07-23-2014, 09:14 PM | #81 |
Metal shaper Join Date: Dec 2008 Location: Hog Eye, Texas
07-23-2014, 09:15 PM | #82 | |
Yes, I'll pull it and see if there's a hinge pin with E-clips that would swap in direct. | |
07-23-2014, 09:17 PM | #83 |
Couple of short Rock testing videos. Specs on the car are in the description of the video. The 500k diff is a definite improvement over stock. http://youtu.be/8eMrh2H_0T0 http://youtu.be/blQ8WXC1NSY |
07-23-2014, 09:38 PM | #84 |
Rock Crawler Join Date: Feb 2014 Location: ?
| Re: Messing with Sasquatch: CFM's Yeti |
07-24-2014, 08:38 AM | #85 |
Rock Crawler Join Date: Feb 2007 Location: Crawling Around
Will it still steer with the fronts tucked in that much? No steering or contact issues at full lock?
07-24-2014, 08:43 AM | #86 | |
Bench testing there is no clearance issue. I will run it maybe this evening with the new .225 hubs and going to bring he rear in some also. Want to do a turning radius test on pavement and see if the hubs are gonna make a noticeable difference or if it will mainly just be a track width adjustment. We aren't gonna lock the front diff and we did swap 43/13 HD gears in the rear. If we have time, I'll swap a stock diff back in the rear and do a true test comparing everything for turning radius results. | |
07-24-2014, 04:18 PM | #87 |
Rock Crawler Join Date: Jul 2009 Location: Victoria Australia
I like the roof and bonnet but I'm not a fan of the side panels behind the cage, looking forward to seeing what else you do with this.
07-25-2014, 07:58 AM | #88 |
Inner side panels are live on the site, http://carterfabmachine.com/?product...de-panels-pair |
07-27-2014, 04:04 PM | #89 |
Ran the Yeti today at our local event. Completed both stages and two of the 4 bonus challenges. Other two were water and winch related so I didn't try those. This was the most fun I've had running a rig at a comp and it blew through the obstacles with ease and speed. My son ran his Wraith which is the same rig we used to comp with, just different rolling stock now. After stage 1: After stage 2: Trevor ran the water challenge after the event and came back filthy. Overall I'm super pleased with the Yeti, even though we've changed a few things from stock, it was the best handling rig and most fun to drive that I've personally run. Cleanup was also a breeze. Just sprayed out the bottom tray. No breakage and nothing seems to be more worn than before. I'll do a full inspection tomorrow. |
07-27-2014, 07:59 PM | #90 |
Photo dump! Photography credit: Ruel Felipe |
07-27-2014, 08:06 PM | #91 |
We swapped the stock bumper out for an Exo bumper. Wanted better approach and a tighter fit when running our aluminum hood. I was gonna swap the toe blocks and all but forgot a couple small pieces when I ordered everything for the swap. All I had to do to fit the Yeti for now was bolt in the Exo upper bumper support and grind the inside mounting edges of the lowering to for the width of the Yeti mount. Also if you want to run the stock shell, remove the grill and headlights from the body. We've also had a problem with the driver side, lower control arm pivot screw, backing out. Tonight I drilled and installed a set screw in front of the head of the screw to prevent it from backing out. I'll get a pic tomorrow. |
07-27-2014, 08:44 PM | #92 |
Newbie Join Date: May 2014 Location: Korea
Not sure if it's possible with the yeti/exo knuckles, but a common fix for the same problem on a slashe is to install that pin from the front instead of the rear (or vice versa if normal installation is from the front). Something about the motion of the arms causes the screw to turn, so flipping it causes it to tighten instead of loosen
07-27-2014, 09:01 PM | #93 | |
| Re: Messing with Sasquatch: CFM's Yeti Quote:
Not possible on the Yeti. It threads in from the front and there is not a nut in the backside that would allow you to simply flip it around. | |
07-28-2014, 07:30 AM | #94 |
Our friend Ruel with Broken Rule media has started playing with some video editing from yesterday. http://m.youtube.com/watch?v=vDN31fr...ature=youtu.be |
07-28-2014, 07:59 AM | #95 |
Quarry Creeper Join Date: Mar 2013 Location: Feather river canyon
Man, that looks great.. I like the spare tire on there and those panels look great, looking forward to getting my hands on one.. Also that exo front bumper looks clean, does it fit with no mods?
07-28-2014, 09:05 AM | #96 |
| Re: Messing with Sasquatch: CFM's Yeti Throw a M3 Nylon locking nut in the chassis pocket. The plastic one is used to avoid cross threading and holds pretty well. The nylon locknut will eliminate your issue, just be careful and make sure its lined up. |
07-28-2014, 10:01 AM | #97 | |
Good to know. Hadn't investigated further to see if there was a way to get something in there. | |
07-28-2014, 06:20 PM | #98 |
| Re: Messing with Sasquatch: CFM's Yeti I did this to mine and Jason's while we were in Colorado. It's a pain to fish in there but pretty overall an easy and cheap fix!
07-28-2014, 06:48 PM | #99 |
Stainless front link kits are live on our site! http://carterfabmachine.com/?product...front-link-kit |
07-30-2014, 01:53 PM | #100 |
Pebble Pounder Join Date: Feb 2012 Location: Riverside
Woohoo. Ordered mine!!
Messing with Sasquatch: CFM's Yeti - Similar Threads | ||||
Courier Sasquatch | 66sprint6 | Axial SCX-10 | 13 | 03-17-2011 08:20 PM |
Sasquatch sited on RCC Live! | badger | Chit Chat | 4 | 03-01-2009 07:05 AM |
Super Sasquatch | Terminator13 | Tamiya Clod Buster | 23 | 12-04-2008 06:26 PM |
just messing around | ToTheMAXXcrawler | Newbie General | 7 | 03-09-2006 06:22 AM |
