06-12-2008, 12:01 AM | #921 |
Rock Crawler Join Date: May 2007 Location: Arnold
I would like to try one of the 30 turn motor,I didnt see it on your site will it be a custom wind ,ifso how much and how do I order it. as for vehicle weight about 1.5 pounds tranny reduction 2.19 to tlt axles.
06-12-2008, 12:59 AM | #922 |
Rock Crawler Join Date: Jan 2006 Location: Derbyshire UK
Hello ,I would like to buy a CC BEC, what voltage will be best to run 2x HS-5955TG servo's ?. Do you have them in stock for imMediate shipping ? Regards JOHN. |
06-12-2008, 01:42 AM | #923 |
Rock Stacker Join Date: Mar 2007 Location: portland
| 7T puller gearing
JRH, Thanks For the information regarding 7T puller gearing! I was curious to know what gearing was used in the jumping rock racer featured on the puller video teaser, in the puller thread (first page) one
06-12-2008, 08:34 PM | #924 |
Rock Stacker Join Date: Jan 2008 Location: Reno
| I'm willing to bet that the guy who programmed your ESC set the Lipo cutoff wrong and the speed control is shutting off power to the motor |
06-12-2008, 08:51 PM | #925 |
Rock Stacker Join Date: Mar 2008 Location: inmyhead
Hey John, Got it figured out - the lipo cutoff needed to be adjusted. Runs smooth now. Thanks for the help. -T |
06-14-2008, 09:00 AM | #926 |
Quarry Creeper Join Date: Apr 2007 Location: Katy, TX
Got another one... Last night I had one of my tubers with your 10t cobalt/mambamax/2100mah 3s lipo and I had just charged the pack when I started it up. I bound it up pretty bad and the drive shaft popped off. So, I was holding the rig in my hand and giving it throttle when I noticed at about 75% throttle in reverse I noticed the spinning part of the motor would spark a bit. It wouldnt do it in forward even at 100% throttle. Motor really hasnt had that much use, is this normal? Should I just take it easy in reverse? Thanks man Tyler |
06-14-2008, 08:59 PM | #927 |
RCC Addict Join Date: Feb 2006 Location: ccxc
Not sure if you answered it but looking at the pinion which way should a 7t cobalt rotate?
06-15-2008, 01:10 AM | #928 |
Pebble Pounder Join Date: Oct 2007 Location: Star Prairie, WI
When do you expect to have the Quark 33 Pro Car back in stock? I just found one elsewhere but would prefer to buy from you if you will be getting some soon. Just kinda in a hurry to get one. Thanks Or is there another ESC you would reccomend right now in the same price range? Last edited by rex21; 06-15-2008 at 01:18 AM. |
06-15-2008, 10:37 PM | #929 |
Quarry Creeper Join Date: Aug 2006 Location: Monroe NC
Hey John I need to get a Pro Handwound 540 motor in either a 35 or 45 turn. Any idea as to if an when I could get one? Thanks, Harold |
06-16-2008, 05:19 AM | #930 |
Rock Stacker Join Date: Feb 2007 Location: Soddy Daisy, TN
Hey John i got a quick question for you. i recently purchased a mamba max from you and this is my first experience with any of castles products, the problem im having is getting it programmed. first i tried it on my computer (which is a turd by the way) and it kept saying it was an unrecognized usb device, so i took it to my mothers house (who has a brand new dell) same results, and i even tried it on another computer at work with no luck. am i doing something wrong here or is my esc doa?
06-16-2008, 08:05 PM | #931 |
Winner of the '07 RCC dumbass award! Join Date: Nov 2006 Location: Up on a Mountain, out in the Woods
Can I run 4 cell A123 on Sidewinder / S2221-12? Or would it be more wise to Mamba Max it? Says 15 volt max. 13.2v should be fine right? Doesn't get nearly as warm as the mamba 25 / 2215 @11.1v Any problem with wiring the battery inputs from the Monster Max, CC BEC, and the Sidewinder to one A123 pack? I could make a Y off the Pack to plug in the ESC's Would be VERY nice to have everything run off the one pack. The A123's should handle it right? Not worried about run time since they charge at 10 amp. Also... CC still repairing Mamba 25's? Got one that acts like one of the motor wire is off, happened in the middle of crawling. Temp was 150F. Thanks JRH! WC Last edited by WheelChair; 06-17-2008 at 02:07 PM. Reason: Added max "?" |
06-17-2008, 10:23 AM | #932 |
Quarry Creeper Join Date: Jan 2006 Location: Redmond
I ended up with a Hyperion Z3013-16, can I run it 2S with a Mamba 25 or a Skyone L38? Need to know soon. |
06-18-2008, 07:40 AM | #933 |
John must be a busy man. He is always "Johnny on the spot" |
06-19-2008, 08:39 AM | #934 |
I wanna be Dave Join Date: Jan 2008 Location: Arat Alabama
When are you getting more FXr's in? Sorry if this has been posted I looked and did'nt see it
06-19-2008, 08:47 AM | #935 | ||||||||||
I have some 30t being wound right now actually, should be done in a few days and in my hands within a week. Quote:
Castle does repair the m25's still. Give em a ring or send it in with the proper repair form filled out. http://www.castlecreations.com/support.html Quote:
If you use it on 2s you might not get very smooth throttle initially. | ||||||||||
06-19-2008, 08:48 AM | #936 |
06-19-2008, 10:29 AM | #937 |
Thanks as always man tyler |
06-19-2008, 02:06 PM | #938 |
Thanks again John! I did not think there would be a problem but I wanted to clear it with the master! Thank you for your time to answer! I know your a busy man! WC |
06-20-2008, 08:36 AM | #939 |
Holmes Hobbies Join Date: Jan 2007 Location: No Where
When you gonna get the Mamba Maxs in stock? I need a couple of things and I want to order them all a the same time,Mamba Max,Bec and a servo. |
06-20-2008, 02:32 PM | #940 |
Newbie Join Date: Apr 2008 Location: manahakin
| battery i just ordered
battery i just received it yesterday i wanted to know what rate i should charge it at i ordered the 8.4v saddle pack . also i want to eventually get your cobalt puller 7t i have a tazer 15t will this esc work when i finally get 7t?
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
