04-16-2013, 01:51 PM | #141 | |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
| Re: Stubs **Dlux axle** superlite Quote:
I already cut the windows out of it! I just like the look of it to much to get to crazy on it. | |
04-16-2013, 02:06 PM | #142 | |
04-16-2013, 04:12 PM | #143 |
| Re: Stubs **Dlux axle** superlite |
04-16-2013, 05:45 PM | #144 | |
Back on topic.... got those motors dialed in yet Stubs? | |
04-16-2013, 07:38 PM | #145 | |
Because of the mixing on the 6ex I am not sure I can adjust the curve in the radio? I am holding out for a castle link so I can run my micros. It feels pretty go how it is. As I'm getting used to it it's starting to feel a lot better. | |
04-16-2013, 08:23 PM | #146 |
| Re: Stubs **Dlux axle** superlite The 6ex has a setting called 'normal throttle curve' since the mix is from the throttle channel to should carry over. It carries across the mix on my pks. It will be defaulted to 100%, back it off a dramatic amount at first to see the effect, then start at about 85% and see where it goes for ya!
04-17-2013, 12:05 AM | #147 |
| Re: Stubs **Dlux axle** superlite Where might I find this setting? I have been through this radio and never found a expo while mixing and I have never understood why the radio can not adjust that.
04-17-2013, 02:07 PM | #148 | |
I'll see if I can find more info for you. | |
04-17-2013, 02:37 PM | #149 |
I wanna be Dave Join Date: Aug 2007 Location: JERSEY BOONDOCKS
Wish I could help...but I don't habla Futaba |
04-17-2013, 05:43 PM | #150 | |
You don't know what your missin'. | |
04-17-2013, 06:10 PM | #151 |
I am wondering how different a Spectrum radio would be. I think Futaba customer service sucks and would like to get away from them for that reason and since there is not adjusting the mixing. If I were not just getting used to the Futaba right now, I think I would switch anyway. Maybe I will keep an eye out for a used Spectrum and see how it is? |
04-17-2013, 06:12 PM | #152 |
Rock Crawler Join Date: Mar 2009 Location: Irving Texas
WOW!!!! awesome
04-17-2013, 06:36 PM | #153 |
RCC Addict Join Date: Nov 2008 Location: I don't think theres rocks in Florida
So no more rolling your tires over on the rims? Glad you got your foam situation figured out Maybe a 6i would do what you need |
04-17-2013, 07:11 PM | #154 |
Tydl, youre running the Spectrum dx6i?
04-17-2013, 07:43 PM | #155 | |
| Re: Stubs **Dlux axle** superlite Thank you. Quote:
Ya, the foam situation is under control for the most part. I am not again spectrum by any means. I just don't like the size of feel of the 6i. I would try a 7s. I just think the 6ex is a much more comfortable radio to use. And I like the fact that it uses the same battery's as my crawler. | |
04-17-2013, 08:27 PM | #156 |
04-17-2013, 09:16 PM | #157 | |
I do love that the 6ex uses a 3s lipo. Many times I have had my battery go low and I just throw in a used lipo till I get back to my truck. I have always hated that the 6ex does not have expo on the mixing. I think it has been one of my biggest challenges and downfalls to the twin stick. For whatever reason, I have not thought about setting the expo in the ESC itself.... good idea Dicky! | |
04-17-2013, 09:46 PM | #158 |
Quarry Creeper Join Date: Mar 2009 Location: fair oaks ca
I had a dx6i a few yrs ago its a big radio it was hard to flip the swicths on the fly like i can with my 6ex theres a few more mods i had to do to the radio to use it on a crawler. The rear motor stick pod had to be spun so it would self center and the springs are way different then futaba springs they were like a flat spring instead of a coil spring like futaba uses. The 1 thing i did like was u could turn off the rear motor stick so it wasnt live all the time. I dont remember if there was any expo settings in there and i wasnt to hip on radio settings not that im any better now but i can figure it out now. Theres a little info on the radio from some personal experiance
04-17-2013, 10:53 PM | #159 |
Was it this style radio? Just doing a quick search it looked like they changed styles of radios. I only really use one button on mine, it might be easy enough to just drill a hole and put it anywhere I want? Looks like they can be found all day long used for $100 and the receivers are dirt cheap around $30 new. |
04-18-2013, 01:51 AM | #160 |
yah thats what it looked like, i could have been mistakin on which stick pod had to be flip it lookin more like the front motor/front dig pod would be the 1 that needs to be flipped so it self centers
Stubs **Dlux axle** superlite - Similar Threads | ||||
axle stubs? | jokers_toys | Redcat Crawlers | 5 | 11-18-2011 09:48 PM |
CVD axle stubs are different???? | RickM | Team Losi Comp Crawler | 3 | 08-13-2011 05:31 PM |
Looking for axle stubs | cartronicshn | Tamiya TLT Crawlers | 11 | 08-11-2010 12:20 PM |
Blakcfoot axle stubs | scruff007 | Tamiya TLT Crawlers | 6 | 12-06-2006 01:24 PM |
