03-18-2016, 10:05 PM | #161 | |
Rock Crawler Join Date: Mar 2009 Location: Parker, CO
| Re: RC4WDs New Micro Crawler Quote:
Its funny, Back in 2002 (ish) I bought a hard plastic D90 1/10 body from a guy in Hong Kong. It was taken off of a toy-grade RC toy. There were only a few in the states - really rare. Now the exact same 1/10 D90 bodies are commonly available through RC4WD. Similarly, my little 1/18 D90 body was a taken of of a rare toy. I wonder if Mike at RC4WD found the same source in China that made the toy for my 1/18 D90 and acquired the molds like they did for the big D90. Could be..... Last edited by Shape_Shifter; 03-18-2016 at 10:39 PM. | |
03-18-2016, 10:05 PM | #162 | |
Rock Stacker Join Date: Mar 2016 Location: OK
Edit, now that I look at it, they might be pretty darn close. Nice build | |
03-18-2016, 10:44 PM | #163 | |
Do me a favor and post a pic of the rear door and the gas cap on yours if you can. Those were different on the two 1/10th D90 bodies. Of course my chassis was one of a kind... | |
03-18-2016, 10:48 PM | #164 |
Rock Crawler Join Date: Dec 2005 Location: East Texas
Is your body the same as these first couple ones? Where can you get them? thanks and yes yours is killer. Nice work 1/18 CNC Axle DIY Chassis (D90&G55) Last edited by Joshs4x4toyz; 03-18-2016 at 10:51 PM. |
03-18-2016, 11:10 PM | #165 | |
I just rembered I still have one of the rare toy bodies like I used but its a D90 pickup. This is the same wheelbase as my D90, and the Galende II. | |
03-19-2016, 06:06 PM | #166 |
Pebble Pounder Join Date: May 2014 Location: Floriduh
| Re: RC4WDs New Micro Crawler For now I just removed those stiff pen springs from the shocks and mounted up my Boggers. Gonna get to painting the body next. |
03-19-2016, 10:14 PM | #167 |
Newbie Join Date: Feb 2011 Location: new zealand
So ive been working all weekend on improving this rig and was adamant on making a divirced motor setup work and heres what i came up with. i used the brass parts from a few of those small gear reduced motors, i had some lying around so i thought id pull them apart and give it ago. there was some filling and drilling involved so i pretty much had to destroy any chance of reverting back to the original setup if it didnt work out but im confident it will work have yet to test run it as i need to make a shaft to complete the drivetrain. Tell me what you think |
03-19-2016, 11:36 PM | #168 |
Props Will. That took some cojones. What is the ratio for the divorced gearbox?
03-19-2016, 11:47 PM | #169 |
| Re: RC4WDs New Micro Crawler |
03-20-2016, 12:04 AM | #170 |
03-20-2016, 12:37 AM | #171 |
Rock Crawler Join Date: Dec 2005 Location: Hawaii
killer start crawler_will, what trans is that? Quote: |
03-20-2016, 12:41 AM | #172 |
Thanks, its the stock trans that ive taken the motor off and modified so i can use a separate motor one that will hopefully provide plenty of torque |
03-20-2016, 12:43 AM | #173 |
03-20-2016, 12:46 AM | #174 |
I see you used the stock transfer case, what transmission is the on the divorced motor? I don't have stuff laying around to tinker with so I ordered a Losi micro crawler trans. |
03-20-2016, 12:59 AM | #175 |
03-20-2016, 09:01 PM | #176 |
Newbie Join Date: Jul 2013 Location: Grand Junction
Still no luck with getting a danally predator motor in mine. The mounting holes seem identically spaced compared between the two motors but are off just enough so using one bolt to mount it is the only option, and no matter how tight I got it you could still easily rotate the motor. Even the shafts seem to be different sizes (thicker shaft on the predator (that's what she said)) so I couldn't use my 9t pinion from my predator motor. Grrrrr... I have noticed a little more torque out of the stock motor after running it for a bit though Sent from my iPhone using Tapatalk |
03-20-2016, 10:15 PM | #177 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
Someone in the facebook group seems to have found a compatible motor. You have to be a member of the group to view the post. https://www.facebook.com/groups/1494...5411896696545/ this post compares the RC4WD with "SAms's" 1/18 chassis and axle kit that was available for a limited run. Using the Newbright TJ body https://www.facebook.com/groups/1494...4805726757162/ |
03-20-2016, 10:44 PM | #178 |
Newbie Join Date: Jun 2012 Location: Oahu, Hawaii
03-21-2016, 07:50 AM | #179 |
Spoo, can you paste that info here?
03-21-2016, 11:53 AM | #180 |
Quarry Creeper Join Date: Jan 2015 Location: Alcoa
| Re: RC4WDs New Micro Crawler https://youtu.be/RwPw2Ke5XqE https://youtu.be/nnKeIczAebo Quick video of redcat sumo crawler tranny swap. Last edited by TownsendTdi; 03-25-2016 at 10:27 PM. |
RC4WDs New Micro Crawler - Similar Threads | ||||
BWD Micro Wheel Weight System for the new Losi Micro Crawler! | billet works | Vendors Market | 19 | 10-18-2010 05:42 PM |
~Petition for RC4WDs next 1.9, 3.7" tall tire~ | STANG KILLA SS | Tires and Wheels | 105 | 02-03-2008 02:17 AM |
RC4WDs Aluminum 2.2 Hilux wheels | SuperSancho | Tires and Wheels | 5 | 04-29-2006 12:42 PM |
