11-14-2013, 01:00 AM | #121 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
| Re: Team Brood Motor Tech Thread
Tons of new motors going out. Lots of cool stuff.... Chaos pair going to Utah... Chaos Can C6 Dual Magnets 729 Standup Brushes Purple Springs 35t HHK-ST Armature 7.5mm Comm Epoxy Balanced Stubby pair going to Australia Stubby .020 Can Coated Motor Armor FB9 Quad Magnets Shaved Tips 729 Standup Brushes Team Extra Firm Springs with Spring Insulation Lightweight Spring posts, Elimination Screws, Endbell Screws, and Timing Ring Ceramic Bearings 30t HHK-T Armature 7.5mm Comm Epoxy Balanced Vapor Pair going up north to canada Vapor Can with Motor Armor FB9 Quad Magnets Team Laydown Brushes Team 150 Firm Lightweight Spring posts, Heatsinks, Endbell Screws, and Timing Ring ABEC 7 Bearings 35t HHK-T Armature 7.5mm Comm Ground Polished Dyed Epoxy Balanced Apocalypse up to canada too for the shafty. Apocalypse Can FB9 Dual Magnets Team Laydown Brushes Team 150 Firm Lightweight Spring posts, Heatsinks, Endbell Screws, and Timing Ring ABEC 7 Bearings 35t HHK-T Armature 7.5mm Comm Ground Polished Dyed Epoxy Balanced Stubby pair going to Harvo Stubby .020 Can Coated Motor Armor FB9 Quad Magnets Shaved Tips Team Brushes 175 Extra Firm Springs with insulation Lightweight Team Spring posts, Elimination Screws, Magnesium Timing Ring, Cut Brushhood Heatsinks, SS Cap Endbell Screws Reverse Spring mod Ceramic Bearings 35t HHK-T Armature 7.5mm Comm Epoxy Balanced Stubby pair going to Europe Stubby .020 Can Coated Motor Armor FB9 Quad Magnets Shaved Tips Soaked and Baked 767 Brushes Team Extra Firm Springs with insulation Lightweight Team Spring posts, Elimination Screws, Aluminum Timing Ring, Cut Brushhood Heatsinks Ceramic Bearings 30t HHK-T Armature 7.5mm Comm Epoxy Balanced Diamond D's new stubbies.... Stubby .020 Can Coated Motor Armor FB9 Quad Magnets Shaved Tips Soaked and Baked 767 Brushes 175 Extra Firm Springs with insulation Lightweight Team Spring posts, Elimination Screws, Aluminum Timing Ring, Cut Brushhood Heatsinks, SS Cap Endbell Screws Reverse Spring mod Ceramic Bearings 35t HHK-T Armature 7.5mm Comm Epoxy Balanced ClassiCutCustoms new shafty motor Vapor Can FB9 Dual Magnets 729 Standup Brushes XHeavy Springs Firm Lightweight Spring posts, Elimnation Screws, Endbell Screws, and Timing Ring Ceramic Bearings 30t HHK-T Armature 7.5mm Comm Ground Polished Dyed Epoxy Balanced Last edited by EddieO; 11-14-2013 at 01:05 AM. |
11-14-2013, 02:48 AM | #122 |
RCC Addict Join Date: Dec 2009 Location: Newcastle, Australia
That's a lot of power for one post! It almost screamed right off the page! |
11-14-2013, 06:16 AM | #123 |
| Re: Team Brood Motor Tech Thread |
11-14-2013, 10:54 AM | #124 |
There was actually a whole batch I spaced on pics for, including the first production maelstrom....along with some axle busters, sisu, etc. I suck....just been a really strange 45 days at this point.... Later EddieO |
11-14-2013, 11:01 AM | #125 |
11-15-2013, 09:38 AM | #126 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
Mr Eddie, For the knowledge impaired (me) regarding GOOD QUALITY motors, can you talk the difference between a stock axial stamped closed bell motor and a precision crafted motor relative to performance characteristics? Basically, I want to replace 2 of my RC motors and I am COMPLETELY lost. I have a stock 27T axial motor in my 2s AE-2 wraith (18/87 gears) and I love its performance...speed, torque, overall power (its worked for 6 months now). I want a quality motor that I can trail run for 3-4 hours at a time, once or twice a week and still play on the rocks at the local park. The 27t does what I want but at some point, its going to poop the bed and I want something of equal performance characteristics that I can install and not have to think, "Is it going to die on this trail run". My other motor is in my AR60 based shafty crawler. I currently have a 2s 55T Novak crap can with a 12/96 gear on a micro sidewinder. I know, way too much torque and no wheel speed. I want more wheel speed on 2s and same torque. any more torque and I'll rip apart my rig. I will be changing the gears depending on the motor. Again, budget build, NON COMP rig - crawler for the rocks at the local park only - no comps. Not sure if your motors are where I should be looking since you typically build high end crawler motors. Any information would be helpful. Hey, Look here....Happy Thanksgiving, Jack |
11-15-2013, 02:08 PM | #127 | |
| Re: Team Brood Motor Tech Thread Quote:
11-15-2013, 05:31 PM | #128 | |
11-15-2013, 06:01 PM | #129 |
It still seems strange that it's losing power already. I certainly don't baby it, but I don't abuse it either. The com does have a black spot on it though. Maybe it's time to buy a com lathe and learn how to turn it |
11-16-2013, 12:10 PM | #130 | ||
I rate using emery cloth right up with water break in! BAD! You typically end up doing more damage than good. Time to buy a comm lathe. You can typically find them for under $50, even brand new. They are easy to use, I showed my wife how to cut a comm in about 5 minutes...... Quote:
