05-08-2012, 10:22 AM | #1521 | |
| Re: GT3B Hack Question and Answer Thread Quote:
What are your settings and which firmware are you using? | |
05-08-2012, 05:06 PM | #1522 |
I'm running the 3 channel 0.4.1 firmware. For settings I"m using your recipe for dual esc setup.
05-08-2012, 08:28 PM | #1523 |
Quarry Creeper Join Date: Oct 2011 Location: in the 7eventh level of hell
ok im just going to ask. where is the this is how you install the hac kit page. or is there a video or what. please dont beat on me to bad. ijust want to get this installed as quickly as possible.
05-08-2012, 11:45 PM | #1524 |
Quarry Creeper Join Date: Mar 2012 Location: Roseburg
Take a look at overkillrc. He's got all the info you need there.
05-09-2012, 04:42 AM | #1525 | |
05-09-2012, 09:42 AM | #1526 |
Newbie Join Date: May 2011 Location: orangevale
ok dont burn me up on this one but im trying to bind my gt3b and i watched a video on how to do it but all i get is steering and no throttle. anybody know what the hell im not doing or what i need to do to get this to work properly. my bad if this question is not in the right thread . thx for the help. |
05-09-2012, 09:57 AM | #1527 |
Pebble Pounder Join Date: Sep 2011 Location: Joliet
Bind plug channel three, plug battery in battery port, turn on radio.
05-09-2012, 10:07 AM | #1528 |
It took a couple of attempts to get mine to bind.
05-09-2012, 10:52 AM | #1529 | |
Rock Crawler Join Date: Oct 2006 Location: Fernley
Make sure you turn everything off and take the bind plug off. Then turn everything back on, it should be good. This stumped me for a second once. Just one of those brain farts. But if I remember correctly that is the way it acted if you try to use it with out resetting everything. | |
05-09-2012, 10:54 AM | #1530 |
i cant get this to do nothing on my pc that it shows in the instructions.
05-09-2012, 01:39 PM | #1531 |
| Re: GT3B Hack Question and Answer Thread |
05-09-2012, 02:29 PM | #1532 | |
Stupid question on my part, did you calibrate the ESC to the RX once it's bound?? I'm guessing "no", since you have steering I believe the radio is fine, now fix the ESC. | |
05-09-2012, 07:12 PM | #1533 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
| Re: GT3B Hack Question and Answer Thread I've had these for at least two weeks now. Credit goes to Freq-E-Skinz for the template and kick ass designs. My camera is slowly dieing and the photos don't properly display the high quality of these skinz. They are so nicely done it's time to spread the word. Below is my TX with all my sponsors: My baby mama's TX : Gavin's TX: |
05-09-2012, 07:30 PM | #1534 |
Rock Crawler Join Date: Oct 2011 Location: smithville
Wow those are nice, a lot better than some of the cheesy stickers on it.
05-09-2012, 07:33 PM | #1535 |
Rock Stacker Join Date: Jul 2008 Location: tulsa
My gt3b is not hacked, haven't really needed to yet since I'm only running throttle and steering at the moment. But I'm having some issues and was hoping someone on here could help me figure it out. I have had the radio for about 7 months now and it has worked perfectly every time but today. When i turn on the radio and car every thing works fine for about 15-30 sec, then it stops and starts glitching. Goes forward on its own, no steering and sometimes when it's acting funny i can turn the wheel and make it stop going forward or backwards. If I turn off the radio and turn it back on it all goes back to normal for a few seconds then does it all over again. I took the radio apart to make sure nothing was loose since I did drop the radio a few months back but i see nothing loose or broke. plus after the drop the radio has worked perfectly for months with out a problem. Also the voltage on my batteries were at 10.7 if that info helps. I also did rebind the radio and reciever together and I'm still having the same problems. Is it my radio or the reciever. |
05-09-2012, 07:37 PM | #1536 |
| Re: GT3B Hack Question and Answer Thread Thank you and I totally agree with you. The radio skinz took the GT3B from feeling like cheap chinese junk to feeling like a higher level, custom radio. I know it's just for looks, but I think it really improved the look of the GT3B. Freq-E-Skinz even included clear screen protectors that fit his skinz exactly. Freq-E-Skinz quality & attention to detail is unmatched.
05-09-2012, 07:46 PM | #1537 | |
It looks alot better than the cell pics you sent me Might be a good idea though to have a cutout where the programming slot is. Quote:
05-09-2012, 07:53 PM | #1538 | |
Have you mounted up those cut n shut tires I made you yet? I'm eager to learn how they perform for you. | |
05-09-2012, 07:57 PM | #1539 |
05-09-2012, 08:12 PM | #1540 |
OK just put another radio system in my truck and i'm still having some issues but not as bad. Since it doesnt seem to be the radio i will start a new thread.
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
