04-09-2016, 06:36 PM | #261 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
| Re: RC4WDs New Micro Crawler
Ahh nvm I just re read your reply. Its not quite a divorced stock setup, you added in the losi transmission for more reduction. A 59t spur would need a little filing and grinding to fit,but would still work
04-10-2016, 07:34 PM | #262 |
Rock Stacker Join Date: Mar 2016 Location: OK
Friends in the UK, what are you paying for these? I saw one pop up on ebay (location was Liverpool), a little on the high side, and made an offer that was very reasonable. He declined it and upped the price to 250 GBP! Now it's gone. Hoping he was just a price gouger! I hope no one paid that much!
04-11-2016, 01:21 AM | #263 | |
Newbie Join Date: Feb 2011 Location: new zealand
| Re: RC4WDs New Micro Crawler Quote:
04-11-2016, 02:41 AM | #264 | |
Rock Stacker Join Date: Apr 2016 Location: U.K.
By the way, have you heard anything about a suitable replacement motor for the stock one? apart from the extensive discussions here in the forum...which is great Last edited by Aeronuclear; 04-11-2016 at 02:43 AM. | |
04-11-2016, 04:02 AM | #265 |
As far as I know the only motor that bolts on is the same motor it came with but there are no better versions of that motor that I know of. I did however manage to bolt with 1 bolt a Losi motor from a trail trekker with the smallest available pinion that losi makes for it, might have been a 8 or 9 tooth and it seemed to provided more power. That's all I know of in the way of motors so the next step up would be a divorced setup or new transmission alternative. Someone made one out of a servo which seemed to work pretty well
04-12-2016, 07:05 AM | #266 |
I stumbled across this and thought maybe it could be used for a divorced setup. You'll have to compare the dimensions as I don't have one of these RC4WD crawlers yet. It says it's only a 105rpm output on 6v. DC 6V 105RPM Micro DC Gear Motor Gear Box Motor Sale - Banggood.com |
04-12-2016, 08:03 AM | #267 | |
Rock Crawler Join Date: Mar 2009 Location: Parker, CO
04-12-2016, 02:24 PM | #268 |
Quarry Creeper Join Date: Jun 2014 Location: San Mateo
Yes the problem with these is the output shaft, cant seem to find any with a 1.5mm shaft to get the pinion onto, or a proper pinion to go on the motors with a bigger shaft.
04-12-2016, 04:03 PM | #269 |
If your willing to you can file down the shaft it's easy enough but when it comes to bolting the gear reduced motor to the transfer case you need to find a long enough bolt to go through the transfercase and through the brass gearbox to bolt into the motor. I've found that the motor needs to be bolted to the brass gearbox with both screws but what ever gets bolted to the transfercase you really only need one screw if you have the right sized pinion
04-12-2016, 08:07 PM | #270 |
Look at SDP or Polulo or smallparts.com, etc. This stuff exists. It just depends on how bad you want to make the mod..... |
04-12-2016, 09:14 PM | #271 | |
Quarry Creeper Join Date: Jan 2015 Location: Alcoa
kkpmo - Zahnräder M0.3 M0,3 für Modellbauer, Faller Car, Modelleisenbahn | |
04-13-2016, 01:54 AM | #272 | |
Pebble Pounder Join Date: Aug 2011 Location: Holland
04-13-2016, 04:32 AM | #273 |
Can anyone that has a zoomed in picture of the motor shaft post a picture? With dimensions of shaft length, diameter etc. and hole sizes to mount the motor on the trans. This will help so people here can have a much better idea and think about a solution as a joined effort? Team work...
