03-17-2016, 06:36 PM | #141 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
| Re: RC4WDs New Micro Crawler
If I had one I'd try to make a motor plate adapter like for other cars and RCs. I've done it to use outrunners in bigger crawlers. Mount a plate that has the stock motors bolt pattern to the losi sized motor or big block. Then you bolt it to the trans as normal. The shafts on either motor should be long enough to set the pinion in far enough. I don't know that it would all fit together in this case,but it's worth a shot. From what I've read these heavy things could really use some big block power.
03-17-2016, 08:56 PM | #142 |
Rock Stacker Join Date: Mar 2016 Location: OK
| Re: RC4WDs New Micro Crawler Last edited by Clingman; 03-17-2016 at 09:52 PM. |
03-17-2016, 10:49 PM | #143 |
Quarry Creeper Join Date: May 2010 Location: Kaena Point, Hawaii
looks good
03-18-2016, 02:52 AM | #144 |
Pebble Pounder Join Date: Jun 2012 Location: Derby, UK
Very nice, great colour choice Sent from my GT-I8190N using Tapatalk |
03-18-2016, 07:01 AM | #145 |
Thanks guys. Color is Tamiya ts-2 if anyone's wondering.
03-18-2016, 09:58 AM | #146 |
Rock Crawler Join Date: May 2009 Location: Hillsboro, OR / Kapolei, Hi
Hmmmm. This should fit the Lindberg 1:20 model bodies nicely.
03-18-2016, 10:26 AM | #147 |
They look so good. I want one more every time I see them.
03-18-2016, 10:31 AM | #148 |
Newbie Join Date: Jul 2013 Location: Grand Junction
Just got mine and it needs quite a bit of work to perform the way I expected. The steering knuckles need to be shaved off where the BTA steering tabs hit the lower shock mount to gain more steering, where the bearings seat in the knuckles is really sloppy causing some serious wheel wobble, and a more powerful motor install will be a must. Otherwise I really love the way it looks and it definitely has potential. Should be a fun project! Sent from my iPhone using Tapatalk |
03-18-2016, 11:31 AM | #149 |
I'd hesitate before doing any major surgery to the knuckles - see crawler will's post on p7 of this thread about dogbones... Sloppy bearing seats to add to the list of crimes, not good. This little truck has sooo much potential it's a shame it has so many issues.
03-18-2016, 11:37 AM | #150 |
To me the steering isn't as much an issue as the power. My wheels do have some play but it's not excessive. Might be some variation in manufacturing showing itself.
03-18-2016, 06:14 PM | #151 |
| Re: RC4WDs New Micro Crawler |
03-18-2016, 08:02 PM | #152 |
Quarry Creeper Join Date: Jan 2015 Location: Alcoa
03-18-2016, 08:08 PM | #153 |
03-18-2016, 08:13 PM | #154 |
Newbie Join Date: Feb 2011 Location: new zealand
03-18-2016, 08:51 PM | #155 |
Cool, keep us updated. It does need to be geared down more for sure.
03-18-2016, 08:57 PM | #156 |
Rock Crawler Join Date: Mar 2009 Location: Parker, CO
03-18-2016, 09:09 PM | #157 |
Thanks for the tip, Townsend. I was wondering why the front seemed to have less travel than the rear. Must be due to the offset mounting locations of the inner links to the frames.
03-18-2016, 09:10 PM | #158 |
03-18-2016, 09:36 PM | #159 |
| Re: RC4WDs New Micro Crawler Once I relocated the links, it looked like the link from the servo horn to the knuckle was limiting the front a bit. Maybe a bent link would help.
03-18-2016, 10:03 PM | #160 | |
| Re: RC4WDs New Micro Crawler Quote:
Moving the links got the front end to really free up. It felt like it was springing against the links, so it was unable to take advantage of the extra 3mm in shock length I got by ditching the white guides. The rear felt like the shocks were able to use the full stroke, so I left the rear links where they were for now. Some longer shocks would definitely require relocating the links there too. With some longer shocks we should be able to get some pretty extreme travel, but I'm pretty happy with it as it sits right now. Just need to get it slowed down and get some climbing torque now | |
RC4WDs New Micro Crawler - Similar Threads | ||||
BWD Micro Wheel Weight System for the new Losi Micro Crawler! | billet works | Vendors Market | 19 | 10-18-2010 05:42 PM |
~Petition for RC4WDs next 1.9, 3.7" tall tire~ | STANG KILLA SS | Tires and Wheels | 105 | 02-03-2008 02:17 AM |
RC4WDs Aluminum 2.2 Hilux wheels | SuperSancho | Tires and Wheels | 5 | 04-29-2006 12:42 PM |
