05-07-2012, 01:01 PM | #41 | |
Rock Crawler Join Date: Feb 2008 Location: Dortmund, Germany
| Re: Dr.Frank's XR Take II Secret Agent 3.5ed Quote:
Greetings Frank | |
06-24-2012, 06:43 AM | #42 |
Hello, new skins don't make the car run better, but the driver feels much better... ...and maybe he'll do a bit better driving Okay, i did some little changes, but that's another story Greetings Frank Last edited by Dr.Frank; 06-24-2012 at 08:04 AM. |
06-24-2012, 07:18 AM | #43 | |
I wanna be Dave Join Date: Sep 2009 Location: Eastcoast CANADA
Look professional be professional is Robs motto! Cheers Michelle | |
09-03-2012, 03:27 AM | #44 |
| Dr.Frank's XR Take II T1E OPS flyweigthed
Hello, a while ago i stop comp crawling and sold my beloved XR Agent. But if you are once infected by the RC crawling virus, you can't go without a MOA. So i start a new build. It'll be slow, but well considered. What chassis should i take now, YTC, T1E... ...okay, i saw the first pictures of the T1E OPS and could not resist. What else should i do. One goal is to meet the 1600g (3.5lbs) mark. I took the best out of several build threads and now it's on me to put it all togehter. First step was getting weight out of the lower and upper links. How to do, quite simple. I took the "Egressor" Ti tube lower link idea and the 3mm "DLux" upper idea together with the OPS. So here is a picture of the result: ...i think that's not the poorest start i made. With the final skid it should be 110g. Detailed pictures of how to do Grade9 Ti hollow lowers will follow. As i said before, this thing will take it's time... ...to be continued Greetings Frank Ah, forgot, i'll run not a 50/50 or 60/40 setup, nop it'll be a 55/45'er Last edited by Dr.Frank; 09-03-2012 at 03:48 AM. |
09-03-2012, 03:46 AM | #45 | |
Rock Crawler Join Date: Jul 2009 Location: Wil - Switzerland
| Re: Dr.Frank's XR Take II T1E OPS flyweigthed Quote:
But I'm just wondering, as a Crawlerkeller Teamdriver that you are, why not the brandnew Crawlerkeller Carbon Chassis? good luck with the lightweight lady | |
09-12-2012, 01:52 AM | #46 | |
The OPS made some very little progress. Due to a surgery i'm not able to use my machinery, so i made a drawing and a freind did the milling. Milling what? A one piece skid. What, one piece, you copy the Chaotic idea. Yes i did, it's an awesome idea they had and i couldn't do better. For my excuse, it's not a mass product, it's only for me Here are some pics: ...to be continued. Greetings Frank | |
09-12-2012, 02:08 AM | #47 |
Great start Frank. I'm looking forward to see what other tricks you pull from your sleeve. Curious about the skid you made. Did you add triangulation to the lowers, or does the t1e setup already include the spacers you have outside of the rod end? |
09-12-2012, 03:40 AM | #48 | |
I ordered the CF plates only and did some 70mm Delrin spacers for the top of the cap and use Axial Aluminum spacers for the rest. 70mm for the shockmounts, 40mm for the upper links. To reach the legal width i use 6mm and 2mm spacers for the uppers and 3mm for the lowers and as you said, this adds some triangulation and helps to let them work smoothly. Greetings Frank | |
09-12-2012, 06:24 AM | #49 |
RCC Addict Join Date: Nov 2009 Location: cleveland,Tn
rig is looking good ! |
09-12-2012, 07:30 AM | #50 |
Rock Crawler Join Date: Jul 2010 Location: VOLS!
Hope you recover soon Frank I'm running a very similar setup but no fancy skid like yours Nice work! |
09-12-2012, 07:41 AM | #51 |
RCC Addict Join Date: Jan 2005 Location: Germany north
| Re: Dr.Frank's XR Take II T1E OPS flyweigthed |
09-12-2012, 08:28 AM | #52 | |
| Re: Dr.Frank's XR Take II T1E OPS flyweigthed Thanks, wait until it's on wheels Quote:
Without your skills, i think there would be no OPS Danke, wird so langsam wieder, laufen "geht" einigermaßen aber das wird. | |
09-12-2012, 12:27 PM | #53 |
Looks awsome man! That is a sweet skid that goes with a sweet chassis!! |
09-12-2012, 12:52 PM | #54 |
I have the Chaotic skid for this reason. Did you make yours the same width as the original Special Ops skid. The Chaotic skid is narrower which is also good for other reasons. Looking forward to more. |
09-12-2012, 01:01 PM | #55 | ||
Greetings Frank | ||
09-13-2012, 04:59 AM | #56 |
Little progress on the axles: Axial 8mm bearing motor plate (Al): RC4WD 9mm bearing motor plate (Al): MM "Amok" 10mm bearing motor plate (CF): Assembled rear axle (Axial lightweight gears and Ti shaft): Assembled front axle (Axial lightweight gears and Ti shaft): ...a good point to go further Greetings Frank |
09-13-2012, 07:58 AM | #57 |
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
Lookin good there doc. The CF motor plate is a sexy piece & you're right...The Chaotic skid is a KILLER addition to your build. Hope ya get that target weight...& don't sell THIS rig off too. J.D. |
09-14-2012, 08:59 AM | #58 | |
...first i have to finish it. Ah, little progress again: ...999g left for wheels, motors and electronics Greetings Frank | |
09-14-2012, 01:06 PM | #59 |
Those motor plates are so sick! Its not a drasitc weight loss but they look so bad ass its worth it |
09-17-2012, 07:06 AM | #60 |
I wanna be Dave Join Date: Oct 2007 Location: 801
Looking good as always frank. Keep uP the good work and get that foot healed up. |
Dr.Frank's XR take II CK Fly V1 - Similar Threads | ||||
Dr.Frank's Mogster | Dr.Frank | Axial SCX-10 | 19 | 08-21-2011 10:54 AM |
Dr.Frank's back | Dr.Frank | RC4WD Bully | 44 | 03-30-2011 07:08 AM |
Dr.Frank's new shoes | Dr.Frank | Tires and Wheels | 13 | 10-08-2010 04:25 PM |
Dr.Frank's MRC | Dr.Frank | Losi Mini-Rock Crawler | 8 | 11-09-2009 08:24 AM |