A good quality handwound or machine wound is a big difference from the sealed can stuff. One biggie is that you can rebuild them and/or change up the configuration if you want. The sealed can stuff is typically made as cheap as possible. Crappy armature balancing, comm termination, epoxy, etc. All these shortcuts lead to a motor that simply does not perform as well a handwound or a rebuildable machine wound. For the wraith, any brushed motor is gonna need to be taken care. Don't take care of them and they will fail....some guys go years with no problems. Luck more than anything, not the quality of the motor. Simply cleaning it out with motor spray and compressed air goes along way in keeping them running good. While some wraith guys go with handwounds, the Specter 30t Type HHK-T is a popular choice. Many just go with machine wounds, the Intensity 30t is super popular with the Wraith crowd. Gearing is CRITICAL in a wraith. You must adjust it so you don't overheat the motor. A bad misconception in crawlers is that all motors use the same gearing. (15/87 is a good place to start on the 30t). The AR60 shafty I would grab a 35t motor. Intensity Machine wound is a good choice if you don't wanna spend a ton. You can always upgrade to handwound later. You are not comping with it and being on a budget, a handwound is not overly necessary. Later EddieO | ||
11-16-2013, 06:33 PM | #131 |
I can't put a price tag on that reply....Worth millions if I had to try! Thank you so much. I'll surf the web and check to see if the Air Force gave me enough money to get things moving. If not, it will be a few weeks! Again, thanks so much, that's Exactly what I was looking for! |
11-28-2013, 08:54 PM | #132 |
How would I know if I got a reverse rotation motor? I bought an "Intensity 35t" and when I installed it, I had to reverse the throttle/reverse operation on my controller. I had a Novak 55T before. Are either one of those motors reverse? |
11-29-2013, 08:26 AM | #133 | |
Matched MOA sets (ordered as sets) will have a marking on which is which. Could be a label, marked on can or marked on motor shaft. Options to reverse a brushed motor: Rotate endbell 180* Swap motor wires (black wire on red motor post, red wire on black motor post) Reverse ESC & TX I usually just swap wires. | |
11-30-2013, 11:11 AM | #134 |
12-11-2013, 06:17 PM | #135 |
RCC Addict Join Date: May 2012 Location: Folsom
| Re: Team Brood Motor Tech Thread Quote: |
12-11-2013, 06:45 PM | #136 | |
12-11-2013, 07:10 PM | #137 |
Good I idea! I'll give that a shot for sure. The motors drive the car really well, but when I stop and start up again they have a build up and slight jerk before they smooth out again. I'm in about 20% throttle when it kicks off. Thanks for the suggestion Rowdy!
12-11-2013, 07:13 PM | #138 |
| Re: Team Brood Motor Tech Thread No prob, should smooth things right out.
12-11-2013, 11:08 PM | #139 |
Adjusting the radio and esc can often help with start up...many people typically have the settings fairly harsh. Messing with the gearing can also help slow down the startup, which is sort of the nature of the beast with the cobalts. Once I had my stuff set correct the start up on mine was pretty smooth. Later EddieO |
12-12-2013, 12:12 AM | #140 |
First a big order going out to Japan, seems some other motors were not pulling their weight. A combo of conflux and stubby motors, along with a special pair for the big kahuna. Stubby .030 Can Coated FB9 Dual Magnets Standup 729 Brushes XX Heavy Springs Lightweight Spring posts, Elimination Screws, Aluminum Timing Ring, 12.9 Cap Endbell Screws Ceramic Bearings 16t CVR Armature 7.5mm Comm Drill Balanced Conflux .020 Can Coated FB9 Quad Magnets Standup 729 Brushes XX Heavy Springs Lightweight Spring posts, Elimination Screws, Aluminum Timing Ring, 12.9 Cap Endbell Screws Ceramic Bearings 16t CVR Armature 7.5mm Comm Drill Balanced The big guys Stubbies….full team treatment. Stubby .020 Can Coated Motor Armor FB12 Dual Magnets Shaved Tips Laydown Putnam Brushes 175 Extra Firm Springs with insulation Lightweight Spring posts, Elimination Screws, Magnesium Timing Ring, Cut Brushhood Heatsinks, Armor Plated Cap Endbell Screws Reverse Spring mod Ceramic Bearings 15t CVR Armature 7.5mm Comm Drill Balanced Lastly a pair of Conflux that went off to Europe Conflux .030 Can Coated Motor Armor FB12 Quad Magnets P-94 1201 Brushes with P-94 Brush hoods Team 175 Springs with Insulation Lightweight Spring posts, Lightweight Heatsinks, Aluminum Timing Ring, Cut Brush Hood Heatsinks, SSCap Endbell Screws Ceramic Bearings 35t HHK-ST Armature 7.5mm Comm Ground Polished Dyed Epoxy Balanced |
Team Brood Motor Tech Thread - Similar Threads | ||||
Look at the new Stubby motor that Team Brood has in the works... | BigBlackCummins | Electronics | 5 | 06-26-2012 10:13 PM |
Team Brood Frenzy Mini-Motor! | EddieO | Vendors Electronics | 5 | 05-30-2012 08:00 AM |
