03-18-2013, 08:25 PM | #121 |
Quarry Creeper Join Date: Dec 2012 Location: Cottage Grove MN
| Re: What shocks you running?
Actually they are slash rear shocks and they are not the same length...I compared the two and the Prolines come up about a 1/8" short. 1/4" Preload No Preload 1/2" Preload |
03-18-2013, 08:51 PM | #122 |
Thanks for taking the time to take extra photos. I'm looking for level bottom links. My rig is 9lbs so may make it level with no preload |
03-18-2013, 08:53 PM | #123 |
Here is the comparison between Prolines and Stock shocks... 1/8-1/16" difference between the two.. |
03-18-2013, 08:56 PM | #124 |
| Re: What shocks you running? |
03-18-2013, 08:58 PM | #125 |
Here's how I'm sitn with stock shocks zero preload and 25weight oil along with all the free lowering tricks. Need to Teflon tape the caps so the stop leaking. |
03-18-2013, 09:05 PM | #126 |
I have limitless rear mounting position and need to build something for the front
03-18-2013, 09:16 PM | #127 |
Rock Stacker Join Date: Mar 2009 Location: frederick
Evan, do you have a close up pic of your rear, upper shock mount?
03-18-2013, 09:29 PM | #128 |
Probly somewhere. Ill look.
03-18-2013, 09:33 PM | #129 |
Not finding any good pucs of it. |
03-18-2013, 09:41 PM | #130 |
RCC Addict Join Date: Aug 2012 Location: Philippines
The slash rears I had measured 108mm, they were they same as my RTR wraith shocks, which is why I said they were the same length. Keep in mind when measuring shocks, I measure center eye to center eye. The two different shocks have different size eyes and the pro lines have more material around the eyes.
03-18-2013, 10:34 PM | #131 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
I'm running Losi Comp crawler shocks with 30wt oil ,soft springs and no preload. The front I'm running the stock kit Wraith shocks with 30wt oil and half preloaded (all of my electronics are up front). Also, I have done all of the free lowering mods. |
03-20-2013, 07:43 AM | #132 |
Newbie Join Date: Mar 2013 Location: ny
What is the complete max shock length eye to eye, without having any binding? i want articulation, was looking to run 138mm with a droop, but now nervous at the cost of binding
03-20-2013, 09:15 AM | #133 |
I've ran 115mm with no binding. Couldn't set needing a longer shock
03-20-2013, 09:29 AM | #134 |
I have 138 mm shocks on the rear with zero binding.
03-22-2013, 07:30 AM | #135 | |
Quarry Creeper Join Date: Sep 2009 Location: Detroit
| Re: What shocks you running? Quote:
Crawling- softer springs, stiffer damping High speed- stiffer springs, softer damping From there you would make the needed adjustments to valving and spring rate for the vehicles weight and desired performance. | |
03-22-2013, 08:25 AM | #136 |
I find it is a matter of preference and driving style for crawling setup. I do better with light springs and lighter damping. But again, try different things. |
03-22-2013, 08:58 AM | #137 |
Springs should be a close mach to valveing Soft springs soft valveing |
03-23-2013, 09:20 AM | #138 |
Rock Crawler Join Date: Feb 2010 Location: rochester, mn
Got my king shocks installed. They look awesome and very scale looking
03-23-2013, 09:21 AM | #139 |
They are very smooth, they are just a tad stiff right now so I have to do some adjusting
03-23-2013, 09:49 AM | #140 |
Pebble Pounder Join Date: Apr 2006 Location: Spring Hill, TN
Looks good. What mm are they and where did you get them?
What shocks you running? - Similar Threads | ||||
what shocks are you running? | maRRtin | Redcat Crawlers | 5 | 03-02-2012 06:26 PM |
Shocks - What has everyone tried or running? | NCT_Guy | Axial Wraith | 13 | 01-03-2012 03:37 PM |
Wraith shocks? What are you running? | Mr.Tek | Axial Wraith | 4 | 01-03-2012 08:28 AM |
What shocks are you running? | V3500 | Axial SCX-10 | 21 | 01-22-2011 03:15 PM |
What Shocks you running? | LeDevil | Tamiya XC/CC01 | 20 | 01-17-2010 05:27 PM |
