03-23-2016, 07:14 PM | #201 |
Quarry Creeper Join Date: Jun 2013 Location: Twin Lake
| Re: RC4WDs New Micro Crawler |
03-23-2016, 10:26 PM | #202 | ||
| Re: RC4WDs New Micro Crawler Quote:
Might be interesting motor. | ||
03-24-2016, 11:57 PM | #203 |
Pebble Pounder Join Date: Jan 2014 Location: San Jose
Well got my DDT predator 90t installed. Definately more torque than stock but still not enough for this gearing. I did have quite a bit of glitching with stock electronics, swapped out with a spare 1/8 esc and axial RTR Tx. Cleaned up the glitches much smoother control. Pretty damn quick now too, gearing is just way too high.
03-25-2016, 06:09 AM | #204 |
Pebble Pounder Join Date: Jun 2012 Location: Derby, UK
So how did you get the predator mounted? My D90 arrived yesterday and I have an 80T predator lying around... I found the stock motor has picked up a bit of torque as it beds in. Still not enough even for trailing really though - it'll struggle over small obstacles but no low end control. |
03-25-2016, 01:00 PM | #205 | |
Sent from my SM-G900P using Tapatalk | |
03-26-2016, 05:00 AM | #206 |
Now that is good news! I happen to have a 2mm tap Just got to work out how to remove those o-rings on the driveshafts. I looked at them and couldn't figure it so backed away. The manual just shows them sliding on. Are they metal or just rubber?
03-26-2016, 06:14 AM | #207 |
Newbie Join Date: Mar 2016 Location: St.cloud
The orings are just rubber. Just be careful not to cut them while your removing them. Does anyone know pitch of the pinion gear on the motor? I want to try and build a 1.5 or 2.0 reduction box for it but I need to order some gears.
03-26-2016, 10:09 AM | #208 |
Quarry Creeper Join Date: Jun 2014 Location: San Mateo
I swapped the stock ESC for a Sidewinder Micro and a small 325 3S lipo using the stock motor and it helped a great seal, it will crawl slow and is even faster but the real improvement is when I hit an obstacle where in stock form it will just stall it will now climb over it, when its being held in place (stuck) it will spin all 4 tires and dig a trench in the dirt. It still needs gearing help but is much better and the motor on the 3S just barely gets warm. I think a gear reduction motor may be the ticket with this setup. |
03-26-2016, 06:54 PM | #209 |
RCC Addict Join Date: Oct 2011 Location: Brighton UK
Isn't the Sidewinder ESC brushless though? Can you pop a picture up of your set up"thumbs" Last question sorry, did that combo have any drag brake? |
03-26-2016, 07:53 PM | #210 |
Newbie Join Date: Apr 2015 Location: Australia
You can program it to be brushed Sent from my iPhone using Tapatalk |
03-27-2016, 09:52 AM | #211 |
Yes the sidewinder micro can do both brushed and brushless. I'll try to get some pics up later tonight.
03-27-2016, 10:56 AM | #212 |
Rock Crawler Join Date: Mar 2009 Location: Parker, CO
Tekin also makes good micro ESCs that will take 3S. I have used the small B1-R which is great for 3S on micro brushed motors. Tekin also makes a micro brushless controller.
03-27-2016, 11:00 AM | #213 | |
Isn't the B1-R a Holmes Hobbies controller? Which would be a Castle based controller. | |
03-27-2016, 12:21 PM | #214 | |
I wanna be Dave Join Date: Feb 2007 Location: South FL
The B1-R is a nice controller, but for the same $ a micro sidewinder is a little slimmer and will do brushed & Brushless and has tons of adjustment. If you're on a budget the xys-20a ESC is very tiny and usually only $12. Its brushed only | |
03-27-2016, 12:25 PM | #215 | |
03-27-2016, 04:51 PM | #216 | |
03-27-2016, 07:58 PM | #217 | |
Quarry Creeper Join Date: Jan 2015 Location: Alcoa
03-27-2016, 08:35 PM | #218 |
Rock Stacker Join Date: Mar 2016 Location: OK
It needs a geared motor. I'm not going to burn a bunch of time and money trying to figure out the best combo, so for now mine is shelved and /or may go up for sale to finance some other project. I wonder if rc4wd is working on some sort of upgrade kit for it to improve its crawling. |
03-27-2016, 08:55 PM | #219 | |
03-27-2016, 10:19 PM | #220 |
Quarry Creeper Join Date: May 2010 Location: Kaena Point, Hawaii
just got mine it was able to clime good sized roots, definitely needs lower gears tho. but im getting the mini sidewinder should be fun
RC4WDs New Micro Crawler - Similar Threads | ||||
BWD Micro Wheel Weight System for the new Losi Micro Crawler! | billet works | Vendors Market | 19 | 10-18-2010 05:42 PM |
~Petition for RC4WDs next 1.9, 3.7" tall tire~ | STANG KILLA SS | Tires and Wheels | 105 | 02-03-2008 02:17 AM |
RC4WDs Aluminum 2.2 Hilux wheels | SuperSancho | Tires and Wheels | 5 | 04-29-2006 12:42 PM |
