Thread: Team Brood Motor Tech Thread
Old 08-10-2013, 06:02 PM   #61
Default Re: Team Brood Motor Tech Thread
Originally Posted by ik632 View Post
You going to post pics of my motor build? Or is a 35t Chaos too boring?
ROWDY RACING is offline   Reply With Quote
Old 08-11-2013, 07:21 PM   #62
Originally Posted by EddieO View Post
I've tried it both ways. The slot car guys insulate both sides. I've done both sides, but the problem is our springs are different with the bend so finding an insulation that fits the bend on the brush isn't very easy. I've tried lots of stuff, with little luck.
After some tests, while power still can flow into it, it doesn't actually conduct anymore, so heat is less. It's even less heat if we do both, but something is better than nothing...
Later EddieO
If you can make/find some delrin (or plastic) spring post, or even insulate the spring post. You might get some improvement in this matter.
Colgout is offline   Reply With Quote
Old 08-11-2013, 07:24 PM   #63
The posts on most motors using the insulation is anodized, so it doesn't conduct anyways.........
I don't think a delrin one would work so well, as I can't imagine the delrin being strong enough to not bend under the tension of the super heavy springs.
Later EddieO
EddieO is offline   Reply With Quote
Old 08-13-2013, 05:23 AM   #64
New goodies going out the door.
First a set of Stubbies (Conflux version) for Hulksta
FB9 Quad Magnets
Stubby .020 Can Coated
729 Standup Brushes
Team Springs with Insulation
Lightweight Spring posts, Elimination Screws, Endbell Screws, and Timing Ring
30t HHK-T Armature Epoxy Balanced
Later EddieO
Got them today, thanks for the quick turnaround, didn't expect to see them so fast.... My pants got a few sizes smaller as I opened the box Cant wait to comp with them, they feel like they have way more power over my old 2010LE's Thanks man
Hulksta is offline   Reply With Quote
Old 08-15-2013, 12:35 AM   #65
Crap ton of motors going out. Just finished a large batch prior to this, but for some reason my phone deleted the pics. Off to Disneyland on monday!
Up first is a Stubby going to the land down under
FB9 Quad Magnets
Stubby .030 Can with Rust Preventive Coating
729 Standup Brushes
Sisu for Tedrockz
Sisu .030 Can with Rust Preventive Coating
35t 28mm Stubby arm Drill Balanced
Dual CB20 Magnets
Ceramic Bearings
Team Firm Springs with Insulation
Lightweight Spring Posts
729 Standup Brushes
Lightweight Heatsink Elimination Screws
Lightweight Endbell Screws
Lightweight Timing Ring
Sisu for Racer_ZH Super
40t 28mm Stubby arm Drill Balanced
Dual CB20 Magnets
Ceramic Bearings
Team Extra Firm Springs with Insulation
729 Standup Brushes
Sisu for Diamond D's Super
Stubby Can with Rust Preventive Coating
Dual CB20 Magnets
Custom Reversed Spring Setup
767 Laydown Brushes
Vapor for Farmerton
FB9 Dual Magnets
729 Standup Brushes Team Modified
35t HHK-T Armature Epoxy Balanced
Vapor Pair for Crawl-O-Matic
FB9 Dual Magnets
729 Standup Brushes
Purple Springs
35t T-LP Armature Epoxy Balanced (Flatwire Arm)
Stubby Pair for Dlux
Stubby Can
FB12 Dual Magnets
767 Laydown Brushes
Old 08-15-2013, 11:30 AM   #66
TEDROCKZ is offline   Reply With Quote
Old 08-15-2013, 11:45 AM   #67
Wanna get? Gotta want.
Erik D_lux's Avatar
Wow! Busy guy!
I am loving the reversed spring mod!
Cant wait to get these motors in and running!
Erik D_lux is offline   Reply With Quote
Old 08-15-2013, 04:57 PM   #68
pretty cool stuff! can you list some of the details like weight and no load current of these new ones? i am looking at getting something nice for my trail rig.
