06-22-2010, 10:07 AM | #401 |
Rock Crawler Join Date: Nov 2009 Location: Wildwood
Any update on the fast-start? It is really bad with my 6" rovers. Here is a video of mine in action. At about :50 you can see my problem. http://www.youtube.com/watch?v=czolGA8gsv4 |
06-22-2010, 12:40 PM | #402 | |
"HOLLYWOOD" Join Date: Dec 2008 Location: Miami
1 foot that was like 8 feet when it died lolol. | |
06-24-2010, 02:09 PM | #403 |
Just jump it! Join Date: Aug 2008 Location: Cedar City, Utah
Got my replacement ESC today. Working great. Thanks a bunch!! |
06-24-2010, 02:45 PM | #404 |
Nothing has been released yet on the fast start up, but that is the prime focus right now. 1.08 firmware should include both a throttle fix and also throttle curves. After this we are tweaking the build a bit. Also, waterproof ESCs will be available again tomorrow. |
06-24-2010, 02:55 PM | #405 |
Thanks for the awesome customer support. |
06-24-2010, 03:02 PM | #406 |
Kennyj, how much wheelspeed do you have? Is the rig geared pretty tall too? That is one helluva fast start.
06-24-2010, 03:20 PM | #407 |
I have a bunch of wheelspeed. Holmes 45turn motors, 15 tooth front, 14 tooth rear, and 6" rovers. Do you think I will be happy with 1.08 or do I need to gear down?
06-24-2010, 03:22 PM | #408 |
We will see. Do you have a sidewinder or mamba to test how slow it can go with different controllers? It may be the startup speed of the motors causing it as well. I would be using 12t with those tall tires, personally. |
06-24-2010, 03:47 PM | #409 |
What esc would have the best start for my set-up? I don't think I want to lose the speed.
06-24-2010, 03:58 PM | #410 |
Currently, a sidewinder or mamba seems to have the best low end, based on user reports.
06-24-2010, 04:08 PM | #411 |
Would the Sidewinder Micro with external bec be a good option?
06-24-2010, 04:10 PM | #412 |
Can't help you there. Although it should act the same, I haven't used it enough to say for sure. Hopefully I can get this resolved within about three weeks. |
06-26-2010, 04:55 PM | #413 |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
Tried Kenny's BR with 55 turn lathes instead of the HH 45's.....no difference. I swapped Kenny's BR out for mine and mine is much better than his. Still starts up harder than I would like but way better than his. They are set up identical. I loaned him my BR since he only has the one ESC. I have had my BR on my JPH 37's as well. Both BR's have 1.07 Tried my Sidewinder on the JPH 37's and it is hella smooth. I have some great vid of the differences between the 3 ESC's I will post up. |
06-26-2010, 06:08 PM | #414 |
RCC Addict Join Date: May 2010 Location: The heart of the south
Any plans for a brushless version? Looking at the MTroniks G2 Pro but would rather buy yours if you get a brushless waterproof one out. For now, What motor would you recommend with a 2.2 Tuber (Timber Wolf), I want to be able to keep my wheel speed up for Mud and Water. |
06-28-2010, 12:16 PM | #415 |
Rock Crawler Join Date: Feb 2010 Location: costa rica
| Big problem with br-xl
Today I decided to change the ESC of my traxxass summit and use a BR-XL as ESC. The final point was to use the ESC with the stock motor (for now) on 6S. I installed the ESC and tested it with the motor in hand (no load) on 3S. After I realized that everything was working I installed the motor on the car to make a quick test run on 3S and see the performance. After about 5 ft. the ESC cought fire.... with quite a big flame (about 2 in.). This was on flat ground in my shop so not even under heavy load, and with the stock 775 traxxas motor. I am including some pictures of what the ESC looks like now. I would like to know what has caused this, wasn't this ESC supose to handle the load easily??????? I wouldn't even think what could have happend if I hooked the ESC on 6S.... I also would like to know if this can be repaired under warranty... |
06-28-2010, 01:43 PM | #416 | |||
I would get a relatively cheap motor for mud and water. Even a sealed can cheapie would do fine, like a traxxas 27t stinker. Quote:
It should have been just fine, most likely a FET failed in a shorted state and caused the meltdown. Although the waterproof versions have a shorter warranty, I will replace this one with a standard warranty. If you want another waterproof I just ask that you pay for the waterproofing again. Please email me with your info and issue so we can get this taken care of. I will need you to send in the ESC. | |||
06-28-2010, 04:52 PM | #417 |
Well after reading your reply I was foolish enough to try it again with another BR-XL I had on my comp crawler. I installed it in the summit and tested it in my shop on 3S everything looked fine, so I made the serial cable to try the 6S setup... still everything fine, I made short runs for 15-20 sec at medium throttle and than checked the temp on the ESC to see if it got hot... nothing everything fine. So I decided to go out and test it on the road. Well just 2 runs at full trottle of about 100ft and it cought fire again.... I wasn't fast enough to take the body off to avoid some damage on the chassis. Now I got two burnt ESC and a burnt chassis..... ONE thing is for sure.... the BR-XL WONT handle ONE single 775 motor.... I have to send you back the ESC (both) so you can check what blew and why. Anyhow I won't be installing your ESC on this car anymore, I am sure that any future result will be just the same. BTW I sent a contact email... through your web page to see what I have to do to send them back to you. |
06-28-2010, 04:58 PM | #418 |
| It might be safe to say you've found the limit! |
06-28-2010, 05:02 PM | #419 |
Maybe I found the limit but at the cost of two burnt ESC.... I just hope they will get repared or changed....
06-28-2010, 08:39 PM | #420 |
Email back at you.
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/holmes-hobbies/200916-torquemaster-br-xl-big-brushed-power.html | ||||
HH TorqueMaster BR-XL new bad boy esc! | This thread | Refback | 10-04-2011 03:37 PM |
