07-22-2019, 01:10 PM | #221 | |
Rock Stacker Join Date: Feb 2019 Location: Los Angeles
| Re: New Axial scx 24 deadbolt Quote:
I think I have some really tiny "RCX" brand outrunner revolver style motors from the micro quad builds of the past that I believe are smaller than the revolver 380. Does anyone know of the smallest micro brushless motor out there? Actually after a quick search around, Hobbyking and Banggood both show some absolutely tiny brushless motors: Now that one in the image is a ridiculously high kv but there seem to be plenty of sub-10g options around 1500-3500kv out there like this: https://hobbyking.com/en_us/ax1304-2...otor-6-5g.html Is there any value in these in our future? I know these are built to take a prop but it seems like for someone like JRH the parts exist to build a micro revolver. Last edited by jessedacri; 07-22-2019 at 01:21 PM. | |
07-22-2019, 05:17 PM | #222 |
Rock Crawler Join Date: Mar 2009 Location: Parker, CO
I used an 80Kv motor from a camera gimbal. Perfect Kv for a micro crawler. Anything with higher Kv would need a ridiculous gear reduction to make it useful. In this vid I used a cheesy ESC with no programming. I may try this setup again with a castle ESC to get some more low voltage torque. https://youtu.be/JHzCS9vx3WQ . |
07-22-2019, 09:53 PM | #223 |
Quarry Creeper Join Date: Jul 2015 Location: Menifee
I run brushless in all my 1/10th scale. I have even thought about trying an outrunner in them. The problem you see from the video is kogging. Your really need a sensored set up. I have never tried the castle sensorless set up And the hardest thing to find is a brushless esc that has instant reverse |
07-22-2019, 10:01 PM | #224 |
Quarry Creeper Join Date: May 2019 Location: North Highlands
| Re: New Axial scx 24 deadbolt |
07-23-2019, 06:07 AM | #225 |
07-23-2019, 06:09 AM | #226 | |
Most of these outrunners set up like this micro pictured can have the shaft pressed out of the bell and reinstalled from the reverse side. | |
07-23-2019, 12:47 PM | #227 |
Rock Stacker Join Date: Nov 2009 Location: hamilton, oh
Where would be a good place to buy some good wheels and tires? not sure I am ready to drop $60 on a set of rims just yet, but I would like to do a nice upgrade Quote: |
07-23-2019, 01:06 PM | #228 |
Newbie Join Date: Dec 2015 Location: Granite City
Yes there is https://www.shapeways.com/shops/lynx...aign=affiliate How about under 20.00 https://lynxmicrotech.wordpress.com/ This one has his email address in case you have any questions |
07-23-2019, 02:06 PM | #229 | |
The Shapeways page will work. I don’t think Fungi answers emails anymore but he may. Tires for the RGT from Amain or some RC4WD from FleaBay. | |
07-23-2019, 03:00 PM | #230 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
AsiaTees has lots of parts for The RGT/FTX, and CR-24 Sent from my LGMP450 using Tapatalk |
07-23-2019, 05:28 PM | #231 |
RC4WD has some of the white steelies in stock - https://store.rc4wd.com/Stamped-Stee...te_p_7056.html They're supposed to get more of the $20 black ones in soon too. I got a set just last week |
07-25-2019, 02:43 PM | #232 | |
Rock Stacker Join Date: Jun 2019 Location: Fishers, In.
07-25-2019, 04:10 PM | #233 |
Find 2 longer bolts to get the halves started together. Then replace them once the shorter ones are seated.
07-25-2019, 05:02 PM | #234 | |
I found even if I clamped these tight in my hand the threads would instantly strip out on the hubs. Anyway what I did was make a little clamp out of a M2.5 bolt, a nut and some washers cutting some notches in one of the washers on top so I could sneak 2 bolts by. Even with this tool they're still a bit of a struggle, I found that getting these 2 screws sort of positioned right (but not threaded in) helped to keep the 2 halves aligned. I got 1 mounted without it and the other 7 were a big struggle. Last edited by HumboldtEF; 07-25-2019 at 05:06 PM. | |
07-25-2019, 05:17 PM | #235 |
Rock Crawler Join Date: Nov 2008 Location: Nor*Cal Cameronpark
You have to make sure all the holes line up. The hub the outer & inner faces. They are drilled to line up a certain way. I like to find the hole at center of the triangle on the face. Pretty much only one lines up at the tip then line up the back face. I mounted scramblers with stock hardware in like 15mins for all four wheels. Key is to line it up or you will be fighting it. You can see in the pic only one bolt lines up with the tip of the triangle. 9 o clock bolt in the pic. Line these up & your good! Sent from my iPhone using Tapatalk |
07-25-2019, 05:42 PM | #236 |
I’ve got some 1.9 and 2.2 stamped steelies like these but not the 1”. Love the look and weight but they’re a pain to get started. With the larger wheels I have used a socket to hold the hex and push down from the top to get them started. But the clamping bolt through all pieces is a better approach. I’ll use that idea the next time I make up a set.
07-25-2019, 06:49 PM | #237 |
| Re: New Axial scx 24 deadbolt This was absolutely not the case for me and I've assembled many, many wheels easy and hard, these are among the most finicky I've had. I lined it up started a thread or 2 and... stripped, next hole... stripped, next hole... stripped and so on. clamping them with the setup I posted above was truly the only way I was able to mount the RC4WD tires (MT/R's and Baja Claws). Last edited by HumboldtEF; 07-25-2019 at 07:32 PM. |
07-25-2019, 07:19 PM | #238 |
Quarry Creeper Join Date: Oct 2009 Location: northeast ohio
I have the same issue, I'mpretty sure mine stripped too. I've tried countless times, I even ordered longer screws, I still don't have my tires mounted. Sent from my SM-G955U using Tapatalk |
07-25-2019, 08:39 PM | #239 |
They were fiddly for sure, but I managed to get them done fairly quickly. I don't think there's a real trick to it unless you can find longer screws to work with. I imagine quys with extra large hands will have a bit of a harder time than others. Luckily mine are just average. At least that's what my ex-wife said...
07-25-2019, 08:39 PM | #240 |
Well I have done six sets of these 1.0 rims with various tire combos. Never had a issue with stock hardware. These are some of the easiest beadlocks at this size I have dealt with!
New Axial scx 24 deadbolt - Similar Threads | ||||
SCX 10.2 Jeep XJ Body on SCX 10 Deadbolt? | sacsmitty | Axial SCX-10 | 5 | 08-15-2018 12:16 PM |
My new Axial SCX-10 Deadbolt | KA7EII | Axial SCX-10 | 4 | 05-21-2016 09:24 PM |
New scx 10 deadbolt | BigCountry11 | Axial SCX-10 | 8 | 07-25-2014 10:00 AM |
