
06-04-2013, 03:52 AM | #159 |
Pebble Pounder Join Date: Nov 2012 Location: Stoke on trent , England
After owning the Gmade piggybacks for 4 months or so I hate them , Just traded for some Losi crawler shocks . Way to stiff and leaked badly .. Love the Losi's Jack. |
06-04-2013, 04:48 AM | #160 |
I've been running the gmade xd aerator shocks up front with no leakage whatsoever for about 4 months.
What shocks you running? - Similar Threads | ||||
what shocks are you running? | maRRtin | Redcat Crawlers | 5 | 03-02-2012 06:26 PM |
Shocks - What has everyone tried or running? | NCT_Guy | Axial Wraith | 13 | 01-03-2012 03:37 PM |
Wraith shocks? What are you running? | Mr.Tek | Axial Wraith | 4 | 01-03-2012 08:28 AM |
What shocks are you running? | V3500 | Axial SCX-10 | 21 | 01-22-2011 03:15 PM |
What Shocks you running? | LeDevil | Tamiya XC/CC01 | 20 | 01-17-2010 05:27 PM |
