09-05-2005, 01:47 PM | #121 | |
Rock Stacker Join Date: Aug 2005 Location: Mesa
Replacement drive belt source? I found a replacement belt for the rear after looking through a selection of VCR belts my local Fry's Electronics had. It is PRB Line part # SCA6.7 Its about $1-$2 depending on where you find it. Last edited by datz510; 09-05-2005 at 01:51 PM. | |
09-06-2005, 01:49 AM | #122 |
Newbie Join Date: Aug 2005 Location: puyallup
in the frunt axle i had the gears in the planetary reduction were the motor goes in at explode! |
09-06-2005, 11:08 AM | #123 |
Newbie Join Date: Sep 2005 Location: Quebec, Canada
| Hi there. Im a newbie here :P I've been reading you for a couple of days. I just bought one 1:6 Jeep yesterday (Went to littleton USA about 2hours from my place). So after 18 LOOONG hours, today, i was crawling rocks backward then the truck just stopped... then start and stoped again... and so on... So i took it and put it in the street in foward and he still doing the same thing... Even on plain surface, backward or foward... Looks like a security cut-out or something like that.... Any idea? *Sorry, my english sucks. I from Quebec. |
09-06-2005, 12:19 PM | #124 |
Double check the battery in your controller. Barring that, you might want to open up the axles to see if there is something wrong inside. Does it seem like an electronic problem or a gear problem?
09-06-2005, 03:54 PM | #125 |
dang i called that number and some guy said i must have the wrong number?
09-07-2005, 10:43 AM | #126 |
I supposed it was doing this because my battery was low... I charge the pack all night then went to a trail and went good for couple of hours I guess... then same again... so... maybe just the batteries. But still, I like a lot this RC... Soon I'll start a make over to make it look like my old YJ... http://i4.photobucket.com/albums/y10...M/DSCF1217.jpg |
09-07-2005, 12:00 PM | #127 |
Rock Stacker Join Date: Sep 2005 Location: Arkansas
I'm losing front axle power when i try to reverse. I took the cover off and made sure everything was tight. There is locktite on the screws and no teeth were missing. I've only run 3 battery packs through it... Other than that, i love it!!! |
09-07-2005, 03:18 PM | #128 |
Quarry Creeper Join Date: Jul 2005 Location: north central IL
Hey ManYum, I'm having the same problem with mine too. Check and make sure your axles are in the same range. Thought that was a problem with mine, but turns out it wasn't. Getting some new parts from Nylint though so hopefully I'll have mine back up in a while. Matt |
09-07-2005, 04:00 PM | #129 |
RCC Addict Join Date: Jul 2005 Location: Provo
well i just go an emaik about my front knuckles and they said that they arent avalaible at this time and that the only way of fixing it was a $70 chassis that really bums me out
09-07-2005, 11:57 PM | #130 |
Awww man.. Thats bad news. :( Is it the knuckles themselves that arent available or the knuckle assemblies? My 1:6 is dead at the moment due to the knuckle pulling itself through the pins. It was only on its 2nd charge too. :( Hopefully they are in the process of working on a new and improved part. I'll cough up $$ if they want it just to have a better part for my truck. Last edited by datz510; 09-07-2005 at 11:59 PM. |
09-09-2005, 10:11 AM | #131 |
Powered by Awesome Join Date: Sep 2004 Location: Parker, Colorado
I had a problem with the pinion gear on the steering motor slipping off... i ended up using shoe goo on the inside of the pinion hole and havent had a problem since... it seems that the grease had worked its way in there and did its job... other than that, i have run @ 6 packs through it and it is workin great... A buddy of mine was over last night and was playin with it... now he's going to go to wally world to buy a 1:18th... awsome product and support. ! A+ in my book Last edited by TwistedXT; 09-09-2005 at 10:17 AM. |
09-09-2005, 05:07 PM | #132 |
Newbie Join Date: Sep 2005 Location: in the woods
| find the pick of the litter when you buy these ok hear goes my breakage story)()() ok for about a year now i have been wanting to get into crawling rc's but i never had the money and when i did i just bought a rtr AHH i know about 5 days ago i seen these things in walmart and i was like ahh junk well turns out that they are pretty great crawlers (with mods ) i bought one 2 days ago the hummer the front gears in the motor kept binding up and i couldent trurn it but when it ran it worked fine i knew it wasent right so i took it apart and then i took the motor apart and found that a gear inside had was to much mesh and was striping so i took the pos back to wally and bought a new one this time its great no problems runs smooth like i said they need revised and stronger parts metal gears atleast i have spare parts gears and crap pm me and we will talk money lol |
09-09-2005, 06:14 PM | #133 |
Pebble Pounder Join Date: Aug 2005 Location: VT Burlinton
I got my parts from them, not bad on the shipping. Got my UPGRADED replacement parts from Nylint today! Stu |
09-09-2005, 09:39 PM | #134 |
Yeah, my front tires will lock up when my steering is at full lock either way. Its really bad in reverse and sometimes going forward. It sucks. Any ideas? Jake |
09-10-2005, 03:39 AM | #135 |
Rock Stacker Join Date: Sep 2005 Location: Ocean beach, San Diego, CA
well i was just tooling around with mine trying to finish draining the battery after its first charge so i can recharge it, and I had it in high range, in reverse, full lock and full throttle and I heard a very nasty popping noise. Seems its coming from the passenger side knuckle, axle shaft, hub area.
09-10-2005, 03:53 PM | #136 |
| I found out that greezzzing the all the gears helps alot i used shock oil guz thats all i had at the time lol but it works great there all good now try it and let me know
09-10-2005, 05:21 PM | #137 |
Rock Crawler Join Date: Nov 2004 Location: Lost in Florida
how long since u email / called them did it take to get the parts?
09-11-2005, 11:42 AM | #138 | |
Stu | |
09-11-2005, 08:17 PM | #139 |
Newbie Join Date: Aug 2005 Location: Chester
Got about four long runs out of my 1/6th and the belt seems to be slipping. My friends just started it the other day.. Besides that this thing is fun for what it is.. About time these toy rc trucks are getting made stronger.. Later |
09-12-2005, 12:05 AM | #140 |
Well i just got my front end torn apart to diagnose the problem. Sure enough, the passenger side knuckle is screwed. the thin metal cup inside that the axle shaft sits in is almost totally reemed out. theres a few chunksw missing too it seems. And for all my effort i was rewarded by accidently jamming a philips head screwdriver through my thumb. I'll post pictures of the hub after i finish cutting my skin with an x-acto knife to pull a chunk of skin out to where it should be and get everything wrapped up.
