08-03-2014, 02:31 PM | #121 |
Quarry Creeper Join Date: Jun 2008 Location: LaPorte
| Re: Messing with Sasquatch: CFM's Yeti
Wow that's impressive! !
08-03-2014, 02:38 PM | #122 |
Rock Stacker Join Date: Mar 2011 Location: Dunlap
I can't believe how bright theu are from the vid. When will vp have them in stock? I seen they were added to the site.
08-03-2014, 06:03 PM | #123 | |
| Re: Messing with Sasquatch: CFM's Yeti Quote:
Those tiny pods put the headlight system for my Mt. Bike to shame! | |
08-04-2014, 07:20 AM | #124 |
Metal shaper Join Date: Dec 2008 Location: Hog Eye, Texas
Took some flight lessons yesterday at a new local spot with some awesome terrain. Will be plenty more pics and videos later this week. |
08-04-2014, 07:25 AM | #125 |
Newbie Join Date: Jan 2011 Location: italy
| Re: Messing with Sasquatch: CFM's Yeti |
08-04-2014, 07:43 AM | #126 |
08-04-2014, 10:23 AM | #127 |
Looks like you can Send her pretty good! !!!
08-04-2014, 02:09 PM | #128 |
The 17t doesn't have quite the motivation to huck it on 3s so we swapped in a 4s lipo for some fun. I've never ran 4s before as there just hasn't been a need. I'm sold now. I was gonna step into a new motor but gonna just grab a few 4s lipos for now. Much cheaper.
08-04-2014, 02:12 PM | #129 | |
RCC Addict Join Date: Mar 2012 Location: Under a Rock in North Texas
08-04-2014, 02:18 PM | #130 |
Roc412 or pro4hd
08-04-2014, 02:25 PM | #131 |
08-04-2014, 02:46 PM | #132 |
| Re: Messing with Sasquatch: CFM's Yeti Yes. I think Harley has just swapped one in so we'll see what he thinks of it. The Tekin Gen2 17t Redline we are running is definitely not quick enough for me, stock motor is fast and spoiled me, but it crawls very well and hasn't let me down other than big air. Running it on 4s out a smile back on my face and with the 2speed option later, thistle maybe just fine by being able to hear a little higher since we'll then have a low range. Doesn't run to hot on stock hearing now. Do have a fan on the motor. The 550 can or Roc412 maybe better suited long term just for the added weight the cars take on with upgrades. |
08-04-2014, 02:55 PM | #133 |
Sway bar quick disconnect kits are now available on our site. Available in raw or anodized black. These function the same as a 1:1 kit does. The bolt that attaches the axle link end, is replaced with a machined stainless pin and clip. There is a machined 6061 upper mount that bolts into the factory chassis with included hardware. To disconnect sway bar: Pull clip from pin on each side Rotate sway bar up so links align with new upper mounts Insert pins through mount securing sway bar in its new position No tools required on the trail and nothing to remove and possibly lose. No interference during suspension cycle and you can still run a spare tire. This mod is for the guys wanting to lock the front diff and really focus on crawling or guys that like watching things get twisty or carry a tire through a high speed corner Baja style. And it's just cool! |
08-04-2014, 03:48 PM | #134 |
RCC Addict Join Date: Aug 2012 Location: Philippines
Hot dayum that is a trick product!
08-04-2014, 10:26 PM | #135 |
Quarry Creeper Join Date: Jun 2006 Location: Aurora, CO
Can you take some pictures of the sway bar disconnect with the body removed? It's a little difficult to see where everything connects up. That's awesome though! Yet another item that I didn't realize I wanted for my truck, but now really do!
08-04-2014, 11:58 PM | #136 |
Pebble Pounder Join Date: Dec 2013 Location: Keller
| Re: Messing with Sasquatch: CFM's Yeti In the photos provided the sway bar links are connected/tucked away in the CFM aluminum mounts. Otherwise the sway bar links would be connected at the axle.
08-05-2014, 12:11 AM | #137 |
08-05-2014, 07:04 AM | #138 |
I will get some pics of the mounts on without stock body. I'll do my best to get a pic if the sway bar connected flex, broke a universal this weekend and my helper tire it down yesterday. I'll get him to throw the stock stub in it so we can.
08-05-2014, 09:56 AM | #139 |
Quick damage report so far on the Yeti. We have been rough on this rig since it came out of the box. We have nearly a month of runnin the truck hard on rocks, sand, asphalt, mud, light water crossings, and big air jumps. So far the only parts that completely failed were a broke female spline WB8 HD shaft. Parts that wore out and needed replacement were the plastic bushings in the steering rack that are on the steering post. A quick bearing upgrade fixed this and VP has already released a post/bearing upgrade kit. Parts that have been damaged but could have "kept" going are the lower trailing arms and one of the upper links that got gouged. The rear trailing arms started to buckle after very hard launches on asphalt and more extreme Rock situations. The asphalt was also the demise of the drive shaft. We also broke a front universal during a big air jump that had a rough landing and tumbled badly. We were also running 4s at the time. |
08-05-2014, 10:00 AM | #140 |
Trailing arm issue has been solved and will be the only set of arms ever needed. The prototypes have proven themselves thus far and the final versions will be tig welded and left raw for sex appeal. They may be a limited run item due to the work involved in a fabricated trailing arm unless demand says otherwise. |
Messing with Sasquatch: CFM's Yeti - Similar Threads | ||||
Courier Sasquatch | 66sprint6 | Axial SCX-10 | 13 | 03-17-2011 08:20 PM |
Sasquatch sited on RCC Live! | badger | Chit Chat | 4 | 03-01-2009 07:05 AM |
Super Sasquatch | Terminator13 | Tamiya Clod Buster | 23 | 12-04-2008 06:26 PM |
just messing around | ToTheMAXXcrawler | Newbie General | 7 | 03-09-2006 06:22 AM |