04-13-2016, 06:35 AM | #274 | |
M2 mounting hardware 99% sure it's a 1.5mm shaft, very short Danally drilled and tapped the holes on a rewound 100t losi motor to 2mm to match the rc4wd motor and the holes still don't line up enough to use both screws to mount. It might be possible to slightly mod one of the holes to line up. I read it still wasn't great, the gearing is too high for that size motor. It needs a 130 or 180 gear head motor (1:30ish reduction) and a transfer case. Or possibly a pinion and spur mounted on the transmission. There is no bolt on motor replacement with adequate power. | |
04-14-2016, 12:22 PM | #275 |
Pebble Pounder Join Date: Jun 2012 Location: Derby, UK
Well my motor is in small pieces so can't provide an accurate shaft length any more, but I'd say 4-5mm max - there is very little room in there unless you open the back of the case up as well. The shaft dia is definitely 1.5mm and stock pinion is a 2.5mm deep 10T - the trans case allows adjustment for 9-11T but no bigger or smaller - a 12T definitely won't fit without removing case material. According to the RC4WD press blurb, the trans is 15:1 and the axles give a further 2.55:1, making a total reduction of 38.25:1. Given that most trekkers etc are running around 160:1 - 180:1 depending on pinion/spur, only a further 4:1 or 5:1 reduction is needed to get the RC4WD in the right ballpark. With a 130 or 180 can motor, trekkers are generally running closer to 110:1, in which case a 3:1 reduction for the RC4WD is about right. I'd say if we're going to the trouble we might as well aim high and work on a 130/180 can mod, particularly given the extra weight of this truck over most trekkers. Having looked over the chassis fairly carefully there really doesn't seem to be much room for a divorced setup, and limited mounting options. I think the ideal solution would be a pinion/spur setup including a slipper plate if possible - with 180 power something has to give |
04-14-2016, 12:46 PM | #276 |
I've been playing around with a spur/pinion setup for 130/180 can motors. This attempt ultimately failed as something wasn't lined up right, but I think I can sort it. I think the principle is sound, just the execution that was somewhat lacking Here's where I got to: I used what I had around - some ally sheet and tube, ally spacers from the HBX, shaft/pinion and bronze bearings from the stock motor, longer m2 hex scews and a 32T gear from a long dead HS81MG servo: The motor is a high torque 180 from my now even more dead esky llama heli - I've been waiting to find a use for it for some time Unfortunately it sits too far back and interferes with the top links, so I've had to revert to a 130 can big block from Danally. With a 16T pinion on the motor this setup will give me an extra 2:1 reduction, which I'm hoping will be enough with the big block. There seems to be room inside the chassis rails to get a 52T-54T gear in there, which would be a better ratio and might also lift the motor just high enough to allow clearance for the 180 can. Unfortunately I don't have a suitable gear lying around to try. I looked at using a losi slipper and shaft but it all got a bit much! |
04-14-2016, 06:40 PM | #277 |
| Re: RC4WDs New Micro Crawler This still makes me shake my head and wonder what the heck they were thinking, setting the things up with that ratio out of the box...
04-15-2016, 03:46 AM | #278 |
I'm surely hoop that Rc4wd comes up with some sort of gear/motor for this problem cause this really SUCKS BIG TIME!! CAN YOU DO THAT RC4WD!!! lol |
04-16-2016, 04:55 AM | #279 |
Pebble Pounder Join Date: Feb 2015 Location: Cambridge, UK
So to try and get a useable D90 I'm putting dual geared (300rpm from an Orlandoo F-150) motors into a custom built skid - still waiting for both the motors to turn up, but it should work OK! |
04-16-2016, 01:28 PM | #280 |
Good effort mate, looks simpler to put together than my attempt Should be good. I reckon two of the sumo size gearmotors might fit in the same way for even more power! I'm working on v2 of mine - so far so good. |
RC4WDs New Micro Crawler - Similar Threads | ||||
BWD Micro Wheel Weight System for the new Losi Micro Crawler! | billet works | Vendors Market | 19 | 10-18-2010 05:42 PM |
~Petition for RC4WDs next 1.9, 3.7" tall tire~ | STANG KILLA SS | Tires and Wheels | 105 | 02-03-2008 02:17 AM |
RC4WDs Aluminum 2.2 Hilux wheels | SuperSancho | Tires and Wheels | 5 | 04-29-2006 12:42 PM |