"custom" reverse springs you mean old trinity hoods and springs?
why the spring isnsulation? ive never once had a spring get warmer than the endbell in a crawler. slot cars we used to do it all the time cause they would get hot without shunt wires especially.
Haltered is offline   Reply With Quote
Old 08-15-2013, 05:03 PM   #69
I didn't measure everything.
Racers Sisu weighed about 150g each. No load amp draw was around 2 amps at 3 volts.
Tedrockz sisu weighed about 155, drew around 2.2 amps
Vapors weigh around 156 or so.
Stubby's Weigh around 130g or so. 30t arms typically can draw around 1.7 amps, 35t around 1.5 amps.
Amp draw varies based on the arm, magnets, etc.
For a trail rig I would look at our new Axle Buster coming out or a Foresaken with cobalts....
Spring insulation just keeps them cool, just like a slot car uses them. Some of the motors get hotter than others, so it just an upgrade some people get for add insurance against the spring losing tension from heat.
Later EddieO
Old 08-15-2013, 05:10 PM   #70
Awe man my cans (.)(.) didn't make the picture thread? HAHAHAHA kidding got my motors and those Cobalts are no joke. Thanks a ton!
Curcal is offline   Reply With Quote
Old 08-15-2013, 05:12 PM   #71
Yers is in post 51. I could only take a pic of one though, as they want to hump each other if they even get close.
Later EddieO
Old 08-15-2013, 05:26 PM   #72
I went back a page and saw them. I tried to grab a weight of one of these motors and the scale was nearly lifting off of the table.
Old 08-15-2013, 08:04 PM   #73
I really have to stop reading this thread......
Just a question......or 2...
Why are the sisu armature drill balanced? Is it because it so jam packed in the can that there is not much space for the epoxy?
Also there are a few different endbell used on the sisu, what is the benefit of the different endbell (like the reverse spring mod thing)?
Old 08-15-2013, 09:22 PM   #74
They are drill balanced because they already make so much damn torque that gaining a little free rpm by drill balancing works for me, on top of them being heavy enough that I figured why add more weight. They are totally able to balance with epoxy though.
Most sisu have the sagami endbell, but a few I used a modified endbell that weighs less and can fit the reversed hoods easily. They don't work easy on the sagami endbell cause of the brush dampener system....all only temp though, the new endbell design is done. I got some 3d samples printed, fixed a few issues....final samples are coming as we speak, then production will start next month. I was hoping to have some at nats....we will see. They are very light, low profile and use existing hardware....well one version does.
The reverse endbell gets the springs and posts up away from the rocks, while removing the tabs that get hung up on rocks. Most motors I get in for rebuilds are often missing a tab from it getting caught.
Later EddieO
Old 08-15-2013, 09:33 PM   #75
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Cool stuff man, glad to see you putting so much thought into the motors!
JohnRobHolmes is offline   Reply With Quote
Old 08-15-2013, 09:35 PM   #76
Thanks.. Reading your post learn more about high end brush motor then my previous 10 months working experience in Johnson Electrics (one of the major maker of silver can 540)....
Old 08-16-2013, 04:38 AM   #77
What does the reverse end bell or spring do?
I on tabs do you just cut of those two unused ones?
sally1800 is offline   Reply With Quote
Old 08-16-2013, 06:22 AM   #78
What springs do you use for the reversed setup?
Calderwood is offline   Reply With Quote
Old 08-16-2013, 06:24 AM   #79
Old 08-16-2013, 06:39 AM   #80
Originally Posted by nigels_world View Post
Thanks I kinda answered my own question.
Team Brood Motor Tech Thread - Similar Threads
Look at the new Stubby motor that Team Brood has in the works... BigBlackCummins Electronics 5 06-26-2012 10:13 PM
Team Brood Frenzy Mini-Motor! EddieO Vendors Electronics 5 05-30-2012 08:00 AM
