03-30-2016, 04:31 PM | #241 | |
Pebble Pounder Join Date: Jan 2014 Location: San Jose
| Re: RC4WDs New Micro Crawler Quote:
Sent from my SM-G900P using Tapatalk | |
03-30-2016, 04:34 PM | #242 |
Pebble Pounder Join Date: Jun 2012 Location: Derby, UK
Yeah no room - the length is fine but the output shaft on those is a 3mm D - the trans is looking for a tiny 10t pinion on a 1mm or 1.5mm shaft and there isn't enough room to mount anything much bigger. |
03-30-2016, 04:39 PM | #243 |
Can you bolt a brushless motor onto the gearbox to get a speed/torque medium?
03-30-2016, 04:49 PM | #244 | |
Quarry Creeper Join Date: Jun 2014 Location: San Mateo
I have one of these on my bench at home and like said above the shaft is way to big to fit a pinion on, and the motor itself is actually smaller than the stock motor. Quote:
03-30-2016, 10:13 PM | #245 | |
Quarry Creeper Join Date: Jan 2015 Location: Alcoa
04-02-2016, 01:30 AM | #246 |
RCC Addict Join Date: Oct 2011 Location: Brighton UK
All the talk so far is transmission and a little on axle width compared to the d90 shell. Have any of you sourced any cool body shells, ones that fit width wise, accepted wheelbase might be wrong. Any findings on rims, maybe tuck under more without rubbing? |
04-02-2016, 01:38 AM | #247 | |
RCC Addict Join Date: Dec 2007 Location: London
Will need a fe bits removing and some little holes filled but has potential. 122mm total width across the arches 165mm ish wheelbase Last edited by Dready; 04-02-2016 at 02:39 AM. | |
04-02-2016, 03:50 AM | #248 |
Aah Dready you jammy jammy get! That is just lovely. Is that the 1/16 Nikko body or something else? I have the 1/20 Nikko Hilux but it's way too small for the gelande. The trouble is the gelande really needs a 1/18 body - 1/16 is a bit too big and 1/20 too small. There don't seem to be any suitable plastic kits at that scale and old RCs tend to be either 1/16 or 1/20. I've spent a few years looking, as I always felt the micro wheels were too big, and I've yet to come across anything. At 122mm it'll actually need offset wheels, and possibly a larger diameter as well to look right. I have a couple of old radio shack/tandy bodies based (loosely) on a 79 Ford, but at 130mm width it is way too big for the gelande. The first one went on to a venom mini giant and I've yet to find a use for the second one: Last edited by Sparks1337; 04-02-2016 at 04:15 AM. |
04-02-2016, 09:22 AM | #249 | |
Rock Stacker Join Date: Jul 2011 Location: Crawler Teds Garage
I've seen the same video and it seems to work great. On his he has ditched the transmission and is using two of the winch motors hooked directly to the driveshafts somewhat like a MOA but retaining the shafts. Sent from my iPad using Tapatalk | |
04-02-2016, 11:26 AM | #250 | |
I wanna be Dave Join Date: Feb 2007 Location: South FL
04-07-2016, 04:36 AM | #251 |
Pebble Pounder Join Date: Aug 2011 Location: Holland
Hi everyone, Got mine today and wanted to swap tire and rim but I can't unscrew those tiny M2 nuts using a traditional tamiya T wrench. Any suggestions would be greatly appreciated. Thanks. |
04-07-2016, 05:31 AM | #252 | |
Pebble Pounder Join Date: Jan 2009 Location: South West Germany
http://cdn.pollin.de/article/xtrabig/X501085.JPG Regards Wolf | |
04-08-2016, 08:46 AM | #253 |
Rock Stacker Join Date: Mar 2016 Location: OK
Seems like it would not be a massive challenge to design and 3D print a dual motor mount for two of those little geared motors. They could be next to each other and opposed, with each connected directly to its respective driveshaft. The stock trans is almost too pretty to ditch, but it's borderline worthless
04-08-2016, 09:15 AM | #254 |
Rock Crawler Join Date: Mar 2009 Location: Parker, CO
I will build the 3D model if you have a printing source.
04-08-2016, 09:37 AM | #255 |
I wouldn't say the stock transfer case is worthless. The axles are just geared high. That seems to be a common problem with axles in this scale, the Sumo and I think the RC4WD micro Trex axles were geared high. Maybe it has something to do with getting enough gear in this small size? I don't know how Sam's 1/18 axles are geared however. You could get more reduction by going to a divorced motor setup a few different ways, I don't think I've seen that yet. |
04-08-2016, 06:07 PM | #256 | |
Newbie Join Date: Feb 2011 Location: new zealand
Also for those interested ive made a leafspring setup with new shocks and extended the wheelbase out to about 155mm and am planning on making a lwb body for it so maybe like a pickup or wagon, haven't fully decided yet but ill be making a build thread in the near future | |
04-09-2016, 02:35 PM | #257 |
Rock Stacker Join Date: Apr 2016 Location: U.K.
Hi has anyone tried to fit an Orlando F150 1/35 reduced gear motor onto this D90? I have the Orlando F150 and there is plenty of torque from the motor. But it's for a 1/35 rig and is all plastic. So lighter and smaller wheels. Link to the Orlando F150 motor. Orlandoo OH35P01 KIT RC Car Parts Gear Motor Sale - Banggood Mobile http://imgapp.banggood.com/thumb/vie...KU206790-4.jpg This is the 120rpm one, but a 200rpm one might just be good for the D90? Last edited by Aeronuclear; 04-09-2016 at 02:41 PM. |
04-09-2016, 04:35 PM | #258 | |
04-09-2016, 06:12 PM | #259 |
| Re: RC4WDs New Micro Crawler |
04-09-2016, 06:15 PM | #260 |
Now that it's divorced you should easily be able to fit the 59t and 60t spur gear from the losi micro rally/SCT. Should be a nice improvement. More torque and slower speed.
RC4WDs New Micro Crawler - Similar Threads | ||||
BWD Micro Wheel Weight System for the new Losi Micro Crawler! | billet works | Vendors Market | 19 | 10-18-2010 05:42 PM |
~Petition for RC4WDs next 1.9, 3.7" tall tire~ | STANG KILLA SS | Tires and Wheels | 105 | 02-03-2008 02:17 AM |
RC4WDs Aluminum 2.2 Hilux wheels | SuperSancho | Tires and Wheels | 5 | 04-29-2006 12:42 PM |
