07-03-2019, 06:05 PM | #181 |
Rock Stacker Join Date: Nov 2018 Location: Louisville
| Re: New Axial scx 24 deadbolt Quote: Sent from my SM-G955U using Tapatalk |
07-03-2019, 06:17 PM | #182 |
RCC Addict Join Date: Nov 2017 Location: Austin Texas
I honestly don't know. I was just going by the fact that the esc/ rec light wasn't blinking. So far I've only run the supplied battery and used the supplied charger. I want to balance charge it on my imax b6ac v2 but I need a lead. I'm going to get this in order to balance charge the stock lipo: https://www.amainhobbies.com/betafpv...SABEgJ2ePD_BwE I also already picked up a couple of these lipo's to balance charge directly from my b6ac v2 but haven't used them yet. https://www.amazon.com/OVONIC-Babyha.../dp/B07CV987XB |
07-03-2019, 06:21 PM | #183 |
I use a little eFlite 2s balance charger for all my micro batteries. Got two of them off eBay for less than $20 a year or so back.
07-03-2019, 06:32 PM | #184 |
I've also had the batteries drop down below 3v too so now I try to run it for like 30 minutes and then check the cells. I've been making sure to stop before it has a chance to (not) hit the LVC lol. I looked into the LVC to see if its adjustable and I didn't find any info on where its set just that there is one which is easy to doubt. I made up an adapter for these batteries, stock is a PH 2.0 plug Since then I switched to JST's and made a new adapter. Last edited by HumboldtEF; 07-03-2019 at 06:34 PM. |
07-03-2019, 06:52 PM | #185 |
Pebble Pounder Join Date: Jan 2013 Location: south jersey
| Re: New Axial scx 24 deadbolt |
07-03-2019, 08:47 PM | #186 |
Quarry Creeper Join Date: Jul 2015 Location: Menifee
Sounds like the servo is a weak spot. It does ok if you keep moving I ordered this https://hobbyking.com/en_us/corona-9...4aAisREALw_wcB It was $12 shipped should get it next week I would have order this one. Twice as strong, smaller and only $15 shipped. Didn’t want to wait 7-26 days for the slow boat from China https://hobbyking.com/en_us/corona-d...0sec-8-5g.html I am thinking 30+oz of torque should be enough |
07-03-2019, 10:21 PM | #187 |
I've got a Bluebird BMS 373MG micro servo ready to install. 28 oz/ in and .11 sec @ 6v. Was $14.80 thru Hobby King
07-07-2019, 09:47 AM | #188 |
Getting a few things done on the deadbolt Moved the stock shocks for more articulation Added lead to front wheels Got the battery mount, rear hinge and stinger front bumper printing up....and a set of 8 hole wheels Got a new servo in the mail Got the body painted and bikini top done to match my 1/10 Thanks guys for all the great info here |
07-07-2019, 03:46 PM | #189 | |
Sent from my SM-G955U using Tapatalk | |
07-07-2019, 03:47 PM | #190 | |
07-10-2019, 05:49 PM | #191 |
07-10-2019, 06:00 PM | #192 |
Was that a PH 2.0? I'll have to double check my spare plugs, EDIT yes a PH 2.0 fits I've converted both of mine to JST plugs. As for the LVC issue yeah it does suck, you can still get decent run time if you try to stop a bit before going too low. Last edited by HumboldtEF; 07-10-2019 at 06:41 PM. |
07-10-2019, 06:19 PM | #193 | |
Quarry Creeper Join Date: May 2019 Location: North Highlands
I'll be converting mine over to XT-30s. | |
07-10-2019, 06:20 PM | #194 |
07-10-2019, 06:57 PM | #195 |
07-10-2019, 06:59 PM | #196 | |
07-10-2019, 07:05 PM | #197 |
So pissed I can't play with the truck basically since I got it. Took out a couple times. The esc messed up the battery for sure at 2.8v but Axial was awesome and helped with replacement parts. I still don't know which broke and don't like using the charger that charges at 2a on a 350mah battery. Gonna wait until.the connector arrives to charge on a real balance charger. Sent from my SM-G955U using Tapatalk |
07-10-2019, 07:14 PM | #198 | |
I don't remember if it was Humbolt or Bigworm or someone else that posted the pigtails originally... but I was under the assumption that the pigtail connector would fit the battery connector and that I could just solder on a Deans or XT plug ( or banana plugs) that would plug into my balance charger. I apologize for not replying sooner... I somehow overlooked this thread recently. | |
07-10-2019, 07:23 PM | #199 | |
07-10-2019, 07:26 PM | #200 |
New Axial scx 24 deadbolt - Similar Threads | ||||
SCX 10.2 Jeep XJ Body on SCX 10 Deadbolt? | sacsmitty | Axial SCX-10 | 5 | 08-15-2018 12:16 PM |
My new Axial SCX-10 Deadbolt | KA7EII | Axial SCX-10 | 4 | 05-21-2016 09:24 PM |
New scx 10 deadbolt | BigCountry11 | Axial SCX-10 | 8 | 07-25-2014 10:00 AM |
